Truck seems a little squirrely at highway speeds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyotadude5, Jan 9, 2010.
  1. Jan 9, 2010 at 2:42 AM
    toyotadude5
    toyotadude5 [OP] Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    So heres the info.
    I have a 2008 access cab 4x4. It does have a 3 inch spacer lift with rear aal. Tire size is 285-70-17 bfg all terrain. also has 1.25 spidertrax spacers, and it has been alligned.
    But when driving on the freeway it seems to sway back and forth. It drives straight , so i know its alligned, but it just seems like it swings left and right a little bit.
    Anything to fix this? or anyone identify the problem?
    Thanks, Chris
  2. Jan 9, 2010 at 3:20 AM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    I'm guessing that you need upper control arms. With your wheels being further out, the caster making your wheels ride on the outside of the tire after the lift all contribute to less of your wheels under the truck touching the ground. Try walking fast on the outside of each foot... you're less stable and you look funny doing it. :p
  3. Jan 9, 2010 at 6:06 AM
    jward2331
    jward2331 Well-Known Member
    Fleming Island, Fl
    '08 PreRunner SR5 TRD Sport
    Debadged, tinted windows, upper/lower Grillcraft (horns relocated), Hella 500's with HID Mod (55W 5000) behind grill, shorty antenna, WeatherTech side window deflectors, suspension TSB, Westin Signature Nerf bars, JVC KD A-615 Head Unit with Sirius Direct tuner, Blacked out headlights, DTDL Mod (Switch for on/off), Hard Wired GPS, NOKYA Arctic Hyper Yellow Fog lights, Fog lights on anytime Mod, Michelin LTX M/S2 (P265/65R17), Powder coated OEM wheels. LED ANZO tail lights, Weather Tech FloorLiners.
    I don't have any lift dtuff installed on my truck (TRD Sport) and notice swaying with mine. The trucks are high to begin with and experience movement with any kind of wind on the highway. Just my thoughts.
  4. Jan 9, 2010 at 6:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2 on the UCA's. but.....Camber makes the tires ride on the sides......not Caster. :eek:
  5. Jan 9, 2010 at 6:14 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yup....UCAs. And keep in mind the higher CG of the 4x4 and PreRunner suspensions can make for a bit more wobble.
  6. Jan 9, 2010 at 6:24 AM
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    Try different tire pressure. (I assume you checked it.) My recollection is that Toyota specifies higher pressure in the rear - probably to meet requirements for a full load. If you are not traveling fully loaded most of the time, you could drop that to match front tire pressure. You could also try going up a couple pounds or down a couple pounds. The changes are subtle, but I'm supposing the squirreliness is subtle as well.
    It's also possible you have a bad tire. You might be able to mitigate that by swapping tires front to back (or perhaps make it worse. ;) ) Maybe it's just an aggressive tire tread that is better suited for off road than high speed applications.
    I wonder how much affect the lift and spacers have on alignment and stability. The alignment specs are designed to work with the suspension and tires in their original positions. Once that is changed, the factory alignment specs may no longer produce the desired results. In that regard, I'm in agreement with other posters who suggested alignment and/or modified UCAs.
  7. Jan 9, 2010 at 6:36 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x3 on uca......i got the same thing and im saving for mine.....
  8. Jan 9, 2010 at 9:19 AM
    DrRabbitFurHead
    Salem, VA
    Yeah, 6am typo on my part. Had to go chop down a tree so my buddy can heat his house!
  9. Jan 9, 2010 at 11:45 AM
    toyotadude5
    chris
    Flagstaff, az
    damn i figured i would need aftermarket uca's. Whats a good uca, for a decent price?
    Also what tire pressure does everyone suggest to be running all around for just every day driving.
  10. Jan 9, 2010 at 4:32 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Tire pressure is gunna kinda depend on your tire and size... Myself I run about 31-32psi (maybe a bit on lower side, but to me it feels more stable and handles better).
  11. Jan 9, 2010 at 4:57 PM
    lightfire
    lightfire Well-Known Member
    Mine is stock except for 265/75 tires. I notice a sway quite a bit. It was worse before I changed tires. I do not have any sway in my '93. Very sensitive to wind. Would better shocks like 5100's help this?
  12. Jan 9, 2010 at 5:07 PM
    SoCaliSnowboarder77
    SoCaliSnowboarder77 Well-Known Member
    Joe
    Valencia, Ca
    09 GSXR 600 & Snowboarders Hauler
    4x4 OFF-ROAD... that is all I need...
    my Coma is stock and I drive 100mph once in a while and it drives like my old 2007 Accord coupe. That is one reason why I don't want to mess with the suspension.
  13. Jan 9, 2010 at 7:44 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Doing your lift with spacers increased the tendency to sway. New UCAs will help but the blocks raise the weight of the body above the point that the suspension is designed to control back and forth movement.
  14. Jan 10, 2010 at 5:16 AM
    2010TACO
    2010TACO Active Member
    Fort Worth TX
    2010 PreRunner SR5
    It is funny you mention this swaying/drifting issue, my 2010 does the same thing on the highway. I never felt anything like this before, unless something was shot in the front end such as control arm bushings. I am surprised how I have to fight to keep correcting the steering as though the truck has a mind of it's own, which I know it does but it is brand new.
  15. Jan 10, 2010 at 6:02 AM
    MurphyZ
    MurphyZ Well-Known Member
    I HATE SPICYTACOS
    Alaska
    97 4runner, 08 Tundy
    89 SAS 3.4 1st gen 4runner- Sold 3.4 swap cut hood for clearance exhaust x-over and magnaflow muffler lockright in the rear SAS 83 toy axle (Wab-Fab) 4xinnovations sliders roof rack from 2nd gen for kayak.
    +1 i had the same on my 06 after a tough country lift. you need the UCA's.
    side note if you get into a side wind on the freeway the truck can catch alot of that and cause it to sway. moving with a full load to Louisiana from Oregon. i must have looked like i was drunk going across Nevada.
  16. Jan 10, 2010 at 6:04 AM
    flyingface
    flyingface Well-Known Member
    Zach
    Auburn, AL
    2013 MGM DCLB TRD Sport 4x4
    Soon....
    I really like my Light Racing UCAs...they have lots of adjustability.
  17. Jan 10, 2010 at 6:10 AM
    lightfire
    And I ask again, since mine is new and does the same thing, does anyone know or have an idea that upgraded shocks would make any difference in this?
  18. Jan 10, 2010 at 6:28 AM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    I heard that this is a common complaint with running spacers and I just got some too :( Can't afford the UCA's right now and my tires rubbing were annoying me.
  19. Jan 10, 2010 at 6:34 AM
    jandrews
    '09 FourDubDee TRD OR
    UCAs, and get that spacer lift the hell out of there and replace it with a suspension lift. I've never known spacers/blocks to help anything.
  20. Jan 10, 2010 at 6:54 AM
    JDCPA
    Jim
    SW FL
    What he said.
