Truck lost power on the freeway
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Naterx, Aug 5, 2022.
  1. Aug 5, 2022 at 6:40 PM
    Naterx
    Naterx [OP] Well-Known Member
    Nathan
    2015 TRD Sport
    Was headed out of town on a trip this weekend on the freeway and gunned it, pedal to the metal on a certain section of road, my 2006 second gen lost power steering and throttle, the check engine light came on, as well as the oil maintenance light. We thankfully coasted to a shoulder on the freeway.
    I turned the truck off, and back on again and regained power and all the warning lights turned off as if nothing had happened. Anyone have any idea what this could be? Or where to start looking?
  2. Aug 5, 2022 at 6:50 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Bad battery terminal or ground.
    Losing power steering would really only be if the engine died or the accessory belt snapped, if the belt is good you lost power somehow, I'd check/clean/adjust your terminals.
    Jimmyh and Dm93 like this.
  3. Aug 5, 2022 at 6:53 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like it stalled, as to why it stalled:notsure:
    Have you checked for codes?
    I have heard of the fuel pump relays going bad and failing to switch to high speed at times but that's just a guess.
  4. Aug 5, 2022 at 7:27 PM
    Naterx
    Nathan
    2015 TRD Sport
    I've got a code reader and its not showing anything.
  5. Aug 5, 2022 at 8:02 PM
    Naterx
    Nathan
    2015 TRD Sport
    Here's my terminals
  6. Aug 5, 2022 at 8:14 PM
    Key-Rei
    Key
    Florida
    Definitely looks like they could use a good cleaning, the negative looks seated high, do the wiggle at all or are they tight?
    What's the accessory you've added off the +Pos?
  7. Aug 5, 2022 at 9:48 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    i think that’s the factory fuse box wire.
  8. Aug 5, 2022 at 9:52 PM
    Key-Rei
    Key
    Florida
    I thought that was crimped in with the to alternator/starter wires?
    Then again it's been a good minute since I was stock.
  9. Aug 5, 2022 at 10:17 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    maybe not then? I rewired mine years ago so I don’t remember either haha.
    Ricardo13x likes this.
  10. Aug 5, 2022 at 10:40 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    My guess based on the photo: battery cable broke off the crimped connection to that weird OEM metal plate piece, someone put an eyelet connector and connected to the top nut. If it was completely stock the cable would be off the back of the metal bracket (see the red line in photo below). I don't have a good photo but mine is stock and that's how mine is.
    Or it's some kind of aftermarket accessory but by the looks of it I wouldn't think so. If you were adding aftermarket stuff the cable would probably look different than stock. This one looks stock to me.
    Edit: Sorry I forgot to include my guess as to what is going on here. I would also check the battery connections. Adding to that check the ground connection to the driver fender off the negative terminal, they can come loose. If it were mine I'd test the battery and alternator as well.
    Key-Rei[QUOTED] likes this.
  11. Aug 5, 2022 at 10:45 PM
    Naterx
    Nathan
    2015 TRD Sport
    Thank you all for the suggestions, im a new tacoma owner and not very mechanical YET. Have a lot to learn.
    Torspd and wi_taco like this.
  12. Aug 5, 2022 at 11:12 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    If you think that needs cleaning, you'd have a heart attack after seeing mine.
    Marc70 likes this.
  13. Aug 6, 2022 at 4:15 PM
    Naterx
    Nathan
    2015 TRD Sport
    So I cleaned my terminals this morning, there was some corrosion that i scrubbed off. I then took the truck to auto zone to use their scanner, and it didn't come up with any codes.
    The guy said to try to replicate what happened yesterday when it stalled and if it happens again to take it to a shop, so I took the truck down some country roads and gunned the hell out of it, and it didn't stall at all.
    So im confused, and wondering if it was something as simple as cleaning my terminals. Seems to easy but I cant get the truck to stall anymore.
  14. Aug 6, 2022 at 5:15 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    It sure happens. Back in the day when I had a summer job driving a truck the one I had flamed out just like this on a bridge 50 miles from the plant. The main mechanic drove out and worked on it for an hour and was stumped. Towed to a gas station or somesuch and the guy came out took a quick glance at it and said "it's your battery terminals". Wiggled them and it fired right up. Then cleaned them good and tightened them down, and that was it.
    Then more recently on my Corvette when I replaced the battery I took apart this terminal circuit board mounted atop it to get it out. I disconnected a couple of main feed power wires I didn't need to disconnect. Put them back when I was done and the nuts had an interference fit, like a lock nut, and I guess I didn't get one totally tightened. A year later the Vette would flame out like this once every week or 2... then start back up. I was puzzled and stumped for awhile before I got around to check the basics and found the problem. Not dirty, just a half thread loose. D'ooohhh.
    Marc70 and Key-Rei like this.
  15. Aug 6, 2022 at 5:17 PM
    Naterx
    Nathan
    2015 TRD Sport
    Wow, crazy!
  16. Aug 6, 2022 at 8:31 PM
    Waasheem
    Waasheem
    2007 xrunner
    Battery terminals is a pet peeve of mine. Believe me, I’ve seen some wonky shi*. One someone bent a penny and stuck it between the terminal and post. I recommend a new terminal, declined so I stuck the penny back in and wished them luck.
    A cheap battery brush, some spray on protector or felt pads will save you some grief.
    I could be wrong but, cleaning the terminals and posts, disconnecting the battery can clear any saved obd codes.
    Raylo, Dm93 and Key-Rei like this.
  17. Aug 6, 2022 at 8:41 PM
    Key-Rei
    Key
    Florida
    Yes it can, it usually takes a few minutes but not always.
    Clean terminals are also a big thing for me and I've seen plenty of snow cones and freaky shit, my favorite was a bare fraying wire wrapped around a terminal and then itself.
    I'm running the SDHQ billet terminals and love them, not the greatest picture but I was testing my voltage booster for the proper AGM charging and you can kinda see them here:
  18. Aug 6, 2022 at 8:45 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Don't forget the ones that pour cola all over their battery and don't rinse it off leaving a sticky mess.:annoyed:
    Baking soda mixed with water is much better at neutralizing battery acid and removing all the crud and doesn't leave a mess behind.
    Jimmyh, Marc70, Raylo and 1 other person like this.
  19. Aug 7, 2022 at 3:04 AM
    Raylo
    MD, USA
    Hey, at least a penny is better than aluminum foil.
  20. Aug 7, 2022 at 3:52 AM
    Raylo
    MD, USA
    Should have used diet coke. Less sticky. ;-)
