Truck not starting up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wixo, Nov 18, 2019.
  1. Nov 18, 2019 at 5:38 PM
    Deathdealer
    Deathdealer Well-Known Member
    Ricky Spanish
    Texas
  2. Nov 18, 2019 at 5:40 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    There has got to be a huge starter relay. No way all those start amps are going thru the cab push button.
    I'd check the connections on that 1st.
    Wixo[OP] likes this.
  3. Nov 18, 2019 at 5:42 PM
    Wixo
    Wixo [OP] Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Ive been considering that
    daddy_o[QUOTED] likes this.
  4. Dec 20, 2019 at 12:46 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    So what was it? I have a similar issue.
  5. Dec 20, 2019 at 12:51 PM
    double_duez
    double_duez Well-Known Member
    San Diego
    2017 TRD OR DCSB
    OVTune
    There is a brake light fuse in the interior fuse box (under the steer wheel) check that.
    I had this same problem when I wired my taillights backwards and blew the fuse.
    First time turning the turn the truck on, I heard a click from underneath me and then the truck would never crank over.
    Replaced the fuse and it works fine. These trucks have a check to make sure the brake like circuit is working before they fire up.
    *EDIT: I said this because it seems possible with you also have light bar issues. not sure how you have everything wired but worth a quick check
  6. Dec 20, 2019 at 1:14 PM
    Radarninja
    Northern California
    06 taco
    Thanks. My problem is intermittent so it’s been a bitch to find. Maybe brake light switch?
  7. Dec 20, 2019 at 3:50 PM
    Wixo
    Hank
    Tint, LED interior
    IDK it worked fine shortly after...
  8. Dec 20, 2019 at 3:51 PM
    Wixo
    Hank
    Tint, LED interior
    My rear LED bar which stopped working a week or so before the ignition started messing up now works well and the ignition doesn't really fail anymore
