Truck running rough still after many new parts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kauaikakalia, Sep 23, 2019.
  1. Sep 25, 2019 at 3:40 PM
    #41
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Yes. Check your fuel pressure. I understand you replaced the pump but it doesn’t mean it’s working properly.
  2. Sep 25, 2019 at 3:43 PM
    #42
    Rachelsdaddy
    Southern NH
    That’s what mine was doing... fuel pressure was all over the place. Even temperature would make it worse or better.
    RedManRocket[QUOTED] likes this.
  3. Sep 25, 2019 at 5:44 PM
    #43
    Kauaikakalia
    Kauaikakalia [OP] Active Member
    Andrew
    00 tacoma 4x4 2.7
    Stock
    Ok so fuel pressure is at 75. But it slowly leaks down
    Black DOG Lila likes this.
  4. Sep 25, 2019 at 6:20 PM
    #44
    Kauaikakalia
    Andrew
    00 tacoma 4x4 2.7
    Stock
    Not to sure what is supposed to be at?? The fuel pump doesn't turn on unless the truck is running once truck dies pump shuts off
  5. Sep 25, 2019 at 8:28 PM
    #45
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Where did you test the fuel pressure at
  6. Sep 25, 2019 at 8:54 PM
    #46
    Kauaikakalia
    Andrew
    00 tacoma 4x4 2.7
    Stock
    The
    fuel line that's coming right out the fuel tank but in the engine bay.
  7. Sep 25, 2019 at 9:06 PM
    #47
    RedManRocket
    Red
    2002 Double Cab LT
    And how slowly does it lose pressure, because there's a vent in the fuel tank I believe
  8. Sep 25, 2019 at 9:09 PM
    #48
    Kauaikakalia
    Andrew
    00 tacoma 4x4 2.7
    Stock
    It took about 3 mins to leak down all the way
  9. Sep 25, 2019 at 9:11 PM
    #49
    RedManRocket
    Red
    2002 Double Cab LT
    Hmmm, honestly idk if that's within spec. Hopefully someone else will chime in
  10. Sep 25, 2019 at 9:13 PM
    #50
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Take a plug wire off and start it and see if it runs the same or worse . One at a time and check them all . If it runs the same with a wire off you found a problem .
  11. Sep 25, 2019 at 9:19 PM
    #51
    RedManRocket
    Red
    2002 Double Cab LT
    Good way to test ignition coils/distributor wires ^^^
  12. Sep 25, 2019 at 9:24 PM
    #52
    Kauaikakalia
    Andrew
    00 tacoma 4x4 2.7
    Stock
    Did all that runs like crap if I disconnect anything to do with spark
  13. Sep 25, 2019 at 9:25 PM
    #53
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Have a look at this.
    • ovi.pdf
      File size:
      59.7 KB
      7
  14. Sep 25, 2019 at 9:27 PM
    #54
    Kauaikakalia
    Andrew
    00 tacoma 4x4 2.7
    Stock
    Will check it out
  15. Oct 1, 2019 at 2:38 PM
    #55
    Kauaikakalia
    Andrew
    00 tacoma 4x4 2.7
    Stock
    Ok so it's kinda crazy to do all this with out reason, took it to a guy and he's said did anyone say anything about brake booster. So I guess the brake booster cares big time. And if leaking it'll pull from your intake manifold and mess stuff up.?? Anyone ever have this issue??
  16. Oct 1, 2019 at 3:03 PM
    #56
    Rachelsdaddy
    Southern NH
    I’ve heard about it, if the diaphragm is leaking you will certainly sucking unaccounted for air, plug the line, see if it improves....
  17. Oct 1, 2019 at 3:49 PM
    #57
    Kauaikakalia
    Andrew
    00 tacoma 4x4 2.7
    Stock
    Exactly
  18. Oct 6, 2019 at 4:20 PM
    #58
    Kauaikakalia
    Andrew
    00 tacoma 4x4 2.7
    Stock
    Ok so I did the test didn't help. Did egr delete. Didn't help???? So stumped man!!!
