Truck leaning..
Discussion in '1st Gen. Tacomas (1995-2004)' started by Neal4x4, Oct 4, 2023.
  1. Oct 4, 2023 at 1:33 AM
    Neal4x4
    Neal4x4 [OP] Well-Known Member
    Southern California
    Truck.
    Just noticed my first gen is leaning to the driver side about 1.25"
    I measured both sides on pretty level surface.
    I know there is some lean due to extra weight one driver side, the measurements were taken with no one in the truck and about 1/4 tank of gas.
    Is this too much lean, I know its an older truck (2001) and it has a 3.5" lift.
  2. Oct 4, 2023 at 8:47 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You've been asking all of the same questions that are commonly asked; have you done any searching at all?
    Taco lean is normal. Some leaf packs (aftermarket) account for this as well as coilover combinations. Worst case, you buy an adjustable coilover and add a little preload to the driver side.
    Also, 3.5" is way too high for an IFS truck.
  3. Oct 6, 2023 at 10:32 PM
    TimPall13
    TimPall13 Well-Known Member
    Tim
    Sandy Oregon
    3link SAS 02 SR5 Limited V6
    Lift: TrailGear 3link SAS with Fox 2.0 Coil overs in front. Custom Alcan Leafs with relocated Fox 2.0 shocks in rear. Sitting at 6in of lift. Armor: Relentless Fab Front bumper with home made hoops and Warn VR Evo 10s winch. Relentless Fab Rear bumper with swingout gate. Gears/Grip: 4.88 gears with ARB Air lockers front and rear. 35x12.5 Mickey Thimpson Baja Boss MTs on 17in Trail Ready Beadlock wheels. Lighting: 6000k 55w HID head lights in Retrofit Prejectors, KC Slim Light LEDs behind a Grillcraft grill and on CBI windshield mounts, And LED rock Lights. Performance: 6" deckplate mod, URD Crank Pulley, K&N air filter, ISR mod, and a AirRaid throttle body spacer, magnaflow muffler. Audio: Alpine speakers and sub running on a Alpine 5ch amp. All ran with Stinger wire kit, and a Alpine touch screen reciever. Extras: 15% Window Tint, Spray in bed liner, LineX coated factoey fender flares, Custom Roof rack/Track system, SoftTopper Canopy, Viair Dual 444c Onboard air with dual 2.5Gal tanks.
    Welcome to the tacoma lean club! lol 1st gens are known for it like mentioned. Mine has had a lean for the 12 years ive owned it until I went SAS with coilovers in front. I did exactly like Kwikvette said and added just a hair more on driver side. Now its not as bad.
    Does your 3.5in of lift include a body lift?
