Truck Lift Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kevinamaya08, May 3, 2020.
  1. May 3, 2020 at 2:23 PM
    Kevinamaya08
    Kevinamaya08 [OP] Well-Known Member
    Kevin Amaya
    2008 Toyota Tacoma 4.0 2020 Tacoma TRD Sport
    So my current set up:
    Front:
    - JBA High Caster UCA
    - 5100 at top notch
    - Stock coils
    Rear:
    - Icon RXT leafs at option 3
    - 5100 shocks
    I would like to gain a bit more lift on the front still leaving a bit of rake but not as much as it is currently. By doing coils on the 5100s should I get 885s or 887s? Your guys opinion is very much appreciated.
  2. May 4, 2020 at 10:57 AM
    Kevinamaya08
    Kevin Amaya
    How does pro comp coils feel in an access cab?
    Do 888 coils work on 2nd gen access cab? Any help please?
  3. May 4, 2020 at 1:38 PM
    Kevinamaya08
    Kevin Amaya
    Any help?
  4. May 4, 2020 at 1:56 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Longer coils on maxed out struts sound scary to me
  5. May 4, 2020 at 2:03 PM
    Kevinamaya08
    Kevin Amaya
    I’ve read 5100s at 0 setting you can use other coils. What id like to know is which one I can use for a access cab
  6. May 4, 2020 at 2:05 PM
    Island Cruiser
    Kauai
    Baja
    You stated “at top notch” though
  7. May 4, 2020 at 2:32 PM
    Kevinamaya08
    Kevin Amaya
    Yeah right now it’s at the top notch but it’s not enough lift. So I want to get a coil but want to know which one is the best for access cab and I will readjust
  8. May 4, 2020 at 2:55 PM
    Island Cruiser
    Kauai
    Baja
  9. May 4, 2020 at 2:59 PM
    Kevinamaya08
    Kevin Amaya
    Would double cab and access cab be the same?
  10. May 4, 2020 at 3:21 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    No. A quick Google search should net you some very different pictures of the cabs on those aforementioned trims.
  11. May 4, 2020 at 3:57 PM
    Kevinamaya08
    Kevin Amaya
    I’m asking for the coil settings for a double cab I’m thinking is not the same as for a access cab. That’s why I’d like to know if for example a pro comp coil would work with a access cab 2nd gen
    will.i.was likes this.
  12. May 4, 2020 at 4:00 PM
    VanDoom
    VanDoom Well-Known Member
    Randall
    2006 AC 4x4 Sport
    Icon 2.5s w/resi ET coils, RXT leafs and struts w/resi, TC UCAs, Hole in Wallet
    Not to derail the convo but do you have any weight in the back? Your rear must be high and stiff as hell :eek:
  13. May 4, 2020 at 4:02 PM
    Kevinamaya08
    Kevin Amaya
    I use my truck daily for work and I work in telecom usually loading up cable or radios back there. Feels nice with the load .
    VanDoom[QUOTED] likes this.
  14. May 4, 2020 at 4:03 PM
    Kevinamaya08
    Kevin Amaya
    and now that u bring that up, what I want to do is bring the front up a bit more and put a bigger tire
  15. May 4, 2020 at 4:11 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    Gotcha, the 887 are 5mm taller than the 885 based on headstrong's website: https://www.headstrongoffroad.com/store/p250/Old_Man_Emu_Lift_Coils_-__Various_Lift_Heights_Available_(PAIR).html
    Edit: was going off your original post quoting ome 885 or 887. Seems more people are happy with 887 as 885 provides too much rake.
    Btw I think the bigger issue with lift difference is the 4 cylinder vs 6 cylinder variant. V6 is much heavier so the specs provided for springs typically reflects this.
  16. May 4, 2020 at 4:28 PM
    Kevinamaya08
    Kevin Amaya
    Ok because I have a huge rake right now but then again I don’t want to be nose up when loaded in the back.
  17. May 4, 2020 at 4:30 PM
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    I just went from front 5100 at 1.75" (3rd notch) stock coils with 1.5" AAL in the rear had me sitting at basically stock rake.
    Just put 887's up front now at 0 setting (new Freedom Offroad UCAs too)and am dead level front to back.
    Ride is sooooo much better.
    Fuck Preload in its smelly cornhole.
  18. May 4, 2020 at 4:32 PM
    Kevinamaya08
    Kevin Amaya
    could you post a pic please when you can.
    I’m guessing 887 will be the way to go for me also.
  19. May 4, 2020 at 4:34 PM
    Jacked Burton
    now
    before
  20. May 4, 2020 at 4:35 PM
    Kevinamaya08
    Kevin Amaya
    It looks really good thanks man
    Jacked Burton[QUOTED] likes this.
