Truck Pulling To The Right After Alignment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09tacomg, Aug 17, 2009.
  1. Aug 17, 2009 at 11:33 AM
    09tacomg
    09tacomg [OP] Active Member
    USA
    09 DC TRD Sport SW
    Leer 100R
    So I took my truck in to have it aligned at the dealer because it was pulling to the right after having 265 70 17 toyo mt installed. You wouldn’t think that the alignment would be off because of bigger tires but what do I know. So they aligned it and it is still pulling to right. Then I decided to have the front tires cross rotated to see if one of the tires were bad. Still does it. I mostly feel the pull on the highway. The truck will make lane changes by its self. What do you guys think. Maybe they are setting the truck to factory specs and not to the larger tires.
  2. Aug 17, 2009 at 11:40 AM
    homeslice
    homeslice Member
    Los Angeles, CA
    09 PreRunner TRD D-cab
    maybe they didn't balance the tire correctly.
    btw, hi, newb here.
    i got a 09 prerunner... off the lot it was pulling left some. the dealership said they balanced.... so i got it aligned, still pulling... had them check the balance on the tires... offf.... had it balanced... no problems now.
  3. Aug 11, 2010 at 9:51 PM
    EvilBetty
    EvilBetty Well-Known Member
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    Did you get this sorted?
  4. Aug 11, 2010 at 10:51 PM
    pinktaco808
    pinktaco808 Hot Steppa
    mine might be like this too
  5. Aug 11, 2010 at 10:55 PM
    DigB
    DigB Go Jets GO!!!!!!
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    try a frame and alignment shop, someone who specializes alignments.....maybe that will help.
  6. Aug 11, 2010 at 10:56 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Sounds like they did a bad alignment job.
  7. Aug 11, 2010 at 10:56 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    i heard somewhere that toyota purposly pulls right because of freeway driving the opposite traffic is always on the left therefore if you fall asleep or arent paying attention instead of merging left the truck will vear right as a safety issue....then again this is just what i heard
  8. Aug 11, 2010 at 11:18 PM
    StandingCow
    NJ
    I think it is more due to road crown. Anyway, thank god the crown makes you go right, I hate falling asleep at the wheel.
  9. Aug 11, 2010 at 11:21 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    tire pressure?
  10. Aug 11, 2010 at 11:27 PM
    pinktaco808
  11. Aug 11, 2010 at 11:39 PM
    ktmrider
    Junk
    is the tire pressure equal in both front tires and at the correct PSI
  12. Aug 12, 2010 at 12:24 AM
    KalamaKid
    KalamaKid Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
    You know after i put my coilovers on i had to take my truck in three times to get it right. Every time it pulled to the right. I reviewed the numbers sheet after each alignment and they changed the right side each time. Maybe the tech that did your alignment was under training...
