Truck randomly dies on me, help?
Discussion in 'Technical Chat' started by TashcomerTexas, Apr 30, 2014.
  1. May 3, 2014 at 7:07 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    The parking brake switch could be sticking, but that's not usually the case. That light also indicates when your brake fluid in the reservoir is low, which usually indicates that your pads are worn out. This shouldn't be at all related to the stalling
  2. May 4, 2014 at 3:23 AM
    triplejjj
    triplejjj Pictographer
    Jerry
    Florida
    2013 XSP-X 4X4
    LoPro QT, Toyota Bed Mat, Husky Liners, ScanGauge, WeatherTech Deflectors, Drop in Billet Grill, Train Horns, PanoFlex Window Tint, Viper Alarm, Remote Start, Console Vault,
    I would also check the brake switch as well as the connections at the Alternator and work backwards.
    Sounds like something telling the starting circuit to shut off or it breaks the circuit.
    If it runs fine until you take it out of gear, look at the switch.
    If it runs fine and just quits, start at the alternator.
    If you have an alarm that could do it.
    Just think through it and you'll get it.
  3. May 4, 2014 at 2:35 PM
    TashcomerTexas
    TashcomerTexas [OP] My truck is a whiner
    2003 TRD DC Supracharged
    Alright well now I've narrowed it down to when I put it in reverse and disengage the emergency brake, happened again today so that seems to be the culprit. I tried letting it idle for a good amount of time but it ran fine, wasn't until I put it in gear. Also I've never put extended brake line when I lifted it so I plan on getting all this corrected within the week.
  4. May 4, 2014 at 2:50 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Might be throttle positioner or theres an idle-high idle positioner or regulator also that should automatically kick up your idle when you put it in gear, also get a code reader or get with someone who does, these trucks will still throw (& save) codes that don't visibly show up like a check engine light
  5. May 4, 2014 at 3:02 PM
    TashcomerTexas
    Thanks for the response, already tried code reading at autozone nothing came up. It will only throw the oil pressure light and battery light not the check engine. Then it kills the engine but then I start it back up and everything runs fine and the cel lights go away
  6. May 4, 2014 at 3:06 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    1st gens don't have a key in chip or immobilizer module...:thumbsup:
    So it can't be his key ;)
  7. May 4, 2014 at 3:08 PM
    TashcomerTexas
    Thank you! I was a little confused on that but I didn't question haha. Nothing special about my standard key...
  8. May 4, 2014 at 3:09 PM
    smmarine
    Melbourne FL
    I knew my 99 doesn't, didn't know if the meet first gens did or not
  9. May 4, 2014 at 3:09 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    No prob. Just wanted to clarify it so someone else that comes in and doesn't get confused
    I hope your issue is something small, you have 100,000 less miles than my 2008 so it can't be something major lol
  10. May 5, 2014 at 3:46 AM
    triplejjj
    Jerry
    Florida
    2013 XSP-X 4X4
    It helps to read. Eliminate the obvious first.
    Keep us posted.
    thanks
  11. May 5, 2014 at 5:20 AM
    smmarine
    Melbourne FL
    Apparently first gens never got a chip key
  12. Jan 14, 2015 at 4:29 PM
    notbrigum
    notbrigum Well-Known Member
    Chandler AZ
    08 double cab 4x4
    TRD intake, Magnaflow exhaust, billet grille, tube steps
    I know his issue was 10+ mos ago but my 2008 did the same thing last week. Engine cold, starts normally, idles 3-4 secs and shuts off. Repeats 3-5x. No sputtering (lack or fuel) or missing, just OFF, like key turned to Off. Checked all fuses, still does it. Wait 10 mins, starts and runs fine. Does not reproduce this last week. I know an electrical prob will be hard to diagnose if not currently acting up. No error codes stored, checked that. Runs great. I guess it's a sensor starting to die (or Chris's idea of moisture in the air/short in harness somehwhere). I was hoping people would jump on and, 'Oh man, that's your crank angle. They all start to die after 110k.' Guess I should be greatful not recurrent. If any insight, would appreciate it.:)
