Truck pulling to left while braking?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoSupreem, May 2, 2010.
  1. May 2, 2010 at 12:40 PM
    TacoSupreem
    TacoSupreem [OP] Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    So here lately my truck's been pulling to the left when i apply the brakes. I'm not sure what's causing it. The truck drives straight any other time. I looked under the truck and saw some grease and dirt on the tie rod boot. Could this be whats causing the pulling? Any advise is appreciated.
  2. May 2, 2010 at 12:47 PM
    270 Well-Known Member
    Jeff
    California
    09 Dc 4x4
    Id go get the alignment checked.
  3. May 2, 2010 at 12:48 PM
    jandrews
    '09 FourDubDee TRD OR
    Sounds like the brakes are grabbing unevenly...check your lines and fluid, take a look at the pads, and rotors as well...while you've got the tires off, pump the brakes a few times and watch caliper engagement to ensure all is well.
    Good idea to check everything on the rear drums as well.
    Edit: Also, check your cylinders. If it's one sided, it's probably not the master cyl.
  4. May 2, 2010 at 12:54 PM
    TacoSupreem
    Hayden
    Kentucky
    ^^This is what i was thinking too? could the front left brake be grabbing more than the others? Fluid level is good?
  5. May 2, 2010 at 12:59 PM
    leg killa
    leg killa Well-Known Member
    AMERICA
    06 SBDB SR5 4x4
    TRD Hood/ Color matched grill/ De badged/ BHLM/ Viper remote start/ Pioneer AVIC Z-130BT/ BFG MT KM2/ MT Classic II/ OME Lift/ LR UCAs/ Pop and Lock
    Warped rotor or alignment could be off..my wifes car was doing this awhile back
  6. May 2, 2010 at 1:06 PM
    jandrews
    Fluid level could be good in the reservoir but if you have a jammed/leaking cylinder then that wouldn't be a tell.
    Like I said, start by verifying that the brakes are functioning properly and go from there.
    I'd be surprised if one brake was more sensitive than the others, but it's possible (sticky cylinder reducing caliper travel, etc.)
  7. May 2, 2010 at 1:37 PM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Oddly enough, when mine was brand new, it pulled to the right when stopping, and pulled hard. Turned out the dealership overinflated the tires - 44psi all around. First thing, check your tire pressure.
  8. May 2, 2010 at 1:47 PM
    bruinsrme
    bruinsrme Well-Known Member
    Scott
    Worcester
    BRM 2010
    Happen to me with my dodge.
    $85 2 calipers, some brake fluid and about 3 hours to complete the job (1st time doing myself)
    after that no more grabbing, no more pulling.
    Stealership will change 5-800 to do such a job
  9. May 2, 2010 at 1:51 PM
    frybike6
    frybike6 Well-Known Member
    southwick, MA
    2010 tacoma doublecab longbed SR5
    Best indicator would be pad thickness and after a drive and hitting the brakes. Check to see if u feel any heat radiating off the rotors. Don't touch cuz you will burn yourself.
  10. May 2, 2010 at 2:13 PM
    TacoSupreem
    Hayden
    Kentucky
    My truck drives dead straight. Could it still be an alignment problem? My tire pressure is perfect. My truck still has the original brakes(18,150miles).
  11. May 2, 2010 at 9:25 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Check for leaks.
  12. May 3, 2010 at 5:03 AM
    frybike6
    southwick, MA
    I'm gonna lean more towards a brake issue. Just because the way your describing the situation.
  13. Oct 5, 2010 at 2:55 PM
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    Oh man, I was having the same problem for about a week a while back. The truck kept veering left EVERY time I braked ,it turns out my left front tire was about 15 psi lower than it should have been.
    Well from what you stated it sounds like that is not the problem.
    Have you found out what it is?
  14. Oct 5, 2010 at 3:01 PM
    09OFF-ROAD
    09OFF-ROAD Member
    Bridgeport, Newfoundland, Canada
    09 TRD Off Road 6-Sp
    TRD Cold Air Intake, Bug-Deflector, Headlight and tailight covers, back rack. 4 hella 550 driving lights on back rack, 3" suspension and 3" body lift, KMC XD Spy wheels 18"x9" with 34x12x18 Nitto Trail Grapplers. Alpine IVA-W505 head unit with Nav. and Bluetooth, Alpine Type R 6.5" components in from, Type-R 6.5" speakers in rear doors. Speakers powered by Alpine 4 Channel Amp 90Wx4 RMS. 12" Alpine Type-R Sub in bass worx ported box powered by Alpine 500W RMS Mono Amp
    did you check your tire pressures? i've had trucks that has had the same issue and it was just tire pressure.
  15. Oct 5, 2010 at 3:10 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Sounds like a caliper issue.
  16. Oct 5, 2010 at 3:19 PM
    i love tacos
    i love tacos Well-Known Member
    St. Louis, MO
    01 PreRunner TRD
    Bull Bar, Hella Lights, AiRaid cold air intake
    X2
    You could have one caliper that is not functioning correctly. Either the left one won't retract or the right one won't engage. I'll bet if you look at you front brake pads they haven't worn at the same rate from side to side. You said the fluid level looks fine so that should rule out a leaking wheel cylinder or caliper. Is this just under hard braking or any braking? If just under hard braking check the back brakes. Also check your shocks for leaks.
  17. Oct 5, 2010 at 9:33 PM
    pinktaco808
    pinktaco808 Hot Steppa
    how to fix man???
  18. Oct 5, 2010 at 10:51 PM
    pinktaco808
    wowwwwwwwww
  19. Oct 5, 2010 at 11:21 PM
    weibz
    weibz Member
    SCOTT
    Rochester,MN
    05 trd offroad 4x4
    Husky liners tube step bars access cover bug gard 35% tint front windows Removed secondary airfilter K&N panel filter
    Deff a caliper issue dude sounds like one side is froze. pretty common on the 2nd gen tacomas I use to be a toyota tech for 3 yrs I have seen more than a few with that problem. hope that helps :)
  20. Oct 6, 2010 at 6:49 AM
    pinktaco808
    fix how????
