Truck rides like a tank, best upgrades to help??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ckhunter3, Feb 20, 2015.
  1. Feb 22, 2015 at 8:05 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Removing your sway bar will impove ride quality significantly. I took mine off and love it. I don't notice any increased body roll in corners (I have 5100s compressed to 2.5" of lift).
  2. Feb 23, 2015 at 6:12 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    And what load range are they? If they're load range E, that's probably part of the problem.
  3. Feb 23, 2015 at 6:33 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Everything I add from you adds weight to the bed and my E's ride better...
  4. Feb 23, 2015 at 6:52 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Keep ordering. Eventually it will be like driving on a cloud of titties.
  5. Feb 23, 2015 at 6:57 AM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    ^this. You can run 265/70/17s on my stock suspension no problem. I would do more research on what you really want before buying anything, but I would get those spacers off ASAP as they are designed for mall crawling not actual work.
  6. Feb 23, 2015 at 6:59 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
