Truck shakes when idling.
Discussion in '1st Gen. Tacomas (1995-2004)' started by sir1123, Oct 3, 2012.
  1. Oct 3, 2012 at 12:50 PM
    sir1123
    sir1123 [OP] Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    I am going to do some cleaning in a few hours and post the results. Thanks everyone
  2. Oct 3, 2012 at 12:56 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    This gets my vote, hands down. Just because motor mounts "look" good doesn't mean that they are tightly holding your engine as solid as they did when they were new. Not broken or crumbled? Great. Doesn't mean that they aren't so worn out that they have more given than normal though.
    If the engine is running smooth otherwise, I'd put my money on motor mounts.
  3. Oct 3, 2012 at 1:04 PM
    sir1123
    Charleston
    I defiantly should invest in this in will but the motor rpms do change and you can hear that slightly through the exhaust note at idle. Do you have to have a motor lift to do this job?
  4. Oct 3, 2012 at 1:36 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Yea I would think so, jacking it up from the oil pan will be too much *I* think. I've jacked up a engine partially to remove a motor mount on one side of a large v6 on my old Mitsubishi to get to the timing belt, the oil pan took it well. But to jack a whole engine up from it..nah. There may be a good way to do this without a engine lift but I am not aware of it.
  5. Oct 3, 2012 at 1:43 PM
    sir1123
    Charleston
    I will do some research
  6. Oct 4, 2012 at 10:49 AM
    sir1123
    Charleston
    So I didn't have time to take the tb off for a deep clean but sprayed it as well as I could and the maf. I also reset the computer. Seems to idle much better now. Still have a little vibe but I believe that is just worn out motor mounts and all. Thanks for the help guys. When I do my other vc I will do a deep clean with the tb.
  7. Oct 29, 2012 at 10:17 AM
    Dcpsychobilly
    Dcpsychobilly Well-Known Member
    Aurora Colorado
    04 dbl cab Taco
    Bumpers, skids, lights and more lights, trail gear bumper, sliders, front kings, dakar lift leaf springs rear, corbeau seats
    I got a similiar problem Im trying This ^^^^
    Sir1123 Any update?
  8. Oct 29, 2012 at 10:37 AM
    Madjik_Man
    Colorado Front Range
    Mine does this all the time too, when sitting at idle.
    It's probably the IAC.
    I cleaned the MAF and TB but didn't do the IAC at the time. I reset my ECU and it still intermittently shimmies or shakes for a split second (typically rpms drop) then regains a normal idle.
  9. Oct 29, 2012 at 2:33 PM
    Dcpsychobilly
    Aurora Colorado
    04 dbl cab Taco
    now Im not sure what it is, I did what bamatoy1997 suggested, my UG showed at stop I was In the 550s now after doing that im at 600s and up, so it reset the idle higher, the shake is less. :confused:It could have somehow lowered its rpms at (stop/in gear) idle, now reset itself to a more normal range Ill watch if it is better or needs more attention.
  10. Oct 29, 2012 at 3:00 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    My thoughts exactly, as my 2000 2.7 PreRunner also has a noticeable vibration at idle. I think it's collapsed motormounts allowing more of the normal vibration to be transmitted to the body via the frame.
  11. Aug 19, 2015 at 9:07 AM
    Mariotaco
    Mariotaco Well-Known Member
    Mario
    El Paso, Texas
    11 SR5 4x4
    The seats and the stick shift (6 speed) vibrate slightly while idling, is this normal?
    specter208 likes this.
