Truck Lunges
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Argo98, Dec 11, 2017.
  1. Dec 11, 2017 at 4:53 PM
    Argo98
    Argo98 [OP] Well-Known Member
    Argo
    2017 Toyota Tacoma TRD-Sport 4x4
    Rough Country 3" spacer lift w/ shocks 285 KO2's wrapped around 16' ProComp Series 7069 Misc. bibbidybob lights
    Title sounds stupid, but it mostly describes what my truck does... I have a 2017 DCSB Sport 4x4, in the morning when I start her up to go to work, after putting her in drive she seems to lunge forward when i come to a stop. Picture yourself stopped behind another car at a stop light and your engine RPM increases by 500, the amount of pressure you have applied to the brakes is now too little so it creeps forward a little.
    It does this primarily when she hasn't warmed up to temp on cold days/mornings, it'll do this intermittently before soemthing makes it stop... It'll raise the RPM's by 500 for about 2/3 seconds then stop, then cycle again. This only happens when I am in drive and and when its cold... Anyone wanna chip in with brainstorming a reason for this?
  2. Dec 11, 2017 at 4:58 PM
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    Something with the transmission? Like fluid level perhaps?
    Caveat: I'm not a mechanic but that would be my WAG.
    Argo98[OP] likes this.
  3. Dec 11, 2017 at 5:01 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    It doesn’t sound stupid. It just sounds like brutal leg day.
    Argo98[OP] and BlakeM like this.
  4. Dec 11, 2017 at 5:11 PM
    rooster32
    rooster32 Well-Known Member
    Utah
    2017 Magnetic Grey TRD OR DC LB
    5.29 gears 6112/5160 w/Dakar Hvy SPC UCA's 255/80/17 Wildpeak AT3 Nitro
    ....mine does the same.
  5. Dec 11, 2017 at 5:17 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Its the stupid brake system, it seems to apply a lot more "engine assisted" pressure than most other vehicles I've driven. Then when you are stopped at the first stop the system has exhausted all it's stored / reserve power, so when the rpm increases ( I don't know why the engine does that) you need a lot more actual foot pressure to keep still than you did to actually stop. After you've driven a while the system has built up a lot more reserve pressure, so the problem doesn't arrise as much. The OR has a different brake system to the Sport, I thought this problem only existed in the OR & Pro.
    Test this theory tomorrow morning by applying slightly more pressure to the brake after you come to a stop.
  6. Dec 11, 2017 at 5:31 PM
    Timbow
    Timbow Active Member
    Tim
    Hudson valley NY
    17 TRD off-road
    I have the same problem. The first two stops in the AM..you're slowing down then just about to come to a complete stop and we "lunge" forward. Pretty annoying, but hey what do you want for 35k? I'll just add that to the list of BS that seem to come with this truck. I have the OR by the way.
  7. Dec 11, 2017 at 5:32 PM
    InfernoTonka
  8. Dec 11, 2017 at 8:19 PM
    bensonxj
    bensonxj Well-Known Member
    2016 DCSB TRD Sport
    I have noticed there is a surge when turning the steering wheel at a slow speed. I have to be very careful pulling in and out of the garage because of the jumping. When you are coming to a stop are you moving the steering wheel at all?
  9. Dec 11, 2017 at 9:13 PM
    93 hilux
    93 hilux Member
    2017 trd sport
    I just picked up my 2017 trd sport a week go it started with the surging in and out of a tight parking spot ????? Also I have the clunk as well after coming to a complete stop ? Disappointed....
  10. Dec 11, 2017 at 9:14 PM
    93 hilux
    93 hilux Member
    2017 trd sport
    Should I take it back? lol problems with a new truck not good taking it into dealer Wednesday
  11. Dec 11, 2017 at 9:38 PM
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    Defrost kicking the AC compressor on/off causing surge in RPM's?
  12. Dec 11, 2017 at 10:15 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Is your cabin air set to defrost? The AC compressor will cycle on and off to assist in drying the air. When this happens there is an additional load on the engine and the computer bumps up the idle to compensate, putting more torque through the converter to the wheels. You have to press the brake harder to overcome this.
  13. Dec 11, 2017 at 10:16 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Must be "characteristic of the vehicle".
  14. Dec 11, 2017 at 10:38 PM
    93 hilux
    93 hilux Member
    2017 trd sport
    Maybe the TSB reset will help
  15. Dec 11, 2017 at 11:22 PM
    Argo98
    Argo
    I thought it was just me, my truck exhibits all these exact issues, the lunging is exasperated by turning the wheel... So now that we’ve figured this out, how do we counteract it? Trying to prove to your insurance that it wasn’t your incompetence as a driver the factor for the accident is gonna be pretty hard to do.... Top off fluids? Call the preist? Go to dealer? Provide offerings? Maybe if we think of something we can prevent fender benders/damaged bumpers/injured pedestrians (yes she has lunged forward at someone as they were crossing in front of me)
  16. Dec 12, 2017 at 4:23 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I’ve done everything suggested and my truck still does this lunging thing and after a year I’ve just learned to live with it as a manageable characteristic of the vehicle - I just know to stay alert those first few minutes when coming to stops, etc., mine also tends to do this when pulling into my garage so I’m always being super careful it doesn’t lunge into my hot water heater!
    MoneyMan55 likes this.
  17. Dec 12, 2017 at 4:44 AM
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    Same with my SR5. Always seems to happen when backing in my carport when my mirror is close to the wall. Makes me curse some days.
  18. Dec 12, 2017 at 6:34 AM
    walterj
    walterj Well-Known Member
    PA, USA
    Sexy Black '17 Taco 4x4 DCSB TRD Off-Road 6MT
    There is also a richer mixture and higher idle due to it just being cold. The trans fluid is also cold and does not flow as easily as when it's warm so it turns higher idle to motion. The steering booster also causes extra load on the engine via the alternator or hydraulic pump so yanking the wheel while the truck isn't moving causes sudden RPM swings the ECU tries to compensate for. The shocks will feel stiffer until they warm up too and not be there to pick up gentle weight transfer making everything feel more abrupt. Differentials and transfer cases will have a little more stiction. The rubber compound of the tires too - if you leave it outside in 0F temps they can feel like flat spotted rocks for a few miles.
    I think softly suspended tall vehicles exaggerate the feeling because any jerking translates to dive/roll you wouldn't sense as much in a lower sedan without all the suspension travel pogoing about.
    You can blame Toyota if you want but, really, it's just cold.
    2016Tacoman likes this.
  19. Dec 12, 2017 at 6:47 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    My Toyota car has done the same for years since new.
  20. Dec 12, 2017 at 6:51 AM
    InChrist
    InChrist Sinner
    Bob
    Kennywood's Backyard
    2017 Tacoma SR5 SBDC
    Bone stock
    Why it happens I don't know, I have sr5 same thing, I just put it in neutral at a light, I go in for 5000 mile service Friday, we'll see if the yo-yo's say or do anything about it. I don't expect much, but this will be my first dealings with taco service poeple. If any Pittsburgh guys know a good service place they trust and have had good experiences with please let me know.
