Truck Pulls to the left at times and i feel a slight vibe in the seat...ideas?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaGus, Sep 20, 2010.
  1. Sep 20, 2010 at 2:50 PM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    My truck is supposed to be within alignment specs or close to it anyways and i used to have huge vibes in the steering wheel at highway speeds, but then i got it road force balanced and that is gone but i do feel some vibes in the seat at times randomly. I'm pretty sure i may need to get my truck realigned, but do u think the bumps in the seat are just from the stiffer suspension (5100's) and the bigger tires?
    Also should i get it realigned?
  2. Sep 20, 2010 at 3:30 PM
    TacomaGus
    Gus
    Morgantown, WV
  3. Sep 20, 2010 at 6:08 PM
    TacomaGus
    Gus
    Morgantown, WV
    anyone?
  4. Sep 20, 2010 at 6:18 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    alignment and balance tires..
  5. Sep 20, 2010 at 6:33 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
    Could be the road that your feeling in the seat. Has nothing to do with the alignment.
    If your truck pulls, and may be out of alignment, Id recommend getting it aligned. It will save you from bad tire wear patterns.
  6. Sep 20, 2010 at 6:41 PM
    TacomaGus
    Gus
    Morgantown, WV
    yea i am getting it realigned here at school friday afternoon cuz the pep boys at home is terrible and they did a great job road force balancing but the vibes come in and out and honestly i drive in PA and WV so none of the roads or high ways are very smooth due to plowing haha
  7. Sep 20, 2010 at 6:56 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Just to maybe point you in the right direction... if it's still a balance issue, front wheels will be felt mostly in the wheel, where rear wheels will be felt mostly in the seat/ everywhere else.
  8. Sep 20, 2010 at 7:04 PM
    TacomaGus
    Gus
    Morgantown, WV
    yea its just that i got them road forced balanced and i have never heard of anyone having to redo road force balancing and the truck drove soo much better after it was done so i'm just wondering if it was the road since no highways even are totally smooth here haha. But it def pulls to the left
  9. Sep 20, 2010 at 9:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Bigger, heavier tires will drive different compared to stock. Plus, when you lift it, it has a big effect on the caster setting. When the caster is too low it will feel like it wanders too easily, especially on uneven surfaces at higher speeds.
    When you align it, see if the caster can be set to 2 degrees or higher while maintaining a toe and camber setting of 0 degrees.
  10. Sep 21, 2010 at 6:36 PM
    TacomaGus
    Gus
    Morgantown, WV
    so pretty much when i go in friday i should tell them toe 0 camber 0 and caster as high as you can go? Or should i just say 2-3.5?
  11. Sep 21, 2010 at 8:49 PM
    TacomaGus
    Gus
    Morgantown, WV
  12. Sep 21, 2010 at 9:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It actually took me two visits to get close to what I wanted. Or at least what I believe is as close to what is possible with my stock UCAs.
    On the 2nd visit I actually got their most experienced tech, likely because I was pushy about the results I got after the 1st goaround. The 2nd time they were able to set the toe and camber very near zero but could not get the caster any higher than 1.6/1.7. Nonetheless, the truck did drive better with less wander.
    To answer your question, I always ask for what I want with the realization that I might have to compromise. But I went in telling them I wanted 0, 0, and 2.4.
  13. Sep 21, 2010 at 9:32 PM
    Mr.Fahrenheit
    Mr.Fahrenheit Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    how much did u lift it? i've heard sometime there are driveline angles can cause vibrations....
  14. Sep 21, 2010 at 10:11 PM
    TacomaGus
    Gus
    Morgantown, WV
    its only the billy's set to 2.5" up front but they have def settled some so i would say 2-2.25" inches now
  15. Sep 22, 2010 at 9:38 AM
    vegetopia
    vegetopia newbie
    Jamie
    Houston
    08 DCSB TRDOR 4x4 MANUAL
    2008 Toyota Tacoma 4x4 TRD Off Road SR5 Double Cab 6.0L 6MT
    hmmm I just picked mine up from pep boys yesterday. I wish I had seen this first. I actually pressed them on the caster specs when I saw the printout as they were (from memory) left 1 and right 0.3. He said that the print out was from before the final settings but the caster was within spec. I imagine that means like 1.3 or thereabouts.
    should I bring it back in and tell them to increase caster to ~2.4?
    I believe camber and toe were both very close to 0
  16. Sep 22, 2010 at 9:51 AM
    Digiratus
    Roaming the PNW
    The RedHead
    The more lift you have the more difficult it will be to get a high caster number with stock upper control arms. How does it drive?
  17. Sep 22, 2010 at 9:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    That Caster is VERY low. It should be just over 2*
  18. Sep 22, 2010 at 9:59 AM
    vegetopia
    vegetopia newbie
    Jamie
    Houston
    no, i know that what i listed is low. He said that it was within spec, just not shown on my printout. spec is what, 1.1 - 2.5?
  19. Sep 22, 2010 at 10:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think the lowest is 1.4*
  20. Sep 22, 2010 at 10:31 AM
    TacomaGus
    Gus
    Morgantown, WV
    pep boys is the most worthless place ever, i have had them align my truck 4 times and it is still off so i would just take it somewhere else
