Truck not starting
Discussion in 'Technical Chat' started by Nstacomaguy, Feb 16, 2022.
  1. Feb 16, 2022 at 11:04 AM
    Nstacomaguy
    Nstacomaguy [OP] New Member
    2006 v6 tacoma dbl cab
    Hello!
    I have a 2006 tacoma v6, I've had a reoccurring issue where my truck won't start..
    The dash lights up but it doesn't turn whatsoever. There has been a few times i went back out in 10-20 mins and it started up no problem sounding normal. I think it may be a fuse or someone said neutral switch? I'm not too educated in mechanics but I am an apprentice electrician and if I can fix it at home without having to pay for a tow to the mechanic that would be great! If anyone has experienced the same problem or has some advice it would be greatly appreciated!!
    *note: I live in Canada and it is currently winter conditions below zero*
  2. Feb 16, 2022 at 5:22 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Do you have a manual or automatic transmission?
  3. Feb 17, 2022 at 11:10 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    First check the battery charge, make sure it’s carrying a sufficient charge. Then check the battery cables.make sure they are tight on the terminals. Check the connections , especially the grounds. Make sure they are tight and not rusted. Check the connections on the starter for the same. These are the things I start with and go from there if they are all good.
