Truck not starting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cpk8979, May 12, 2020.
  1. May 12, 2020 at 1:35 PM
    Cpk8979
    Cpk8979 [OP] New Member
    2012 Tacoma TRD Off Road
    Hey everyone,
    I have a 2012 Tacoma, 4.0L, TRD Off Road, Manual transmission.
    About two months ago I went to start my truck and it made a high pitch drill noise. It sounds like the gear on the starter was spinning but not engaging the flywheel. After talking with my friend he told me it was most likely the starter so I got a new one put in it. I also got a brand new battery since mine was pretty old. Still having the same problem but it’s getting worse and happening more often. We’re 99% sure it’s the flywheel but I wanted to know if anyone else has had this issue and if it could be something else. Thanks guys!
    BassAckwards likes this.
  2. May 12, 2020 at 1:40 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Sounds like the ring gear on the flywheel is toast:(
    Jimmyh likes this.
  3. May 12, 2020 at 1:41 PM
    BassAckwards
    Id try unbolting the starter moving it over a little and see if you can inspect the ring gear thru the hole where the starter sits
    Jimmyh likes this.
  4. May 12, 2020 at 1:41 PM
    BassAckwards
    Make sure to disconnect the battery before doing this
  5. May 12, 2020 at 2:39 PM
    Cpk8979
    We tried to look At the ring gear when we put in the new starter. My roommate is a mechanic and he was helping me. Just wanted to see if there was any other ideas out there. Thanks guys!
  6. May 12, 2020 at 3:26 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Well did you see the gear or not ?
  7. May 12, 2020 at 4:47 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Someone else had this same issue not to long ago and the flywheel was chewed up.
  8. May 12, 2020 at 5:32 PM
    avnut48
    avnut48 Member
    NE USA
    2012 DCLB Base Auto
