Truck pulling to left after lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bryan0386b, May 19, 2021.
  1. May 19, 2021 at 11:44 AM
    Bryan0386b
    Bryan0386b [OP] Active Member
    Bryan
    2017 Toyota Tacoma SR5 double cab
    3in front and 2in rear lift
    Just installed a 3in front and 2in rear leveling kit on my Tacoma and had it aligned twice by Firestone and still pulls to the right also when braking at low speed it does a little shiver before coming to a complete stop.
  2. May 19, 2021 at 11:49 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    you need upper control arms.
    71tattooguy likes this.
  3. May 19, 2021 at 11:51 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Gonna need ucas as mentioned above. The caster number is horrible!!!!
  4. May 19, 2021 at 11:51 AM
    Bryan0386b
    Bryan
    Can you elaborate on that?
  5. May 19, 2021 at 11:52 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Even with stock arms you should be able to get at least 2.5 degrees of caster, dem techs just lazy as shit.
    boston23 and essjay like this.
  6. May 19, 2021 at 11:53 AM
    fourfourone
    all they did was a toe and go.
    After you lift your truck a certain amount in the front you need aftermarket upper control arms to get the caster in spec.
    boston23 likes this.
  7. May 19, 2021 at 11:54 AM
    fourfourone
    You really think he can get 2.5 out of stock with a 3 inch lift?
  8. May 19, 2021 at 11:54 AM
    coopcooper
    alberta canada
    yes. ive done it dozens of times.
  9. May 19, 2021 at 11:55 AM
    Bryan0386b
    Bryan
    What are the negative effects if I leave the caster as is?
  10. May 19, 2021 at 11:55 AM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    This. I recently had an alignment shop tell me that you couldn't "adjust caster on these trucks without aftermarket parts" and then tried to sell me on SPCs. Went to another shop with a competent alignment tech, got it taken care of, and got a refund from the first shop.
  11. May 19, 2021 at 11:56 AM
    gotoman1969
    They probably won’t be able to. But normally you can get into the green but on the lower end of spec. With the lift and larger tires you’ll want it at the higher end and even 3 or 3.5 is great. I personally run 4* caster. But you’ll need aftermarket ucas to obtain those numbers.
  12. May 19, 2021 at 11:57 AM
    fourfourone
    Don't leave it like that. If you run into a road with a ton of road crown, your truck will track all over the place. Shame on them for even calling that an alignment. I would want my money back.
    07sct and 71tattooguy like this.
  13. May 19, 2021 at 11:57 AM
    gotoman1969
    it will drive crappy, wander on the road etc
  14. May 19, 2021 at 11:57 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Alignment looks horrible. UCA’s will help :thumbsup: 0 camber 3 - 4 caster 0 toe that’s what uppers will get you
  15. May 19, 2021 at 11:58 AM
    TRD__Chris
    TRD__Chris Well-Known Member
    STL
    2016 Sport
    Excessive wear and tear on your tires + suspension.
    You need UCA’s and maybe try a different shop for your next alignment.
  16. May 19, 2021 at 11:59 AM
    fourfourone
    At least bring it somewhere to get the caster in spec. My truck is at 1.6 caster on each side and it tracks perfectly. No wander, no pull.
  17. May 19, 2021 at 11:59 AM
    gotoman1969
    From the looks of it, they didn’t even try to set caster. Adjusted toe and sent ya down the road. Idiots!!!
  18. May 19, 2021 at 12:00 PM
    Bryan0386b
    Bryan
    Yup that’s Firestone for you! Already called to get a refund and filing claim with my bank
  19. May 19, 2021 at 12:01 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    I agree seems unlikely
  20. May 19, 2021 at 12:01 PM
    fourfourone
    how much did they charge you for that alignment?
