Truck runs hot
Discussion in '1st Gen. Tacomas (1995-2004)' started by SamZ, Nov 20, 2024.
  1. Nov 20, 2024 at 9:21 AM
    SamZ
    SamZ [OP] Member
    04 tacoma
    Just rebuilt it, and it runs hot
  2. Nov 20, 2024 at 11:20 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Not very cool of it
    ztwatson and 0xDEADBEEF like this.
  3. Nov 20, 2024 at 1:36 PM
    SamZ
    SamZ [OP] Member
    04 tacoma
    My point exactly
  4. Nov 20, 2024 at 1:37 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    How hot is hot?
  5. Nov 20, 2024 at 1:43 PM
    02hilux
    Planet: EARTH
    Hot as in the dummy needle gauge hot or an actual temp with a scan gauge?
  6. Nov 20, 2024 at 1:51 PM
    SamZ
    SamZ [OP] Member
    04 tacoma
    Well the needle shows it hot, but I turn the heater on, and it cools right down, I never have to add coolant
  7. Nov 20, 2024 at 1:52 PM
    0xDEADBEEF
    Which engine? Did you put the jiggle valve up or down on the thermostat?
  8. Nov 20, 2024 at 1:58 PM
    SamZ
    SamZ [OP] Member
    04 tacoma
    The engine is 3400v6 the work has all been done by a shop!! I have had it completely redone, all the cooling system, heads, gaskets timing belt water pump, and two different thermostats, and it still gets almost to the red, if I do not use my heater, it runs fine then!!!
  9. Nov 20, 2024 at 2:16 PM
    02hilux
    Planet: EARTH
    Many will disagree with me because Toyota said otherwise but I tried both 6 and 12 position and it made no temp difference. Readings were from a scan gauge with the same thermostat, just positioning the valve at 6 & 12 for testing.
    -5 minutes of idling on the drive way
    -5 minutes of stop and go traffic to the highway
    -5 minutes of highway driving
    -15 minutes return trip on side street coming home
    temp remain nearly identical the entire trip on both setting, a difference of 3 degree before turning the vehicle off on the drive way. The funny thing was, it ran cooler at 12 vs 6 but 6 was what factory recommended.
  10. Nov 20, 2024 at 2:54 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Change out the engine coolant temp sensor, and the water temp sensor. The engine coolant temp sensor is for engine function, the water temp sensor is for the gauge display.
  11. Nov 20, 2024 at 7:27 PM
    SamZ
    SamZ [OP] Member
    04 tacoma
    first, I want to say thank you for the responses, I appreciate it, I also don't think my post reads correct?? I put it in the shop, redone the heads,radiator,fans,shrouds, water pump, timing belt, all new hoses, and gaskets, thermostats x2,complete new cooling system,runs fine until I start up an incline, turn my heater on, and it cools right down to normal, put new sensors in it, hooked it up to obd, and it reads good.. what is left that could cause this.. also there are no cracks, leaks, or fluids mixed at anywhere they are not supposed to be..it does not smoke, it has plenty of power,
  12. Nov 20, 2024 at 7:33 PM
    ChargedSHOTaco
    Hot based on the dummy gauge or a scan gauge? If scan gauge, what is the actual temperature reading?
  13. Nov 20, 2024 at 7:39 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Maybe some trapped air.
    Might just need a gentle break in.
    Even “shops” can oops. They’re just people too so maybe a cooling channel got fouled. If an IR gun is available see if one of the cylinders gets warmer than the others.
    time623 likes this.
  14. Nov 20, 2024 at 7:50 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    +1 for air bubble
    I would take back to shop ASAP b4 they say you did something
    “We test drove for hours and NP”
    meh to that
    time623 likes this.
  15. Nov 20, 2024 at 7:53 PM
    02hilux
    Planet: EARTH
    probably from the built in smart gauge
  16. Nov 20, 2024 at 7:57 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    OP, definitely need the OBD2 measurement. There are two coolant temp sensors, one for the gauge, one for the ECU.
  17. Nov 21, 2024 at 10:11 AM
    Clearwater Bill
    Billy
    Largo Florida
    Then it would seem the shop should correct their work.
