Truck makes a clunk sound when downshifting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by new_tac_man, Apr 25, 2025.
  1. Apr 25, 2025 at 5:38 PM
    new_tac_man
    new_tac_man [OP] Member
    Phoenix
    2023 TRD OR AT
    Hey all,
    Lately, I’ve been experiencing an issue with my Tacoma. When I’m cruising 35-45 mph and I’m about to slow down at a stop sign or whatever, I’ll hear this weird click, jerk or clunk from under the vehicle, and I notice the RPM goes a bit higher right at the time I hear the sound. If I had to guess, it’s when the truck shifts from 4th to 3rd gear around 15-20 mph. It’s not horrible or loud, but it’s definitely something I notice and feel. I just want to have the peace of mind that it’s normal.
    This Reddit post also talks about the same issue I’m having. https://www.reddit.com/r/Tacomaworld/s/gNfmsffxtT
    Should I take it to the dealer?
    anyone has this issue? Any thoughts?
  2. Apr 25, 2025 at 7:11 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Stock truck? Mods? DCLB? DCSB?
  3. Apr 25, 2025 at 7:44 PM
    new_tac_man
    Phoenix
    2023 TRD OR AT
    Lite/mild OTT tune. Stock suspension, no other mods. short bed. Sorry for leaving that out.
  4. Apr 26, 2025 at 4:56 AM
    TBLTravy
    TBLTravy Well-Known Member
    2019 SR5 4X4 Sement , 2016 DCSB *sold*
    Did the truck do it prior to OTT?
  5. Apr 26, 2025 at 8:08 AM
    new_tac_man
    Phoenix
    2023 TRD OR AT
    No it didn’t. Or at least not that I remember.
  6. Apr 26, 2025 at 8:09 AM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Check u joints, and make sure spare tire isn't loose.
  7. Apr 27, 2025 at 1:36 PM
    new_tac_man
    Phoenix
    2023 TRD OR AT
    Sorry to sound dumb, but is the drive shaft supposed to move/rotate while truck is in park and e brake pulled? I crawled under and there is a bit of a play with a clunk in the drive shaft. As far as I know it shouldn’t rotate at all unless tires are off the ground and in neutral, is that accurate?
  8. Apr 27, 2025 at 1:42 PM
    yotadust
    yotadust Well-Known Member
    all normal it sounds to me. My 23 has always behaved like that. Trans in these trucks are a clunky jerky mess during speed changes/rpm changes at lower speeds. Good thing they are overbuilt.
  9. Apr 27, 2025 at 3:59 PM
    new_tac_man
    Phoenix
    2023 TRD OR AT
    That makes me feel better. But would but drive shaft have any movement when the truck is in park and e-brake pulled?
  10. Apr 27, 2025 at 4:18 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I take it you drive an automatic...
  11. Apr 27, 2025 at 4:19 PM
    new_tac_man
    Phoenix
    2023 TRD OR AT
    Yes, automatic.
  12. Apr 27, 2025 at 4:31 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The truck is just downshifting as you slow. That's why rpm's go up. Perfectly normal.
  13. Apr 27, 2025 at 5:07 PM
    yotadust
    put a vid on youtube of the movement so we can look at it.
