truck loses power for a second when floored.
Discussion in '1st Gen. Tacomas (1995-2004)' started by GioGuitarDude, Jun 18, 2013.
  1. Jun 18, 2013 at 9:03 AM
    GioGuitarDude
    GioGuitarDude [OP] Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    1996 3.4l v6 manual transmission x-cab tacoma.
    When I punch it and put the pedal to the floor, my truck feels like it loses and regains power several times in a rapid manner. It almost feels like I'm repeatedly flooring it and then completely letting off the gas several times but very fast. Fuel filter has just been replaced and both differentials, tranny and transfer case liquid has been recently replaced. Spark plugs are new and clutch plate and bearing was recently replaced. Does this sound like a bad fuel pump?
  2. Jun 18, 2013 at 9:05 AM
    nut
    nut she'll ride
    Patrick
    Eustis, FL
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    Welcome! Good luck with fixing this, sounds like trouble!
  3. Jun 18, 2013 at 9:07 AM
    4x4yota
    4x4yota 4wd is awesome
    Collin
    PA
    02 trd stepside v6
    Sounds like a miss fire. Did u only replace the plugs and not anything else invovling ignition?
    it could be fuel pump. Cuz a fuel pump can go bad by two ways. Either pressure or volume.
    one wont let the truck start and the other causes lose of power.
  4. Jun 18, 2013 at 9:10 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Could be a fuel pump, or it could be the air filter, when was the last time it was cleaned?
    Or (less likely IMO) it could be the coils, or wires. ( i can't remember of you have coils or a distributor)
  5. Jun 24, 2013 at 5:58 AM
    Half028
    Half028 Member
    Kenny
    El Paso
    98 Tacoma 3.4 V6. 246K and counting
    I'm pretty sure you have coils. Might want to check the ohms on each.
  6. Jun 24, 2013 at 6:04 AM
    WThomas1250
    WThomas1250 Molon Labe
    Will
    Fredericksburg, VA
    98 3.4L 5-Spd SR5 TRD 4x4
    4" Deck Plate Mod, Flowmaster 40 Muffler, Intake Silencer Delete; Ultragauge, Kenwood HU, Infiniti speakers, Sony Xplod amp; Black Grille guard, Crystal headlights, Clear corners & signals; Tons of spray paint, bed-liner, and Plasti-Dip
    Definitely sounds like a misfire. My '98 did something similar when it was in desperate need of a tune-up last year.
  7. Jun 24, 2013 at 6:07 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    I've never heard of an EGR getting clogged up or going bad on a Tacoma; but, I've had this same problem with others vehicles due to just that
  8. Jun 24, 2013 at 6:08 AM
    Half028
    Half028 Member
    Kenny
    El Paso
    What all did you replace
  9. Jun 24, 2013 at 6:18 AM
    WThomas1250
    Will
    Fredericksburg, VA
    My mechanic did it. He replaced the spark plugs, plug wires, PCV valve, and ignition cables.
    My truck was only misfing if I let it sit for a week or so. (while I was out of town) At first I thought it was a bad tank of fuel or water in the tank. It happened twice before I got the tune-up. Haven't had a problem since.
  10. Jun 24, 2013 at 6:22 AM
    Swimmerboy2112
    Swimmerboy2112 Well-Known Member
    Brian
    Walnutport, PA
    02 TRD V6 5 Speed X-Cab
    Borla exhaust, K&N intake, ARB bumper, 16x8 Konig Countersteer Offroad wheels, 20% Tint
    Sounds like you need a tune-up.
    I'd do the following;
    replace spark plugs
    inspect the wires
    replace fuel filter
    inspect and replace air filter if needed
    oil change
    clean the throttle body and mass air flow sensor
    inspect the belts and replace as needed
    check the coolant
    Also depending on the mileage now may be the time for a 4x4 service which includes;
    draining and re-filling the front and rear diff (make sure the fill plug comes out first!)
    Also if you have a 5 speed, i'd drain and fill the trans.
    Edit: Just saw that you've done most of what i'd typed. I'm gonna leave this up in case someone else was wondering.
  11. Jun 24, 2013 at 6:23 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    It might be a bad fuel...
    OP: Have you had the problem for more than one tank? Can you put a few gallons of 91 in it and see if it gets better? (Just trying to knock the cheap possibilities out before spending money on parts)
  12. Jun 24, 2013 at 1:53 PM
    nut
    nut she'll ride
    Patrick
    Eustis, FL
    Totaled
    OP? You still there?
  13. Jun 24, 2013 at 2:09 PM
    4x4yota
    Collin
    PA
    02 trd stepside v6
    Haha this reminds me of my jeep. It had problems starting in the morning. (Yet later in the day it would start. Just figured the jeep wasnt a morning person :D )
    ran 91 octane through it for a week and never had the problem again
  14. Jun 25, 2013 at 9:27 AM
    GioGuitarDude
    Gio
    Cold air intake
    Thank you guys for the help!
    I actually FIXED IT :)
    I'm not sure witch one did it, but I cleaned the sh*t out of my MAF sensor and intake system and I also added an extra ECU ground straight to the negative battery terminal. Purrs like a kitten now.
  15. Jun 25, 2013 at 10:44 AM
    GioGuitarDude
    Gio
    Cold air intake
    I actually had a bad coil a few weeks ago that was causing it to misfire even worse. Truck runs fine now since I cleaned the MAF. It has 230k miles on it so I'm not surprised that this stuff is finally starting to show some wear. Thanks though man.
  16. Jun 25, 2013 at 10:46 AM
    GioGuitarDude
    Gio
    Cold air intake
    Dirty MAF was the culprit. Thanks!
  17. Jun 25, 2013 at 10:54 AM
    GioGuitarDude
    Gio
    Cold air intake
    I replaced the ignition coils a few weeks ago along with the plugs. One of the coils was cracked. It ran much better after that but it still hesitated when I'd floor it. I added an extra ECU ground wire straight to the negative battery terminal and cleaned the crap out of my intake and MAF and it runs better than ever now. Prob solved. Thank you guys!
  18. Jun 25, 2013 at 10:56 AM
    GioGuitarDude
    Gio
    Cold air intake
    Yeah you're pretty much dead on with that :)
    It ended up being a dirty MAF.
  19. Jun 25, 2013 at 11:48 AM
    nut
    nut she'll ride
    Patrick
    Eustis, FL
    Totaled
    Glad you got it fixed!! :D
  20. Jun 25, 2013 at 1:25 PM
    4x4yota
    Collin
    PA
    02 trd stepside v6
    Congrats man. Always feels good when u diagnose and fix a problem
