truck not starting when i push clutch in?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bombers_2007, Dec 16, 2009.
  1. Dec 16, 2009 at 10:16 AM
    bombers_2007
    bombers_2007 [OP] Member
    Anthony
    Panama City
    99 Tacoma
    I have a 99 tacoma extended 5sp V6
    I have the push button start by the steering wheel and it starts like thAT!
    But when i push the clutch in and try to start it, i get nothing!! Any ideas??? Thanks
  2. Dec 16, 2009 at 10:21 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Check the switch under the dash above the clutch pedal assembly. It may need adjusted.
  3. Dec 16, 2009 at 12:08 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    ^ this.
    Or if you have a thick floor mat or two you can't put the pedal all the way down.
  4. Dec 16, 2009 at 12:56 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    x3 yeah thats what it is, the switch by the clutch pedal
  5. Dec 16, 2009 at 4:05 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Seems pretty obvious you wired in the new push button ignition switch in such a way that it conflicts with the OEM clutch start switch circuit.
  6. Dec 16, 2009 at 4:13 PM
    Afwrestler1986
    Johnstown, NY
    Wait, Wha?
    I think he is talking about the clutch start cancel button working, but nit the clutch pressure switch.
  7. Dec 16, 2009 at 4:23 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    thats what I thought he was talking about
  8. Dec 16, 2009 at 8:28 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Mines doing the same thing, only I don't have the clutch cancel button. I found the switch, just haven't adjusted it. It should take about 2 minutes.
  9. Dec 17, 2009 at 7:13 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    OK - I see ... There's been a wave of folks installing push-button start switches on their Tacos lately, and I misinterpreted the OP to mean he was referring to a newly-installed push switch, not the clutch start cancel button.
  10. Dec 17, 2009 at 8:47 AM
    Afwrestler1986
    Johnstown, NY
    Yeah, I know that you know what you are talking about. Wasn't a bash. :D You came from CT right?
  11. Dec 17, 2009 at 10:08 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    I would check floor mats, then actually take a closer look at the switch. I had a minor version of this and it was just because the floor mat had pushed forward and was under where the clutch pedal almost hits the floor. Didn't bother the shifting, just the starting of the truck.
    It's one of those things that's so obvious that it can be missed...
