Truck not starting up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wixo, Nov 18, 2019.
  1. Nov 18, 2019 at 4:52 PM
    Wixo
    Wixo [OP] Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    So for a few months Ive had random non start ups. I hear a single click right below me, but the truck doesn't start. It doesnt crank either. At first it seemed like the button itself wasnt working, but 1. the truck turns on (not the engine tho) 2. this last time I heard a click from some component under me when I pressed the button. By under me I mean under the front half of the cab. Usually the truck starts up after a few tries. I have the toyota platinum so I dont doubt it will be covered, but Im wondering what it is? Have any of you guys experienced this? Any guesses on what it is? My rear facing LED bar started acting up and then completely went out, but its switch still turns on. Could they be related?
  2. Nov 18, 2019 at 4:55 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    What’s the security light doing when you turn the ignition on?
    Wixo[OP] likes this.
  3. Nov 18, 2019 at 5:00 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Are you getting any messages on the center display? I wonder if it is not seeing the brake being applied. :confused:
  4. Nov 18, 2019 at 5:10 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Sounds like rodents are chewing your harnesses. Ignition harness partially chewed, and reverse led bar totally chewed.
    Wixo[QUOTED][OP] and ANTupLIFE like this.
  5. Nov 18, 2019 at 5:21 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Or..... battery issues .
    BSFord, Big tall dave and Wixo[OP] like this.
  6. Nov 18, 2019 at 5:25 PM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    check battery
    my truck was acting strange before the battery died.
    BSFord and Wixo[OP] like this.
  7. Nov 18, 2019 at 5:26 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Sounds like corrosion to me. Check battery and cables for corrosion, check the ground going to the fender on the driver's side.
  8. Nov 18, 2019 at 5:27 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Don't they require you have your foot on the brake to start? If the brake switch is acting up, it might be causing an issue.
    Big tall dave, Wixo[OP] and daddy_o like this.
  9. Nov 18, 2019 at 5:27 PM
    mbigpops
    mbigpops Well-Known Member
    2017 TRD Sport
    Could be a bad ground connection somewhere or a relay. Anyone know if the starter button and light bar are on the same circuit ?
    Mark
  10. Nov 18, 2019 at 5:32 PM
    Wixo
    Hank
    Tint, LED interior
    I needa check.
  11. Nov 18, 2019 at 5:32 PM
    Wixo
    Hank
    Tint, LED interior
    Nope, and yes lol
  12. Nov 18, 2019 at 5:34 PM
    Wixo
    Hank
    Tint, LED interior
    Maybe so, I have lately seen many rats around my house
    Stocklocker[QUOTED] likes this.
  13. Nov 18, 2019 at 5:34 PM
    Wixo
    Hank
    Tint, LED interior
    I put in a new northstar in the summer so I doubt it.
  14. Nov 18, 2019 at 5:35 PM
    Wixo
    Hank
    Tint, LED interior
    I replaced the factory with a northstar when it went out in the summer. I also changed the connections then.
    bulalo likes this.
  15. Nov 18, 2019 at 5:36 PM
    Wixo
    Hank
    Tint, LED interior
    Might be it. I aitn checking squat tho, thats what I got the toyota platinum for lol
    0xDEADBEEF[QUOTED] likes this.
  16. Nov 18, 2019 at 5:36 PM
    Stocklocker
    17TRDORDCSBAT
    I worry for you. Have a good look under there. If you see chew marks, or nesting material, get the truck to the dealer before it dies for good.
    Wixo[QUOTED][OP] likes this.
  17. Nov 18, 2019 at 5:36 PM
    Wixo
    Hank
    Tint, LED interior
    Yeah Im taking it over tomorrow.
  18. Nov 18, 2019 at 5:37 PM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Try to the tighten the connectors including the ground.
    Big tall dave, Wixo[OP] and Skydvrr like this.
  19. Nov 18, 2019 at 5:37 PM
    daddy_o
    Bossier City, La
    And on the way home stop by the shelter and adopt a cat.
  20. Nov 18, 2019 at 5:38 PM
    0xDEADBEEF
    And then stop by a church and get a drive-thru exorcism, just to be sure. Make sure its a Catholic one though, all the others are watered down.
