Truck Rolls Forward When Facing Downhill in Reverse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gsujake, Jul 6, 2019.
  1. Jul 6, 2019 at 11:03 AM
    Gsujake
    Gsujake [OP] Member
    Jake
    2009 Double Cab Tacoma 4x4
    Alright, I have a 2009 DCLB 4x4 that has 120k on it. Today, I was going to back up my driveway and I put it in reverse and went to hit the gas, and before I hit the gas, it began rolling forward. It's never done that before. After backing up the drive, I pulled back down and was able to recreate the same scenario with the same outcome.
    Transmission hasn't been serviced, ironically, I have an appointment Monday to have that completed.
    What could the issue be here? Thanks
  2. Jul 6, 2019 at 11:43 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Wait. You mean, gravity still works?
    Could be low on fluid however, if it's never been serviced, might consider doing a full proper fluid change
  3. Jul 6, 2019 at 11:48 AM
    Muddinfun
    Muddinfun Well-Known Member
    Maybe the earthquake shifted your driveway to a steeper angle.
  4. Jul 6, 2019 at 11:51 AM
    Gsujake
    Gsujake [OP] Member
    Jake
    Previously, it's always stopped itself, probably due the pressure that the torque converter is/was able to build.
  5. Jul 6, 2019 at 1:17 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I don't think I've ever owned a vehicle that didn't do that.
    outxider and whatstcp like this.
  6. Jul 6, 2019 at 1:19 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Same, seems normal OP.
    Hell, my subaru with electronic parking brake has a mode for stop and go driving on a steep hill where it'll reapply the parking brake every time you stop, so you don't roll backwards (very specific feature I might add).
  7. Jul 6, 2019 at 5:53 PM
    FishingPups
    FishingPups Well-Known Member
    Barry
    2014 Tacoma TRD Sport Access Cab
    Prerunner, Towing Package, Convenience Package, Tonneau Cover
    Check to see what the rpm's are supposed to be when it is in gear. Then check to see what your rpm's actually are when in gear. That is a starting point.
  8. Jul 6, 2019 at 8:24 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds normal to me...
    06Tacooo and whatstcp like this.
  9. Jul 6, 2019 at 8:37 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Sounds normal 2 me too. When in that situation I always use foot on brake and foot on gas to prevent rolling. My wife always does this in her car and then when I drive it I do the same thing she does without rolling. She just can’t understand why it rolls with her and not me.
  10. Jul 6, 2019 at 9:09 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    When you reverse out of a parking space (or drive way, etc) and then shift into (D), do you stop fully or let the truck roll back WHILE you're shifting it into D?
  11. Jul 6, 2019 at 9:16 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Every vehicle l have ever owned has done the same thing.
    ace96 likes this.
  12. Jul 6, 2019 at 9:29 PM
    James710
    James710 Well-Known Member
    James
    Springfield, MA
    '14 Sport AC BRM
    Facing down hill, putting it into reverse and then rolling foward is the same as.. facing uphill, being in drive and then rolling backwards :anonymous:
    Happens to a lot of people including me, try the brake thing @maxtherat suggested.
    maxtherat likes this.
  13. Jul 6, 2019 at 10:04 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I really can't believe anyone would think this is even a problem. Do they not teach gravity in school anymore?
    I find this as silly as those clutch switches in order to run the starter.
    Or in a manual transmission that has a brake that holds the truck when starting from a stop. Hill Start Assist I think.
    Learn to drive and none of these are an issue.
    Torspd and Hobbs like this.
  14. Jul 7, 2019 at 7:01 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    My truck has always rolled on incline like that. Gravity is a bitch sometimes.
  15. Jul 7, 2019 at 4:31 PM
    FishingPups
    Barry
    Point being is the OP said that it has never done this before meaning that he believes something is amiss because it is doing it now. My ford will hold its own in the same situation on a 30 degree downhill slope when in reverse. It might slowly creep forward but it willl not just "roll" foward. Low transmission fluid will cause it to go into gear slower. Maybe it didn't engage quick enough before he took his foot off of the brake. Low RPM's can cause this too.
    b_r_o likes this.
  16. Jul 8, 2019 at 4:35 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Leaning towards normal too. These truck don't hold their position on inclines/declines.
  17. Jul 8, 2019 at 9:12 AM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    You're supposed to use the brakes to hold a vehicle on an incline or decline. If the transmission is doing it while in Drive. It's building up a lot of heat, as it's the fluid pressure doing it.
  18. Jul 8, 2019 at 5:26 PM
    FishingPups
    Barry
    Right. But we are only talking a few seconds in this situation.
  19. Jul 8, 2019 at 6:16 PM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    A few seconds won't matter. l just mean if people do it too long because they become used to it. l had a friend that always did it. He'd let the vehicle hold itself on slight inclines for a whole traffic light, or if stuck in traffic.
  20. Jul 8, 2019 at 6:20 PM
    FishingPups
    Barry
    Yeah, that ain't good.
