truck pulls to right
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spinso71, Jun 6, 2022.
  1. Jun 6, 2022 at 4:35 PM
    spinso71
    spinso71 [OP] Active Member
    Shawn
    Baton Rouge
    09 Tacoma 4X4
    OME MT64
    2009 TRD OR 4x4 DCSB. I've had the alignment check twice, the tires have already been rotated. Truck pulled before and after alignment. Bearings replaced with Blue Pit bearings in 2016. Tires inflated the same. Has anyone else experienced this and what would be your first item to check? Also, no sounds of rubbing from the caliper.
  2. Jun 6, 2022 at 4:47 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Did you balance the tires?
  3. Jun 6, 2022 at 6:13 PM
    spinso71
    Shawn
    Baton Rouge
    09 Tacoma 4X4
    OME MT64
    Yes.
  4. Jun 6, 2022 at 6:15 PM
    spinso71
    Shawn
    Baton Rouge
    09 Tacoma 4X4
    OME MT64
    I'd like to add that it doesnt pull hard. Its just that I've driven it for 13 years and notice that I can't go as straight and as far with no hands on the wheel as I used to.
  5. Jun 6, 2022 at 6:21 PM
    spinso71
    Shawn
    Baton Rouge
    09 Tacoma 4X4
    OME MT64
    From the ground to the bottom of the wheel well on the driver side at the center of the hub is 2' 10 1/4". Its 2' 10 7/8" on the passenger. So, its sagging a bit on the driver side but wouldn't it be pulling to the left in that case? Also, is that within spec?
  6. Jun 6, 2022 at 6:42 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Ok. What are we talking here. 5 feet? 50’yards?
  7. Jun 6, 2022 at 8:01 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I have had experience this.
    It was my wheel bearing. At first it was just a pull and then a noise.
    And these were assemblies with Koyo bearings from a reputable builder.
    They only lasted 34k miles. At first I just didn’t want to believe it. And even thought maybe my steering rack was bad?
    Sometimes the bearing just don’t make it as long as we’d like:confused:
    BTW, I’m not bashing the builder. For all I know it might have been me, my truck or just bad luck as to why the bearing went bad?
    TexasWhiteIce likes this.
  8. Jun 7, 2022 at 6:00 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Mine does this when i come up to a beer store....
  9. Jun 7, 2022 at 6:07 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Did they give you a printout of the alignment, so you had actual eyes on the toe and center measurements?
    Otherwise I agree with bearings. Take it for a good 20 minute drive then use an IR temperature gun to check brake calipers, drums, and wheel hubs. Find the part that's running hotter than the others.
    wi_taco likes this.
