Truck King's 4th Gen TRD Off Road 6MT: It's Broken... :-(
Discussion in '4th Gen. Tacomas (2024+)' started by Mad German, Jun 29, 2024.
  1. Jul 2, 2024 at 1:27 PM
    #101
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    ^Thanks. Yes, you wouldn't get grinding going 5th to 3rd, but yes, 5th to 1st!
  2. Jul 2, 2024 at 5:48 PM
    #102
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yeah well, some of my friends might disagree with yer shit talkin'
  3. Jul 2, 2024 at 6:01 PM
    #103
    linuxpickup
    linuxpickup Well-Known Member
    2024 OR MT
    Cannot. Resist.
    But seriously, thanks for taking one for the team, or just getting away from your sock drawer, whichever was your primary motivation.
    SH10151 and JustAnotherSquid like this.
  4. Jul 2, 2024 at 7:01 PM
    #104
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    FYI, quite a few Canada geese are born in the USA.
    JustAnotherSquid likes this.
  5. Jul 2, 2024 at 11:00 PM
    #105
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    I’d love to hear who at Toyota programmed a rev match from 5th to 1st and a 11k rpm blip
    Lt. Dangle and lastcall190 like this.
  6. Jul 2, 2024 at 11:46 PM
    #106
    linuxpickup
    2024 OR MT
    I don't use the iMT either and don't know its limits/internal workings but would guess when he was grinding it that it had already reached whatever its max. is and said "you're on your own bud". If it had rev matched 1st he might have actually got it all the way in gear? Which may have yielded a much worse result.
    They scrap the press cars after they are done with them, right?
  7. Jul 3, 2024 at 3:51 AM
    #107
    JustAnotherSquid
    JustAnotherSquid Just here for the resale value
    Charlotte, NC
    2024 White TRD Sport 4x4 6MT
    No one did, because it didn't and it doesn't.
    So I think you are mixing up the two sides of the clutch, as many people in this thread are. iMT has absolutely nothing to do with the success or failure of him getting the transmission into first gear. All of that is happening on the opposite side of the open clutch.
    Since both my sock and underwear drawers are now organized, I have plenty of time to pontificate so let's walk through what happened in that catastrophic video, beginning with Chucklehead driving along at 2K in fifth. The clutch is closed so both sides are turning ~2K.
    He opens the clutch and engine revs drop to idle but the transmission is still in fifth. At this point the engine side of the clutch is turning ~800 rpm and the trans side of the clutch is still turning ~2K.
    He moves the gear shift over and tries to force it into first. Two completely different things are happening on either side of the clutch. On the trans side, the syncros are being forced to try to spin the input shaft (and that side of the clutch) up to ~12K rpm. (!!!) On the engine side, iMT senses that more than redline is required to rev-match, so it does the best it can: it tries to bring the engine (and that side of the clutch) up to 5,300 rpm and hold it there. That's the only choice it has under these horrific circumstances, and I'm willing to bet iMT is petrified at this point because it knows that if Chucklehead does get it into first, and then releases the clutch, iMT and the rest of the engine are going to die a horrible, painful, humiliating death.
    But, Chucklehead doesn't get it into first. Somewhere on it's journey from 2K to 12K rpm, the input shaft (and the trans side of the clutch) explodes. Chucky releases pressure on the gear shift lever, iMT breathes a sigh of relief, and engine revs (and the engine side of the clutch) fall back to idle. Then our illustrious videographers coast to the side of the road and say "OMG TOYOTA BLEW UP! TOYOTA BAD!"
  8. Jul 3, 2024 at 6:51 AM
    #108
    2001 4x4
    2001 4x4 Well-Known Member
    2008 TRD Offroad 6MT
    Guarantee there will be a software update coming for the iMT system!
  9. Jul 3, 2024 at 6:54 AM
    #109
    JustAnotherSquid
    Charlotte, NC
    Why? It did nothing wrong.
    vtown and henryp like this.
  10. Jul 3, 2024 at 6:59 AM
    #110
    2001 4x4
    It sounds like the iMT system tried to match the rpm that it would be at in 1st gear at 55mph and cooked it’s self.
  11. Jul 3, 2024 at 7:01 AM
    #111
    JustAnotherSquid
    Charlotte, NC
    Nope. Read the post three posts above yours.
    vtown and 2001 4x4[QUOTED] like this.
  12. Jul 3, 2024 at 7:04 AM
    #112
    ethanfiamingo
    ethanfiamingo Well-Known Member
    Ethan
    2011 Regular Cab 4wd 5sp
    I am not sure about the trans in the 4th gen, but in my 2nd gen there is no way I could accidentally go to 1st from 5th without absolutely muscling it in as there is a lockout that either knows rpm or wheel speed. The trans can only get into first under 5mph, and trust me I have accidentally tried to go to 1st from higher gears many times and it saved my butt. I would be surprised a newer trans wouldn't have this but the software controlling it might be the issue. As a LONG time manual Tacoma driver, I also don't think he ever got to first as the rpm didn't get nearly high enough, AND the wheels would have locked/ chirped as the engine braking from the speed differential would be massive.
    doublethebass likes this.
  13. Jul 3, 2024 at 7:13 AM
    #113
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    There's no lockout that stops you from doing it. The synrcos can't match the speed and that makes it difficult to get into the lower gear. The entire point of a manual trans is that you have control over it; not the computer.
    Read justanothersquids post. He explains it well.
  14. Jul 3, 2024 at 8:28 AM
    #114
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    I don't think there is a ''you can't fix stupid'' software upgrade.
    If there was, the inventor would make Gates look like a pauper.
  15. Jul 3, 2024 at 8:28 AM
    #115
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Lies!
  16. Jul 3, 2024 at 8:37 AM
    #116
    JustAnotherSquid
    Charlotte, NC
    So question for you: Do USA-born Canada Geese fly in km/h or mph? I'm betting they fly in mph.
  17. Jul 3, 2024 at 9:09 AM
    #117
    CrispyTacoLover
    lol. There are a few each year at the nature center I walk my dog.
    SH10151[QUOTED] likes this.
  18. Jul 3, 2024 at 9:12 AM
    #118
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    My dog would always LOVE to eat the green goosy treats they left behind on the grass and then he would get so damn sick.
    shakerhood and BrokenMachine like this.
  19. Jul 3, 2024 at 9:13 AM
    #119
    CrispyTacoLover
    Yea, Beau loves them too.
  20. Jul 3, 2024 at 9:27 AM
    #120
    tmac5809
    tmac5809 Well-Known Member
    It's been over a decade since I drove a manual, but I am pretty sure all the MT's I drove didn't allow you to go into 1st if you weren't going slow enough. But then again I never tried 1st going 55mph.
    SH10151 likes this.
