Truck lunging forward
Discussion in '2nd Gen. Tacomas (2005-2015)' started by capibara68, Nov 2, 2022.
  1. Nov 2, 2022 at 8:19 AM
    capibara68
    capibara68 [OP] New Member
    2006 blue tacoma
    3" lift.
    Hey guys, whenever I stop and sit for a bit with my foot on the brake, the truck sometimes jumps forward as though someone rear ended me. I've gotten so much crazy advise. I've had the driveshaft balanced, transmission changed, brakes done, driveshaft completely rebuilt and balanced again, and it still does it. I'm so frustrated with this problem and can't afford to keep spending money like this. please help....
    Also, exactly how many catalytic converters are there in a 2006 tacoma pre runner?
    ZMan2k2 likes this.
  2. Nov 2, 2022 at 11:28 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Stop spending. You’re gonna hate the answer.
    The lunge is when the A/C compressor clutch kicks in and the engine revs to about 750rpm. Push the A/C button on the HVAC controls to shut off the light…no more lunge.
    And, there is 4 cats on the V6 and 2 on the I4.
    Oh, and welcome to TW. :hattip:
    winkel, zul, muddog321 and 2 others like this.
  3. Nov 2, 2022 at 11:51 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Also, if you have defrost on, the AC runs.
    And the light won’t be in. So it will do it in defrost too.
    FWIW, mine does it too.
    Always has, it’s normal.
    winkel, ZMan2k2 and GarlicFarts like this.
  4. Nov 2, 2022 at 11:51 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    You need to fire your mechanic for doing all the work to try and fix that problem. All the items you mentioned that were fixed would never cause a truck to lunge forward.
    Mine does the lunge too. All v6 Tacomas do it. Just remember to keep a bit extra pressure on the brake pedal at stop lights.
    usmc2msu and drizzoh like this.
  5. Nov 2, 2022 at 11:52 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Turd gen owner chiming in, yeah same here.
    TnShooter likes this.
  6. Nov 2, 2022 at 12:18 PM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    All V6 Tacomas do not do this. The only way mine would do this is if I was double footing it. Using one foot for braking and the other for the accelerator.
  7. Nov 2, 2022 at 12:22 PM
    fourfourone
    My 15 and 18 do it...
  8. Nov 2, 2022 at 12:47 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    The slip yoke on the drive shaft binds from axle roll an then when it slips it feels like this truck lunges, there are a million threads about this issue. Grease it if you have a zerk , if not pop it off and drill it out for a grease zerk or just re grease it often.
  9. Nov 2, 2022 at 1:24 PM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Yikes, a quick search on this forum BEFORE doing all that crap would have been much easier and cheaper...
    wilcam47, zul and jackn7 like this.
  10. Nov 2, 2022 at 3:03 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Maybe I'm confused here. Is he saying when he's stopped at a red light when he lets off the brake his truck surges or lunges forward? If so, I just drove home just now and tried this. My truck, an 08, didn't do anything like that. Maybe I need a tune up. Lol!
    But I do grease every zirk I can find and have occasionally greased the drive shaft. Maybe that makes a difference?
  11. Nov 2, 2022 at 3:12 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Mine has never done it. Unless my foot slipped off the clutch in gear.
    Score another one for the 6 speed!
    XSplicer62 likes this.
  12. Nov 2, 2022 at 3:57 PM
    TnShooter
    Deogee
    STOCK
    No, he said - Stoped, foot on brake.
    There’s been multiplayer posted on this subject.
    And many with nearly the same description - “stopped, lunges, feel like rear ended”.
    winkel and Bivouac like this.
  13. Nov 2, 2022 at 4:09 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    This is a new problem, and nothing I've ever experienced in my V6 Taco. Not understanding how the truck lunges while the brake is depressed...can someone explain?
    My condolences OP if the AC is the issue when you spent all that money trying to find the fix :(
    jackn7 likes this.
  14. Nov 2, 2022 at 4:12 PM
    TnShooter
    Deogee
    STOCK
    It should not lunge if the brake pedal is pushed hard enough.
    The thing is, most people push the pedal just hard enough to keep the truck stopped.
    I am/was guilty of this myself.
    winkel likes this.
  15. Nov 2, 2022 at 4:23 PM
    TacoTyusday
    Zac
    San Diego
    Ahhh got it. Maybe i've been doing a good enough job of keeping it depressed all this time lol
    jackn7 and TnShooter[QUOTED] like this.
  16. Nov 2, 2022 at 5:00 PM
    HeyB
    HeyB Well-Known Member
    2022 TRD OR DCLB
    Does it happen more frequently or violently when you brake hard to a stop vs a more gentle deceleration?
    And are you experiencing the truck actually lurching forward several inches after reaching a complete stop with your foot firmly on the brake (vs more of a shudder with no actual forward movement, which is how I’ve experienced the AC compressor kicking)?
    If so, might want to look up “Axel Wrap”. I’m no mechanic, but roughly speaking it’s driveline angle related but caused by rear suspension. I had a ‘11 develop those symptoms (intermittently, but often quite violently in the event of a very hard stop) and replacing some seriously abused rear leafs took care of it.
  17. Nov 2, 2022 at 6:02 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Any chance that might have something to do with the torque converter?
    Edit: Yeah, I know, grasping at straws, but still...
  18. Nov 2, 2022 at 6:22 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Completely normal. Usual cause is the idle, to meet mpg regulations, is low and when the AC compressor kicks in, the idle jumps so it doesn't stall and thus the surge. Sometimes it's more noticeable than other times.
  19. Nov 2, 2022 at 7:39 PM
    TnShooter
    Deogee
    STOCK
    No, highly unlikely.
  20. Nov 2, 2022 at 8:50 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    We bought our trucklet new in 2005. It has always had the 'lunge when stopped', though it doesn't do it every time. I never bothered to track it down but I suspect it's the compressor engaging, just like several of you have posted. I hardly notice it anymore, but it sure was disconcerting at first. For the record, I hit all the driveshaft zerks at every 5K oil change.... and I'm quite sure that has nothing to do with the 'lunge'.
    jackn7 likes this.
