Truck Sales May 2018 Taco surges 21%
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2016Tacoman, Jun 5, 2018.
  1. Jun 7, 2018 at 1:27 PM
    #101
    mcdean
    mcdean Well-Known Member
    San Jose, CA
    2016 DCLB TRDOR 4x4 A/T
    LED int lights, Morimoto HID lows, Philips LED fogs
    Not a light duty test by any means. Long distances over washboard will absolutely kill a shock; the constant, rapid compression cycles will heat the shock to the point of failure. As the article points out, the Ridgeline did better because it is a unibody with 4 wheel independent suspension which greatly reduces the stresses on the individual shock. It's why the rears on the Tacoma blew, but the fronts (IFS) didn't.
  2. Jun 7, 2018 at 1:55 PM
    #102
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    Also why the TRD Pro has remote REAR Resi's but not up front
    2016Tacoman[OP] likes this.
  3. Jun 7, 2018 at 4:03 PM
    #103
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Ahhhhhh that’s a great point, I never thought of that!
  4. Jun 7, 2018 at 5:36 PM
    #104
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Uhh no. The trend has been towards unibody because of the weight savings. If it really was inherently stronger, then why do nearly all heavy duty vehicles continue to utilize body on frame?
    Comparing GVWR to HP is a false equivalence. HP is a measurable characteristic, GVWR is a number the lawyers and government agree on. You can register the same heavy truck with two vastly different GVWR's based solely on what license you want to drive it with.
    I have no problem with the Ridgeline, but saying it's a more capable truck than the Tacoma is a stretch.
    Edit: also if you compare 2wd DCSB models, the payload is the same for v6 models and the taco beats the Ridgeline if you get a 4 banger.
    If you get a 2wd access cab taco you beat max Ridgeline payload by 40lbs.
  5. Jun 7, 2018 at 6:16 PM
    #105
    MIDSIZED13
    MIDSIZED13 Active Member
    2018 Ridgeline
    Most consumer orientated trucks are still body on frame because the perception is that they are tougher. Most people aren’t open to a unibody platform.
    Body on frame is also cheaper once you start offering multiple variants of something. For example, long bed, short bed, dual cab,etc. every single one of those would effectively have to be its own unibody construction and costs would add up. With body on frame you just bolt stuff to the frame and call it a day. That’s why the ridgeline is only offered in 1 variant, would be too costly for multiple variants.
    Body on frame is still generally better for towing to your point but the rigidity and inherent strength of a unibody is unbeatable for hauling if done properly. All the weight it better distributed. Look at the crash tests of the ridgeline vs any body on frame truck and you will see how much stronger of a structure it is.
    Body on frame is also better for off roading partially because they aren’t as rigid as a unibody. The fact that they flex is actually a desirable trait.
  6. Jun 7, 2018 at 6:31 PM
    #106
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Actually the Ridgeline is offered in several variants:
    Odyssey
    Pilot
    Ridgeline
    Acura MDX
    They all share many common parts.
    At the end of the day, the biggest difference between the Ridgeline and Tacoma is off road ability. Certain compromises by Toyota are needed to make a truck that performs well off road and well on road. The Ridgeline is not good off road. It is exceptional on road though. The Tacoma is OK on road and good off road.
    greengs, StayinStock and RocTaco like this.
  7. Jun 7, 2018 at 6:37 PM
    #107
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Well said.
    The Tacoma won for me because a 6ft bed, 4wd with low range, ground clearance, and a manual transmission were more important to me than 4 doors and a smooth ride.
    Different strokes for different folks.
    hiPSI[QUOTED] likes this.
  8. Jun 7, 2018 at 6:40 PM
    #108
    crappie man
    crappie man Well-Known Member
    i agree. Ridgeline no question rides and handles on road much better and lot more comfortable. Turning radius is not great for its size but I will say when I test drove them it was nice. As far as most conditions on road from snow and other stuff it handles really better in that arena too unless real deep snow.
  9. Jun 7, 2018 at 6:45 PM
    #109
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    The only thing wrong with a RL is the looks. Honda really screwed the pooch on that. This market is too wide open to sell the numbers they do, and there is only one reason why they do, looks. A RL wouldn't work for me, but for a vast majority of Taco owners, it would actually be a better choice. Honda just needed to not make it look like a Pilot from r/shittycarmods.
    hiPSI likes this.
  10. Jun 7, 2018 at 6:56 PM
    #110
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    and dont regret it. But I do miss the trunk in the bed.
    hiPSI likes this.
  11. Jun 7, 2018 at 7:51 PM
    #111
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    hiPSI likes this.
  12. Jun 7, 2018 at 7:52 PM
    #112
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    What the...
    bv8ma and shakerhood[QUOTED] like this.
  13. Jun 7, 2018 at 8:28 PM
    #113
    Lt. Dangle
    Ohio
    I don't hate this as much as I should.
  14. Jun 7, 2018 at 9:03 PM
    #114
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    Test drove the ridgeline, had some goid tech in it, but it was more expensive and i didnt like the minivan look
  15. Jun 7, 2018 at 9:11 PM
    #115
    GearByThr3Six
    GearByThr3Six Well-Known Member
    '17 Tacoma OR
    Hey hey hey, I traded my WRX STi in for my Tacoma, but it wasn't the lesbian type of Subaru. While an awesome car with plenty of fun to be had, it was a really stiff ride. When I hear people complain about the ride comfort in their Tacoma, I just laugh. They don't even know. I drove that thing from Arizona to Maryland and back. My body paid for it.
  16. Jun 8, 2018 at 2:57 AM
    #116
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    Right? I didn't have a STi but I still have a 05 Mustang GT that is lowered with stiffer springs, talk about rough. The Tacoma is a Cadillac in comparison.
  17. Jun 8, 2018 at 4:14 AM
    #117
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Next big storm, I will not pull out the stuck Pilot.... Anyhoo, get a Subaru then it has more ground clearance, MUCH MUCH MUCH better AWD and for less money. Again, I have had Honda's AWD in the 2014 CR-V EX and frankly it sucked.
  18. Jun 8, 2018 at 4:26 AM
    #118
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Yep, honda, specifically the CRV from what I have seen, repeatedly has failed tests of the AWD system. It is really poor at sending power to the rear wheels when the front lose grip.
  19. Jun 8, 2018 at 4:49 AM
    #119
    bv8ma
    Bill
    MA
    2017 TRD OR
    I haven't had a 4wd in a while but my last car was the AWD Taurus SHO and that thing was terrific in the snow, even when it didn't have ground clearance it didn't matter.
  20. Jun 8, 2018 at 4:55 AM
    #120
    Pine State
    Maine
    Ultimately it comes down to tires above all else. A Fwd car with snow tires will be quite a bit more stable in snow than an AWD or 4WD with all season.
    bv8ma[QUOTED], MIDSIZED13 and RocTaco like this.
