Truck makes weird noise please help thankyou.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Sep 10, 2013.
  1. Sep 11, 2013 at 12:10 AM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Might be wheel bearings too... If it increases with speed then its a rotational part ETC wheel, Driveshaft, Pulleys...
    I think its either wheel bearings, U joints or a belt.
    To check wheel bearings, Place lead foot on bottom of tire preventing it from shaking the whole assembly and push and pull the wheel from the very top. If there is play its a wheel bearing, Try all four tires.
    To check U-Joints, Get under your vehicle and shake your driveshaft if there is play in any direction of movement besides rotational then its a u-joint. Check Carrier Bearing as well.
    To check for a belt simply give it a once over and look for any dry areas or cracked ribs, Usually cracks in a belt means its time to be replaced.
  2. Sep 11, 2013 at 11:49 AM
    Nfurtado77
    Nfurtado77 Well-Known Member
    Yea it isn't a belt if your speed effects it. Is it just a squeak or more of a creaking noise.
  3. Sep 11, 2013 at 7:33 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    ok let me rephrase it sorry more detail it a metal scraping sound it pretty dam loud.
  4. Sep 11, 2013 at 7:37 PM
    pinktaco808
  5. Sep 11, 2013 at 7:48 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    That video kind of sounds like rubber squeaking... Is that your truck in the vid?
  6. Sep 11, 2013 at 7:51 PM
    pinktaco808
    no it not but make a similar sound, but sounds very like metal. If i put my trucks on jack and put in reverse can i hear the bad unjoints if it that? should i change both front and back if it that?
  7. Sep 11, 2013 at 7:53 PM
    pinktaco808
    how i check if it the carrier bearing?
    also could it be the rear drum shoes?? like the rear right shoe could be stuck?
  8. Sep 11, 2013 at 7:56 PM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    It wouldn't be a bad idea to change them out, but I don't think that's the noise. I might be wrong, but could it be brake shoes? Don't drum brakes self adjust in reverse? Does it squeak at all when you push the brakes? Forward or reverse?
  9. Sep 11, 2013 at 8:01 PM
    4lo
    4lo Well-Known Member
    El Campo, TX
    2017 TRD Sport
    some stuff
    Check the pads. Wife's Camry was doing the same thing this summer and only in reverse....
  10. Sep 11, 2013 at 8:01 PM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Make a video man.
    Mine is starting to make a similar noise in reverse.
  11. Sep 11, 2013 at 8:02 PM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    If it sounds just like that video, it's u-joints. That's exactly what they sound like when the needle bearings inside have turned to dust
  12. Sep 11, 2013 at 8:03 PM
    4lo
    El Campo, TX
    2017 TRD Sport
    some stuff
    ^^Skidooman got to it first...
  13. Sep 11, 2013 at 8:19 PM
    Slvr2ndGen
    Slvr2ndGen Well-Known Member
    05 PreRunner DCSB, 2010 PreRunner DCSB
    Do your u joints asap. Mine started making the exact same sound this weekend and im taking the drive shaft in tomorrow. Its the rear u joint and mine will barely move in one direction so it would only be a matter of time before it breaks and then your really in trouble.
  14. Sep 11, 2013 at 8:21 PM
    pinktaco808
    that the thing though the my driveshaft has no play trie moving and twisting nothing. 2x4 truck
    loud noise
  15. Sep 11, 2013 at 8:24 PM
    #35
    Slvr2ndGen
    Mine barely had any play in it but once i unbolted the carrier bearing and moved it around, the rear u joint would make the squeak sound.
  16. Sep 11, 2013 at 9:21 PM
    #36
    pinktaco808
    What parts do i need to change out the u joint?Also my driveshaft has no play can it still be the problem . Just looked and the sound coming from either the front or rear u joint.
    Is it ok driving around with this problem? Wont be able to fix it for 2 weeks.
  17. Sep 11, 2013 at 10:08 PM
    #37
    ToyComa92
    Jon
    Conifer, Colorado
    It could a be a seized U-joint thats only getting movement in reverse, In drive its pretty much seized dried and fried but in reverse you might be free-ing it up a little which is causing the sound.
  18. Sep 11, 2013 at 10:19 PM
    #38
    pinktaco808
    how will i know if it the front or rear one? The sound is hard to tell, but it is coming from the driveshaft. How would that cause at what you said cause the drivshaft is spinning the other way?
  19. Sep 11, 2013 at 10:22 PM
    #39
    ToyComa92
    Jon
    Conifer, Colorado
    I would replace both, When in reverse your driveshaft is going counter clockwise if i can remember right from auto shop, You drive in reverse ALOT less frequently then you do in drive so the bearings inside the joint are smashed from driving, But switching rotation might be knocking something lose and causing the sound.
    Your u-joints probably are dust, When you take the caps off you'll have rust and needle bearings fall out indicating a for sure seized u-joint.
    Replace both with greasable zerk u-joints and youll be covered either way. Even if its not the sound id do it if it hasnt been done in your ownership.
  20. Sep 11, 2013 at 10:33 PM
    #40
    pinktaco808
    Yes I will man. Are the universal with the Zerk fitting ok to put in? They are the same size
