Truck Lift
Discussion in '4 Cylinder' started by Bristow.907, Aug 6, 2011.
  1. Aug 6, 2011 at 6:09 AM
    Bristow.907
    Bristow.907 [OP] Well-Known Member
    Onterrible
    07 AC sr5
    Pretty clueless when it comes to this stuff, I've done a lot of research but haven't found much that has helped me. I have a completely stock 07 access cab sr5 and I'm looking to get a little bit of height out of her. Thinking that 5100 route would be a good way to go. Question for you all, what exactly do I need for that kind of lift? I want the truck to be level but can make do without. If I get this 5100, do I crank it to 2.5 on the front and back or do I need to add-a-leaf in the back? How does all this work? Thanks for your help everyone.
  2. Aug 6, 2011 at 6:22 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    I have a '10 regular cab and put 5100's in the front set at .85. I'm pretty close to level but still a little low in the front. You may be perfectly level with the extra weight of the access cab. All you need is the 5100's to level it out. Down the line you always have the option of adding an add-a-leaf in the back along with some 5100's (for the back) and cranking up the fronts for more lift. I'm thinking about adding the leafs in the back now but am not sure how it'll look with my current tire setup (265/75r16's or 32"). Hope this helps.
  3. Aug 6, 2011 at 6:25 AM
    Bristow.907
    Onterrible
    07 AC sr5
    Def helps, my current tire size is like 215/75r/15 so I'd like to go atleast 235's without any issues. The 5100's are about $85 each so it might get costly if I do them all around.
  4. Aug 6, 2011 at 6:27 AM
    FLtaco
    FLtaco Well-Known Member
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Painted stock wheels, bfg km2s, 5100s front and rear, tc spindles, add a leaf, 3" block, debaged, flowmaster exhaust, 2nd air filter removed, wheel spacers and k&n air filter
    5100s are a great a popular choice. For front you'd need the 5100s to achieve the 2.5" but it'll be a little stiffer a ride then stock. You can always get coils also which I believe makes for better ride and lift as we but never been that route so don't know much on coils. As for rear you can upgrade to billies for newer better rears and set front at second setting I believe to be level or add a leaf and go to third setting(2.5") on front etc etc.... So many combos can even bro it out and leave rear low. All in your taste. I'm sure others will chime in and give you links to threads with your answers
  5. Aug 8, 2011 at 3:53 PM
    Bristow.907
    Onterrible
    07 AC sr5
    Does anyone have a pic of an access cab with just the 5100's either all around or up front with the add a leaf in the rear?
  6. Aug 9, 2011 at 5:59 PM
    DeuceRooster
    DeuceRooster Well-Known Member
    Kentucky
    2011 RC 4X4
  7. Aug 9, 2011 at 6:04 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    ^^ that lift kit right there was my first kit it did fine for me i had no problem i actually still have it if you would like to buy it off me if ya do lemme know and i can make sure i still have all the stuff to the kit but im not gonna look unless you are interested lol i think it had roughly 14000 miles on it. it did fine with my shocks i never had any problem with it
  8. Aug 9, 2011 at 6:10 PM
    DeuceRooster
    Kentucky
    2011 RC 4X4
    Still getting ideas together right now. I'll keep you in mind when I'm serious and ready to buy. Thanks for the input though, can't beat hearing from someone with first hand experience!
  9. Aug 9, 2011 at 6:11 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    yeah man if your interested and i have it all i will sell it 2 ya for $100 always willing to help out just lemme know and i will see how much the shipping would be i dont think much since your only in kentucky
  10. Nov 20, 2011 at 1:48 PM
    Bristow.907
    Onterrible
    07 AC sr5
    Bringing this thread up again, but what do you guys recommend for a leveling kit? I'm on tuff country's website but they only show 4wd and 2wd prerunners, would that leveling kit fit my 07 access cab?
  11. Nov 20, 2011 at 2:01 PM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    dude is your truck a five lugger? If so the 5100's wont work.
  12. Nov 20, 2011 at 2:02 PM
    Bristow.907
    Onterrible
    07 AC sr5
    Yeah she's a 5 lugger, I was looking into it more and you are right, they 5100's wont work, I'd just like my front end to be a bit higher, what do you suggest?
  13. Nov 20, 2011 at 3:57 PM
    david2011sr5
    take a guess
    MA/VT
    2011 SR5 4x4
    I'm no expert on 5 lug tacoma's, but unless you want to drop some serious coin your limited to spacer lifts. I've seen some guys on her with the fatbobs kits. can really say how good they are.
  14. Nov 20, 2011 at 5:48 PM
    Bristow.907
    Onterrible
    07 AC sr5
    Are those spacer kits any good?
  15. Nov 20, 2011 at 6:22 PM
    Thorpedo26
    Thorpedo26 Well-Known Member
    Brandon Thorpe
    Justin TX
    2006 silver 4 cylinder
    Blacked out badges, weathertechs, painted grill, cut tailpipe, removed mud flaps, black head lights, red calipers, tinted tails, front and rear bilsteins are here along with fatbobs spacer and aal awaiting install, also a set of 16 inch pro comps are here and 265/75/16 dynapros
    they work, id upgrade your shocks/struts though with the fatbobs kit eventually. its a stiffer ride. for the 5 lug your options are the fatbobs/ready lift spacer aal kit. Or to long travel it which is a heck of a lot more money.
