truck pulling to the left when braking/loose steering
Discussion in '1st Gen. Tacomas (1995-2004)' started by bob119831, Nov 7, 2010.
  1. Nov 7, 2010 at 9:34 AM
    bob119831
    bob119831 [OP] New Member
    california
    97 toyota 3rz-fe
    Allright. I have had this issue with my 97 4x4 since the day I bought it. The truck will pull to the left when I am braking. The steering is also a little loose to the left when under way. I have replaced the following parts and had this service performed already:
    new calipers and pads in the front.
    new shocks and springs for all 4 corners
    new rack and pinion
    poly urethane bushings in the rack and pinion
    Wheel alignment
    topped off brake fluid
    The truck bounced side to side when I first bought it. The shocks and new rack made a big difference. could a missing bushing in my lower control arm causing the front wheels to shift? the only other thing that I can think of is an issue with my master cylinder? Bad bearing?
    The ride is still pretty squirly when I hit a bump on the freeway just right. Thanks for your help.
  2. Nov 7, 2010 at 12:04 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    You neglected the rear brakes as a cause. Uneven brake force is a cause of the yaw.
  3. Nov 7, 2010 at 7:23 PM
    bob119831
    california
    97 toyota 3rz-fe
    Ill check the rear brakes. would a rear brake issue/yaw cause the wheel to turn to one side?
  4. Nov 8, 2010 at 4:51 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    The rear brakes shouldn't affect the wheel.
    Check your suspension for worn parts and slop. Check your shocks for leaks and corrosion. After you eliminate the brakes from the equation, I would suspect the suspension.
    When you stop, does the front end dive evenly, or at an angle?
  5. Nov 9, 2010 at 6:02 PM
    bob119831
    california
    97 toyota 3rz-fe
    the front end doesn't dive but the wheel will fall to the left. The car will veer slightly to the left when approaching a stop light/sign. The wheel does correct when I accelerate.
    I can see the front DS tire turning toward the right from outside my window. I keep thinking this is a control arm issue. the steering wheel used to go limp and fall to the left when I would hit a bouncing patch of road on the freeway.
  6. Nov 9, 2010 at 6:04 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    tires psi?
  7. Nov 9, 2010 at 6:40 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Tire pressure doesn't cause that.
    Jack up the front end. Pull and push both tires in all directions and look and feel for slop.
    I had a mazda that did that. It was the wheel bearings.
    Have a buddy move the wheel while you inspect.
  8. Nov 10, 2010 at 8:09 AM
    JDBECK23
    JDBECK23 Well-Known Member
    Jesse
    King George, Va
    '01 Tacoma Reg Cab 4 cyl 4x4
    Good call on the wheel bearings... what about ball joints? Those have a tendency to go and wreak havoc on your handling.
  9. Nov 10, 2010 at 8:34 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Ball joints don't usually cause those symptoms. I'd check them anyways since you are already in that area.
  10. Nov 10, 2010 at 8:17 PM
    Tacoma02TRD
    Tacoma02TRD Well-Known Member
    Walla Walla WA/ Klamath Falls OR
    02 Tacoma TRD
    3inch Revtech lift,Flowmaster Muffler, K&N cold air intake, 33x12.5 Maxxis Bighorns, TRD stock locker, Hella 500 Fog lights, Scanguage II, 6k HIDs, Painted Black Rims
    Steering rack might be going out. This just happened to my roommate (TW member Timicha)
  11. Nov 10, 2010 at 8:25 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Were the brake lines properly bled after the new calipers?
    I almost died years ago when air in my brake lines in a CJ-5 caused only the drivers front tire to get all of the pressure and lock up. It pulled so hard to the left when this happend the giant steering wheel nearly snaped my wrist.
    Went home, bled the air out, brakes were fine after.
    Moral of the story, bleed the brakes properly.
    Your story is also consistant with a bad master-cylendar: the pressure might not be being distributed; the shortest line is to the front left = left brakes the hardest and causes pull.
  12. Nov 11, 2010 at 10:32 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I think there were other factors in play which caused your one wheel lock. Pressure in a hydraulic system is equal on the front wheels, less on the rears (proportioning valve). Air affects the whole system, not just 3/4.
