Truck pulling to left after lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bryan0386b, May 19, 2021.
  1. May 19, 2021 at 12:01 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    I'll take a stab at this:
    A bit of caster helps your front wheels return to moving in a straight line when you let go of the steering wheel. Without it, they can tend to wander requiring you to maintain total control via the steering wheel. Any road imperfection can cause the truck to pull to one side or the other. Pulling to the right is common because most pavements are crowned a bit to shed water off onto the shoulders.
    Anyone else - feel free to confirm or deny my understanding.
  2. May 19, 2021 at 12:02 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Agreed :thumbsup:
  3. May 19, 2021 at 12:03 PM
    Bryan0386b
    Bryan0386b [OP] Active Member
    Bryan
    2017 Toyota Tacoma SR5 double cab
    3in front and 2in rear lift
    $111
  4. May 19, 2021 at 12:06 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    I paid $150 for mine dropped off truck with numbers I wanted told them I’m
    A picky fuck. Picked up truck numbers were perfect. Sorry OP DEFINITELY frustrating. Definitely if you can invest in some UCA’s. Will solve your problems
    N5J_Taco likes this.
  5. May 19, 2021 at 12:06 PM
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    Looks like you've got this mostly figured out, but I will add something about upper control arms.
    You don't NEED new upper control arms with your lift, a proper alignment will make your truck much more reasonable to drive. But, new upper control arms will make it so much better.
    I drove my truck for 2 years with an inexpensive spacer lift (3ish" in the front), and it was fine. Now I've been on new upper control arms for 2 years, and it does make a huge difference. Just have decide what it's worth to you.
    N5J_Taco, essjay and 71tattooguy like this.
  6. May 19, 2021 at 12:15 PM
    N5J_Taco
    N5J_Taco Well-Known Member
    Well you are all ready experiencing some of the issues. You have to remember you just change all the angles on your truck with the lift and your current numbers are for stock I believe. By having higher caster numbers it will help eliminate steering wheel shake and will allow to fit bigger tires or more articulation without severe tire rub in the back every time you wheel or going over bumps. I've got a 2.5 lift and my caster is 3.0 and steering is solid/straight!
  7. Jun 4, 2021 at 6:35 PM
    InyoTaco4x4
    InyoTaco4x4 New Member
    Robert
    2019 Tacoma TRD 4x4
    2" Old Man Emu lift, BFG T/A KO2 265/75R16
    Some upper control arm recommendations would be awesome. What to buy?
  8. Jun 4, 2021 at 6:37 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    JBA or SPC. I run JBA.
  9. Jun 4, 2021 at 6:42 PM
    InyoTaco4x4
    Robert
    2019 Tacoma TRD 4x4
    Do you have the STD or the Heavy Duty version?
  10. Jun 4, 2021 at 8:53 PM
    gotoman1969
    I have the STD. Have had zero issues with them. They have 60k miles on them.
