Truck out of storage?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JARStacoma, Feb 11, 2019.
  1. Feb 11, 2019 at 2:28 PM
    JARStacoma
    JARStacoma [OP] Well-Known Member
    Alaska
    17' inferno TRD OR MT
    I will be returning home to Alaska in a few weeks. My truck has been in cold storage for 4 months. When I left I it fresh oil in and disconnected the battery. Is there anything I should do before I hook it up and crank it over? I have been doing this with my 02 4runner for years and all had been ok, however now with a new truck with only 6,000 miles I really want to take all precautions and. M not sure this will cause any internal damage.
  2. Feb 11, 2019 at 2:32 PM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    Should be fine.
  3. Feb 11, 2019 at 2:35 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    The battery will probably need a boost if it was left out in the cold with the truck.
  4. Feb 11, 2019 at 2:41 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Id check the oil, and go thru the fluids and make sure everything is where it should be. Other than that, crank her up let it get to operating temp, and put the old italian tune up in her
    TD90S and kahanabob like this.
  5. Feb 11, 2019 at 2:41 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    hopefully you put fuel stabilizer in it before you stored it. if not 4 months should be OK but that is stretching it.
  6. Feb 11, 2019 at 2:43 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    @Taco16LB can't quote or like your post?
  7. Feb 11, 2019 at 2:45 PM
    Taco16LB
    Taco16LB Well-Known Member
    Misread the post , too late to add stabil after wards , oops !
    kahanabob[QUOTED] likes this.
  8. Feb 11, 2019 at 3:03 PM
    HacksawMark
    Mark
    OREGON
    If I was leaving mine in storage, I would (if possible) leave the battery in, hooked up to a battery tender. When I take it out, start it up, let it idle for a minute or two and start driving. My neighbors are snowbirds from AZ and they do this for six months at a time with their Honda mini-van and they've had no issues.
  9. Feb 11, 2019 at 3:03 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I have cars I park for 9 months out of the year, a 1973 dodge challenger, and a 1991 BMW convertible. Neither one do I use stabil in, neither one has trouble starting in the spring. Been doing it for the past 15 years and never had a issue.
    Both are stored in a garage in MN, lowest it gets in the garage is about 20 degrees.
    I check oil, if its good I back it out and then look at what fluids I leaked onto the cardboard under it. Then top up the fluids I find.
  10. Feb 11, 2019 at 3:55 PM
    JARStacoma
    Alaska
    ThNks everyone. I do the same to my other vehicles. Put stabilizer in all including lawnmower. Just wanted to check about the newer engine sitting without oil lubricating internals for extended periods and then just turning over. Thanks for the feedback.
    shakerhood and HacksawMark like this.
  11. Feb 11, 2019 at 5:26 PM
    JARStacoma
    Alaska
    Copy the Italian tune up;)
    BassAckwards[QUOTED] likes this.
