Truck leaning to one side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Silence9, Jan 4, 2014.
  1. Jan 4, 2014 at 1:02 PM
    Silence9
    Silence9 [OP] Solve et Coagula
    Alberta, Canada
    Hi there. My truck seems to be leaning toward the driver side, it has been like this for months and it is quite irritating. What could be causing this? I am still under my warranty so it would be nice to have a diagnosis before it runs out. I just read pages about undertightened U-bolts on leaf springs, would that make a difference in the way the vehicle sits if one side is torqued higher than the other? I am going to borrow a torque wrench and tighten them up either way. Maybe one of the leaf springs is faulty? Plz help. :mad:
  2. Jan 4, 2014 at 1:04 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    unfortunately its normal. its the notorious taco lean. ... its due to the extra weight from the gas tank and driver being on that side. its strains the leaf springs faster.
  3. Jan 4, 2014 at 1:04 PM
    MTLTaco
    MTLTaco Well-Known Member
    Montreal
    09 Double Cab TRD
    Otherwise known as the taco lean. Mine does it too especially with a full tank of gas. Normal. The battery and gas tank are both on the drivers side
  4. Jan 4, 2014 at 1:09 PM
    Silence9
    Alberta, Canada
    Thanks for putting my mind at ease. It sucks, but at least it's not a problem. Maybe I will change it to a right hand drive setup to offset the wear and weight. :rolleyes:
  5. Jan 4, 2014 at 3:03 PM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    Or getcha a big old girl friend.....LOL
    pinchenolan, rke1063 and DukesTaco like this.
  6. Jan 4, 2014 at 3:06 PM
    Luis1
    Luis1 Well-Known Member
    Alberta, CA
    2013 Tacoma DCLB TRD SPORT 4x4
    - OME 2.5 inch lift nitro charger with 886 coils in front and 2 inch lift OME nitro charger with heavy Dakar leaf pack - custom high clearance rear steel bumper with swing out made by Vertan Kustoms out of Alberta. Carts full size spare and 2 x 20L Jerry cans - Allpro Apex front bumper - Smittybilt 10000lbs winch w/ synthetic line - Dobinsons Snorkel - RA Motor sports roof rack and bed rack - 5 x 6inch Diode Dynamic light bars on roof - 2 x unknown brand ditch light pods - 5 x 285/70/17 BFG Ko2 - 5 x Black Rhino Stadium wheels - deep dish - 17x9.5 with - 18 offset - exhaust chop mod - rear seat delete - horrendous mpgs lol
    haha and the banjo plays
  7. Jan 4, 2014 at 3:35 PM
    Silence9
    Alberta, Canada
    :p:p:p
  8. May 6, 2017 at 8:19 AM
    Michael226
    Michael226 New Member
    Michael
    I also have the same problem with my 2016 Tacoma, 1" higher on the passenger rear spring. Although my dealership is working with me and replaced the driver's side rear spring, but it did not solve the problem. I now have a appointment with them next week and they want to get the frame checked for proper alignment.
    I agree with you that is does look horrible and I think that in the long run it could do some unnecessary wear and tear on the drive train.
    Michael
  9. May 6, 2017 at 9:05 AM
    Tacotruck422
    Tacotruck422 Well-Known Member
    Seattle, Wa
    2015 DCLB
    Pro wheels, bilstein 5100's, 265/70/17 ko2's
    This causes no suspension problems in the long run but to ease your mind(and eyes) companies make a 1/2" block to help. I made my own out of a spare overload.
  10. May 6, 2017 at 9:07 AM
    DrFunker
    DrFunker Well-Known Member
  11. May 6, 2017 at 9:36 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    As has already been mentioned, it's normal (at least on the 2nd gens). If it bothers you, you can get one of these installed:
    https://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-8317
  12. May 6, 2017 at 9:54 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    So if you don't do a lot of driving, is it best to avoid keeping a full tank of gas? Just bought my truck, but it's perfectly level. I'm not a heavy dude either.
  13. May 6, 2017 at 9:56 AM
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    If it visually bothers you that much, I guess. I have a 1/4" spacer that I need to put in but I don't want to deal with paying for another $100 alignment. Probably will wait a year until I need new tires.
  14. May 6, 2017 at 10:00 AM
    Fitz235
    Rob
    New Hampshire
    I bet if you measure from center of hub to bottom of fender, you'll find you do have 1/2" to 3/4" delta from passenger side. No real reason to do anything about it, as it's normal. As has been mentioned, if you have any level of OCD (as many of us do) you can correct it with a spacer.
  15. May 8, 2017 at 8:35 PM
    Thillman
    Thillman Well-Known Member
    '12 Tacoma TRD Off-Road
    Mine does it too; I heard levelling kits come with additional washers/spacers for the driver side to compensate when you have a full tank
  16. May 9, 2017 at 1:38 PM
    Michael226
    Michael
    If more people complained about it to Toyota and stopped accepting it as normal, Toyota might make come up with a solution. Any new truck should never have this problem.
  17. May 9, 2017 at 3:33 PM
    Thillman
    Agreed Toyota is basically, and I hate saying this, the Apple of trucks.
    Sent from my iPhone.
  18. May 9, 2017 at 3:45 PM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Fat-bottomed girl in the passenger seat should do the trick.
    stbear likes this.
