Truck pulls right after multiple alignments
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 850_taco, Apr 26, 2021.
  1. Apr 26, 2021 at 10:17 PM
    850_taco
    850_taco [OP] Active Member
    2011 Speedway blue access cab long bed
    2.5 bilstein 6112 coil overs 1inch rear leaf springs
    Truck pulls to the right after multiple alignments wondering if anyone else has had this issue
  2. Apr 26, 2021 at 10:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Incorrect alignment.
    Defective tire.
    Defective front suspension part(s).
    Post your alignment numbers and I'm sure somebody in the know will chime in.
    blu92in99 and whatstcp like this.
  3. Apr 26, 2021 at 10:48 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    AeroCooper likes this.
  4. Apr 27, 2021 at 7:30 AM
    850_taco
    It’s not my tires I’ve swapped back to the factory ones and still pulls
  5. Apr 27, 2021 at 7:40 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Possible dragging caliper or rear parking or stopping brake. Pull the parking brake in a straight line while rolling and if it pulls right it could be dragging.
    Gearheadesw likes this.
  6. Apr 27, 2021 at 7:40 AM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Mine did this and after multiple alignment shops it was finally discovered I had a bent spindle.
  7. Apr 27, 2021 at 7:45 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Mine sorta did this after two alignments and finally the guy had to adjust caster somehow to get it to track straight. The numbers looked good on paper but they ended up having to do some finaggling with the caster to get it right.
  8. Apr 27, 2021 at 8:03 AM
    Turdyota3000
    Turdyota3000 Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    How did you figure that out? Mine is pulling hard right after new LCA’s, all new UCA bushings, and uniball. I thought it could be my tires because of how it feels like a hopping/bouncing and steering wheel shake upon braking. New rotors, pads, wheel bearings, and ecgs clam shell as well. And several alignments.
    Edit: I also have new wheel bearings
    Gunshot-6A and 850_taco[OP] like this.
  9. Apr 27, 2021 at 8:17 AM
    850_taco
    Gunshot-6A likes this.
  10. Apr 27, 2021 at 8:19 AM
    850_taco
    @Turdyota3000 ive done the same thing too and mine still pulls right
  11. Apr 27, 2021 at 8:20 AM
    Turdyota3000
    Round da corner
    I can’t figure it out. I don’t know what to look for or how to inspect the spindle without taking it off? Going to have my coilovers rebuilt soon as well. I’ve spent a lot of damn money on new front end parts just to have this thing go straight to the ditch if I let go of the wheel.
  12. Apr 27, 2021 at 8:24 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    what are your alignment numbers?
  13. Apr 27, 2021 at 8:25 AM
    850_taco
    @Turdyota3000 i took mine to Toyota yesterday and they said they had fixed it but as soon as I hit the road it pulled right again so I’m taking it back
    Turdyota3000 likes this.
  14. Apr 27, 2021 at 8:29 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    What are your alignment numbers? Always request a spec sheet after the alignment. You’d be surprised how many places do toe-n-goes
  15. Apr 27, 2021 at 8:41 AM
    Turdyota3000
    Round da corner
    604D7B3B-8520-4F31-899E-05488A8B14F3.jpg Not trying to thread jack you OP but I’m having this same issue and any advice will help. I was just told by Toyota tech to check my motor mounts as well.
  16. Apr 27, 2021 at 8:48 AM
    Slick Taco
    • I finally took it to a shop that specializes in off roading and 4x4 vehicles. The guy removed both spindles and put them side by side and you could see that one of them had a slight bend in it. It wasn't much but it was enough to pull my truck slightly to the right even though they were able to get proper alignment numbers.
  17. Apr 27, 2021 at 8:54 AM
    eon_blue
    Azusa, CA
    Just throwing in my experience with this as well (also to the right, funny how that's what we all experience lol). Mine was so bad it wore down my STMaxx really unevenly within a short amount of time.
    Finally the 4x4 shop adjusted my SPC UCAs to have more caster on one side, so at least I was able to track straight and not destroy my tires fighting a pull all the time.
    My spindles look fine though we haven't taken them off to compare side by side. The shop thinks it might actually be a slight bend in my driver side LCA where the ball joint mount is riveted into the arm...that side looks like it has a slightly upward angle compared to the other side, which might explain the right pull. Currently looking at replacing that LCA to see if it helps.
    If not then I'm looking at the spindles, hopefully.
    My advice would be, in the meantime get them to try and align your truck so it does track straight so you don't eat up your tires.
    Although in my case, they were actually unable to get me good alignment numbers so that's a little different than some.
  18. Apr 27, 2021 at 8:57 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Mine was caused be a sized cam bolt.
    TRDSport10 likes this.
  19. Apr 27, 2021 at 8:58 AM
    Turdyota3000
    Round da corner
    I just got off the phone with Toyota and I ordered all new cam bolts.
    koditten[QUOTED] likes this.
  20. Apr 27, 2021 at 9:07 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Look and measuring fine are two different things. I may be pleasing to the eye, but how does it measure out or compare to a new one.
