Truck shakes when braking
Discussion in '1st Gen. Tacomas (1995-2004)' started by toyotadan98, Jan 1, 2013.
  1. Jan 1, 2013 at 5:26 PM
    toyotadan98
    toyotadan98 [OP] Well-Known Member
    wa
    2011 TRD OFFROAD 4X4 ACC
    I just installed a 2 inch front and 1 inch rear lift with bilstein 5100,s on the rear, It sure looks better:cool: but anyway i was driving it today and noticed that when i would hit the brakes at 50 to 60 mph my truck would shake like my rotors warped or something but they are new and it didn't do this untill i put the lift on any ideas what would cause this???? i don't want to remove it after 100 plus dollars. Thanks :confused:
  2. Jan 1, 2013 at 5:34 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    Extra fog lights behind grill, Pro Form rubberized undercoat, Fog lights on w/ high beams mod, Lighted 4wd switch, Husky Liners, 12v always on, Yellow wire mod, DEVIL HORNS BABY!! OME 886's Nitrochargers w/ 1.5" AAL with 1" lift block, Redline hood struts, front/rear winch wiring, Blue Sea systems Fuse Block, Spidertrax spacers, Wet Okle seat covers, ECGS front diff Bering Replacement Are LR UCA's right for me???
    1) Is your alignment done correctly.
    2) Get under your truck and check that everything is tight, and that your lug nuts are tight.
    3) that's weird,
  3. Jan 1, 2013 at 5:36 PM
    10DC4x4
    10DC4x4 Well-Known Member
    changes your brake rotors . They are wearing unevenly.
    FJ to Taco likes this.
  4. Jan 1, 2013 at 5:37 PM
    janelle2388
    janelle2388 Well-Known Member
    Corey
    Montana
    09 tacoma access cab SR5
    3 inch icon lift, dual exhaust, 17 inch pro comp rims, tinted tail lights, black badges, BHLM, T-Rex eye lids, 10" alpine type R sub, alpine deck, alpine amp, K&N CAI, icon UCA's, 2" AAL, 32" led light bar
    might sound stupid but start cheap and easy, go back through what you did make sure everything is as tight as it is supposed to be and put in properly. thats what i would do.
  5. Jan 1, 2013 at 5:38 PM
    IgnorantlyAlberta
    IgnorantlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Its broken buy a new one.
    Seriously though.
    Check your lugs!!!
  6. Jan 1, 2013 at 5:39 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    wut 2" lift at the front ?
    I'd fairly suspect the additions recently added.
    * an alignment would be top priority, post suspension changes.
  7. Jan 1, 2013 at 5:53 PM
    toyotadan98
    wa
    It has new rotors and pads on the front , i will double check everything and make sure everything is tight. It didn't do this untill i put the lift in this weekend. Thanks,:confused:
  8. Jan 1, 2013 at 6:40 PM
    obscurotron
    obscurotron Well-Known Member
    Bay Area, California
    '14 DCSB 4x4
    Did you overtorque the lug nuts? 83-85 ft-lb is all they need. Excessive lug nut torque can cause the rotors to warp on vehicles where only the caliber and the lugs keep them captive.
  9. Jan 1, 2013 at 6:51 PM
    toyotadan98
    wa
    torqued all lugs to 85 ft lbs. Truck drives great just shakes when the brakes are applied at high speed like 50 or 60 not at slower speed ????? Now when i say shakes it feels like a warped rotor but it didn,t do it on saturday before i put the lift in saturday afternoon and sunday morning before the seahawks game:D I will check everything again twice. Thanks. Go Hawks:D
  10. Jan 1, 2013 at 7:24 PM
    WuTang
    WuTang Well-Known Member
    SOMD
    2000 Tacoma v6 5 speed 4x4
    Deckplate Grey wire 2" Spacer lift 32's Retrofit
    Maybe you need a bpv bracket? It could be a tie rod, or you may have some play in the rack
  11. Jan 2, 2013 at 5:40 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    New rotors can still warp if you heat and cool it really fast like drive and brake all day and then didn't think about it and wash your truck and cool the rotors. Most time when I brake and the steering wheel vibrates and shakes its a warped rotor.
  12. Jan 2, 2013 at 7:00 AM
    toyotadan98
    wa
    Thanks for the opinons. I will figure it out it only started when i put the lift in the other day.
  13. Jan 2, 2013 at 9:04 AM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    Take it to the alignment shop, ASAP. You likely changed camber, or something else.
  14. Jan 2, 2013 at 10:43 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Camber would not cause vibration when braking. Incorrect toe MIGHT, and Caster can. Alignment would be something to have checked anyway after installing a lift or making changes in the suspension system.
