Truck shake while braking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacosfordaysndays, Apr 16, 2022.
  1. Apr 16, 2022 at 7:17 AM
    Tacosfordaysndays
    Tacosfordaysndays [OP] Member
    18 taco sr5
    Bed rack with rtt
    Looking to see if anyone else had the rear of the Tacoma up on jack stands and spun a tire? Does yours sound like a horrible gear mesh/gap clunking noise when you spin one tire? I've been battling a horrible truck shake while braking. Rotors on front replaced, no change.checked runout on rotors, under .002". Rear drums replaced, it got worse. Changed the drums again and went back to the same level of shake. If I apply emergency brake while moving the shake is present so that's really leading to the rear obviously. I have noticed that there is a huge amount of rotational play from the drum to the wheel studs, but no up and down movement. Wheel bearing seems good. I do have a surging while at highway speeds if you approach in incline and accelerate a little but not enough to downshift, I think that's completely separate though. I'm thinking of draining the rear dif fluid and checking it just to make sure it looks clean. Going to check torque on rear suspension components today but I'm really growing tired of this truck. Checked rear axle run out and it's under .002. Any suggestions is welcomed please. Kind of our of patience with this truck now.
  2. Apr 16, 2022 at 8:24 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    It sounds similar to warped brake drums my old tundra had in warranty, but they replaced the star adjusters in the drum also.
  3. Apr 16, 2022 at 8:31 AM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    Stuck caliper piston is what caused my braking issue
  4. Apr 16, 2022 at 8:39 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  5. Apr 16, 2022 at 11:03 AM
    Tacosfordaysndays
    18 taco sr5
    Bed rack with rtt
  6. Apr 16, 2022 at 12:04 PM
    Tacosfordaysndays
    18 taco sr5
    Bed rack with rtt
