Truck Noob Questions on LT
Discussion in 'Long Travel Suspension' started by Fen, Mar 11, 2012.
  1. Mar 12, 2012 at 3:57 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    not really independent arms... its a triangulated shock displacement type thing a majig... hahaha... i am so not a technical person...
    i have an outboard cantilever system on my truck now with a Tundra rear axle... it allows me to keep my bed...
    i just need to photograph my rear...
  2. Mar 12, 2012 at 3:58 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    that's right... forgot about Rialto...
  3. Mar 12, 2012 at 6:52 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Just google cantilever suspension and you will get tons of different versions. Lots of bagged/slammed trucks use it too. You can typically get more travel out of less space.
  4. Mar 15, 2012 at 2:24 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Raptors only pull 11" right? You should be able to do a solid mid travel all around and be good! Obviously gusset some shit but LT is top notch if you've got the funds!
  5. Mar 15, 2012 at 5:46 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    All pro LT will require glass up front if you run a 32" or larger and tire and actually use the travel.
  6. Mar 15, 2012 at 6:52 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    and well tuned internal bypass shocks on all 4 corners... something a mid travel set up isn't going to have
    travel numbers only mean so much dude...
  7. Mar 15, 2012 at 8:18 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    well you are in the right area on your budget of 10-15k, that will be more than enough if you just do a simple bed saver cage in the rear with the normal LT out back and just a normal kit up front.
  8. Mar 15, 2012 at 9:20 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    True....so the internal bypass is the way to go! What's the likelyhood of fox or anyone developing an off the shelf one?
  9. Mar 15, 2012 at 9:38 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Encinitas/San Diego
    I know of a Tacoma that has them :anonymous:
  10. Mar 15, 2012 at 10:21 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    With internal bypass'?
    Pic's or it didn't happen!
  11. Mar 15, 2012 at 10:26 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    :rolleyes:
    :p
  12. Mar 15, 2012 at 11:04 AM
    Supermoto
    Landon
    Encinitas/San Diego
    From a armored Hilux:spy:
