Truck shakes during and after heavy rain
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cryceratops, May 23, 2012.
  1. May 23, 2012 at 6:32 PM
    Cryceratops
    Cryceratops [OP] Active Member
    Greenville, NC
    2001 Manual 4x4 5VZ-FE
    Like the title says my truck shakes when I'm idling or driving during heavy humidity. Any idea what it could be? I read some and found it may be the spark plugs but they were replaced about 15k miles ago.
    Hope you all can help out!
    <--- My truck specs
  2. May 23, 2012 at 6:55 PM
    webb323
    webb323 Well-Known Member
    Jordan
    Tennessee
    97 4x4 Regular Cab (sold), 2014 Double Cab TRD Sport
    plug wires
  3. May 23, 2012 at 7:03 PM
    Cryceratops
    Greenville, NC
    So you think they've gone bad already?
  4. May 23, 2012 at 7:05 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    if the rubber begins to dry out it will lose the seal against the plug, causing the moisture in the air to get inside the wire and ruin the electrical connection with the plug
  5. May 23, 2012 at 7:13 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    Had a similar problem with an old truck, when it rained it idled roughly. Basically when any one (or More) spark plug don't fire. In my case the problem was not the spark plug, it was the spark plug wires which were cracked. Current will always follow the path of least resistance. If the rubber coating of your spark plug wires are cracked, on a humide day the current may go to ground before it gets to the spark plug.
  6. May 23, 2012 at 8:10 PM
    Cryceratops
    Greenville, NC
    I'll make sure to check them tomorrow morning or whenever it stops raining. Thanks guys. I just needed to make sure that it was most likely either the wires or the plugs. I have an 01 so it shouldn't even have plugs right?
  7. May 24, 2012 at 4:14 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) If you do change your spark plug wires, you need to buy some Di-electric grease for the wires and apply the grease to both ends of the wire before you apply them to the engine. The grease will displace any water and prevent water from shorting the wires at the connectors in the future. It will not fix bad or broken wires, but you can apply the grease to the ends of old wires to protect them. You do not have to wait for new wires to use Di-electric grease.
  8. May 24, 2012 at 9:59 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Im not positive but this is the first thing that came to mind for me... could there be water getting to the MAF?
  9. May 24, 2012 at 10:03 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    distributer cap, do you have those on the first gens? if you do that's what it is. used to happen on an older nissan pickup i had because it had a small crack in it
  10. May 24, 2012 at 3:59 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    next rainy night or very humid night pop the hood while the engine is running and see if there is a lightshow going on under there
  11. May 24, 2012 at 7:37 PM
    Cryceratops
    Greenville, NC
    Will do guys! I'll get back to you all when it rains again... shouldn't be too long hah. In the mean time I'll be changing the spark plugs still debating about the wires.
    -Actually just checked the humidity and it's at 88% and there was no arcing at all. I guess that's a good thing.
  12. May 26, 2012 at 2:06 PM
    Cryceratops
    Greenville, NC
    Just changed the spark plugs, cleaned the throttle body and MAF. Added TRD Throttle Body O Gasket too.
    I pulled out 6 NGK single electrode spark plugs :mad:
    My brother in-law that gave me the truck always took it to a shop.
    So this time I put in 6 Denso K16TR11's :cool:
    Hopefully this will help during the next torrential downpour (only happens during those times.)
  13. May 26, 2012 at 8:32 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    1995.5 to early 1997 had distributors. My 1997 didn't have a distributor but some did. No way an 01 has one.
