Truck shakes when idling.
Discussion in '1st Gen. Tacomas (1995-2004)' started by sir1123, Oct 3, 2012.
  1. Oct 3, 2012 at 8:30 AM
    sir1123
    sir1123 [OP] Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    Hello everyone. So my truck has done this shimmy/shake thing in idle for a while. I have replaced plugs and cleaned tb. It does it worse when the a/c is on and truck it in idle. I don't really know what it could be. Maybe a vacuum leak? Not sure where to go. Besides from the shaking in idle the truck runs great.
  2. Oct 3, 2012 at 8:33 AM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    Notice the tach next time, where's it idling at? My car has a similar problem after some major engine work and I know that's its caused by the idler not being re-tuned.. Not actually a big issue other than that it causes the vehicle to feel rough at idle... May not be your problem but worth looking into!
  3. Oct 3, 2012 at 8:40 AM
    TACO3
    TACO3 Deer Dropper
    Aaron
    VA
    03 tacoma 4wd 4 banger
    maybe fuel pump? my dads truck did this.. an maybe air filter :notsure:
  4. Oct 3, 2012 at 8:43 AM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Mine does the same thing
  5. Oct 3, 2012 at 10:11 AM
    sir1123
    Charleston
    My idle with no ac is 680-710 rpm. With ac on it is 840-860 rpm. And what exactly is the idler?
  6. Oct 3, 2012 at 10:19 AM
    NewRider
    Travis
    '87 4runner
    I'd have to look up the specs for the trucks but that sounds pretty low and would cause the engine to shake as if it was going to stall.
    The idler is pretty much what it sounds like like, a computer that keeps the engine running at a correct minimum rpm while the vehicle isn't moving. If its not adjusted properly it can make the engine run fast or slow. In your case I'm guessing slow which causes the vehicle to shake when at rest.
  7. Oct 3, 2012 at 10:21 AM
    sir1123
    Charleston
    Why would a computer go out of tune. Never had any work done to truck.
  8. Oct 3, 2012 at 10:28 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    A vacuum leak is possible, but if it runs great everywhere above idle, it sounds like a throttle body or MAF sensor cleaning is in order. How many miles are on it, and has this cleaning ever been done before?
  9. Oct 3, 2012 at 10:59 AM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Shes cammin!! lol I loved how those old 70's fords and chevys had that rough idle that shook the bed side to side.
  10. Oct 3, 2012 at 11:01 AM
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    how violent is the shaking? Mine has just a very slight shake at idle, but it is not constant. Just wondering if I should also be concerned. Mine idles at around 700 give or take
  11. Oct 3, 2012 at 11:32 AM
    sir1123
    Charleston
    Cammin? And the shake is not bad just feel it through the steering wheel and floor. It is like the motor just wobbles for a sec then hats better then wobbles again. And I have replace maf. And cleaned it once. I have 224 k on it and I have cleaned the tb only a little when I replaced my valve covers a while ago but just sprayed a bit of cleaner in it. It didn't look real dirty if I remember correctly.
  12. Oct 3, 2012 at 11:34 AM
    sir1123
    Charleston
    I guess I will clean the maf and tb tonight and see how she does. My truck isn't sputtering or anything just a wobble I can feel at idle
  13. Oct 3, 2012 at 11:41 AM
    pippen
    Pippen
    Eastern NC
    04 PreRunner Ext.
    I was just messing with ya man, camming is when someone has a mild/larger cam in a engine and it makes it run at low rpm at idle and shake alot, not your problem though! I dunno what to say except check vacuum lines for leaks http://www.popularmechanics.com/cars/how-to/maintenance/how-to-find-a-vacuum-leak
    I dunno if theres another way of doing this. I've yet to Seafoam my engine, you might look at some posts on here about that https://www.google.com/#hl=en&safe=off&output=search&sclient=psy-ab&q=site:tacomaworld.com+seafoam+1st+gen&oq=site:tacomaworld.com+seafoam+1st+gen&gs_l=hp.3...1956.12492.0.12809.40.38.2.0.0.0.193.2914.33j5.38.0.les%3B..0.0...1c.1.P1Uxej3eeEk&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.&fp=4c814b5607df3525&biw=1024&bih=653
  14. Oct 3, 2012 at 11:41 AM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    hows the motor mounts?
  15. Oct 3, 2012 at 11:49 AM
    sir1123
    Charleston
    Well they are 224,000 miles old but still solid. No deterioration. I checked those a while ago thinking that was the problem
  16. Oct 3, 2012 at 11:52 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    pull the idle air control valve and clean it well. its on the throttle body
  17. Oct 3, 2012 at 11:56 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    My truck shakes at idle too :anonymous:
  18. Oct 3, 2012 at 12:37 PM
    BamaToy1997
    Bill
    Navarre, FL
    ^^^ What 2000GTacoma said. The "Idler" mentioned earlier is actually more commonly called the IAC or Idle Air Control valve. Before you cleaned your throttle body the computer (ECM) had calculated the correct position for the IAC based on a dirty throttle body. When you clean the throttle body, it will sometimes fail to correct itself the other direction, and can cause a rough idle. The easiest way to force the computer to relearn is to wipe the memory. you can do this two ways: disconnect the negative(ground) terminal from the battery and allow 30 minutes for the capacitors in the vehicle to discharge, or if you have access to a quality scan tool you can go into the system that way and force a re-learn.
    Some people suggest to disconnect the battery and short the terminals together. This is not a good idea on late-model vehicles. The reason for this is because these vehicles have a DERM module that is part of the airbag system. This DERM has a built in, non-rechargeable battery. There have been cases where shorting the battery terminals have discharged the DERM's internal battery. A discharged DERM battery can cause a failure of the airbags deploying in certain types of crashes. So never use this cable-shorting method to discharge the battery.
    After you have allowed the systems to clear out their memory, you can reconnect the battery terminal and restart the truck (It may stall once or twice when you first start it up) after the truck has started, let it idle in park or neutral with the AC off for 60 seconds. After that, turn on the AC and let it idle an additional 60 seconds before putting it in gear. This normally will learn the IAC new position the fastest.
  19. Oct 3, 2012 at 12:48 PM
    sir1123
    Charleston
    Ok so does the iacv come off the tb?
  20. Oct 3, 2012 at 12:49 PM
    sir1123
    Charleston
    Whoa thanks for the info. Will do this too.
