Truck pulls right after multiple alignments
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 850_taco, Apr 26, 2021.
  1. Apr 28, 2021 at 9:50 PM
    #61
    850_taco
    850_taco [OP] Active Member
    2011 Speedway blue access cab long bed
    2.5 bilstein 6112 coil overs 1inch rear leaf springs
    @essjay thats the only other thing I can think of they said after they align it and the truck hit a bump it comes out of alignment but I’ll ask for a sheet tomorrow
  2. Apr 28, 2021 at 9:56 PM
    #62
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    But... you don't know how it's aligned? The alignment tech's job is just to get everything in spec. It could have been completely within spec before and after each of your alignments, and still pull to the right.
  3. Apr 28, 2021 at 10:03 PM
    #63
    850_taco
    @essjay i don’t know man I’ll figure something out
  4. Apr 29, 2021 at 6:43 AM
    #64
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the cam bolts were loose and moving when you hit bumps you'd be able to hear it. Mine were slightly loose (not torqued to 100 lb/ft) after an alignment and they made a horrible popping sound when weight was put against the lower control arm. Like going up a curb with one tire or sharply applying the brakes.
    A thrust angle issue at the rear axle will haunt whatever alignment settings get performed at the front
    Biscuits and 850_taco[OP] like this.
  5. Apr 29, 2021 at 8:25 AM
    #65
    850_taco
    @b_r_o funny you mentioned a popping sound my truck used to make terrible front end noises when the suspension flexed but Toyota retorqued my bolts and it doesn’t do it anymore
  6. Apr 29, 2021 at 8:29 AM
    #66
    Taco'09
    Taco'09 Well-Known Member
    I thought this would be a good place to park this TSB. This one is from 2008 but there is no reason to think it would not still apply to current models. I have just not seen an updated version.
    FWIW, most of the seemingly unresolved pulling issues I have personally experienced over the years have often been rooted in the tires themselves, and specifically conicity. For the DIY, tire swapping L-R and front-back can help initially isolate tire issues without continually having to run to an alignment shop and constantly tweak settings.
    REPAIR_MANUAL_SUPPLEMENT_VEHICLE_PULLING_TO_ONE_SIDE_T-SB-0391-08.pdf
    essjay likes this.
  7. Apr 29, 2021 at 10:39 AM
    #67
    Turdyota3000
    Turdyota3000 Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    My new rims and tires helped with the pulling, somewhat. Have to change/replace cam bolt tabs because one of the cam bolts was seized and the dude flattened the front tab while torquing on the bolt. Going with the total chaos cam tab gussets an new cam bolts.
  8. Apr 29, 2021 at 6:01 PM
    #68
    850_taco
    Update truck seems to be fixed drives straight steering wheel is just crooked not a hard fix though
  9. Apr 29, 2021 at 7:10 PM
    #69
    Turdyota3000
    Round da corner
    So it was your alignment?
  10. Apr 29, 2021 at 7:13 PM
    #70
    850_taco
    @Turdyota3000 tbh I have no clue what Toyota did but I will find out when I go to pay for it
    Turdyota3000 likes this.
  11. Apr 29, 2021 at 7:15 PM
    #71
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    So the dealer attempted another alignment, they claim they got pull to go away but the steering wheel is now off center?
    :facepalm:
    Larzzzz and Turdyota3000 like this.
  12. Apr 29, 2021 at 7:15 PM
    #72
    essjay
    Concord, CA
    How do you even know if it's driving straight if you haven't picked it up yet?
  13. Apr 29, 2021 at 7:16 PM
    #73
    850_taco
    @b_r_o yeah I’ll take it back tomorrow and they will fix the steering wheel
  14. Apr 29, 2021 at 7:17 PM
    #74
    850_taco
  15. Apr 29, 2021 at 7:17 PM
    #75
    Turdyota3000
    Round da corner
    Sounds sketchy bro
  16. Apr 29, 2021 at 7:19 PM
    #76
    essjay
    Concord, CA
    But you just said:
    If you did pick it up, wouldn't you have gotten the alignment sheet and paid for the work?
  17. Apr 29, 2021 at 7:19 PM
    #77
    850_taco
    How all I asked them to do was make it drive straight and they did
  18. Apr 29, 2021 at 7:19 PM
    #78
    850_taco
    The service department was closed I spoke to the manager of the Toyota dealer he said to come by tomorrow and pay for it
  19. Apr 29, 2021 at 7:23 PM
    #79
    850_taco
    He let me take the truck home to make sure it was fix I hit every possible bump in the road at speed and the truck continued to drive straight did this for about 2 hours truck still drives straight
  20. May 1, 2021 at 8:05 AM
    #80
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    You're not hitting big enough bumps. :rofl::rofl:
