Truck shaking 55-85mph... why?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kmedei, Jan 13, 2024.
  1. Jan 13, 2024 at 7:07 AM
    Kmedei
    Kmedei [OP] New Member
    2015 Tacoma access cab (base model)
    My truck (2015 tacoma) shakes (dramatically so in the steering wheel) at certain speeds. With summer tires it occurs at 65 to 85 mph and with winter tires it starts at 55mph. There is a subtle increase in shaking when I brake/slow down, but it's quite subtle. In attempt to fix the problem I have had the tires rotated, aligned, and rebalanced (both the summer and winter tires) and replaced the carrier bearing that seemed a bit loose. I'm at a loss of what the problem could be. Thoughts? Thank you!
  2. Jan 13, 2024 at 7:10 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    Any accident history?
    Kmedei[OP] likes this.
  3. Jan 13, 2024 at 7:15 AM
    IronMaidenJapan
    IronMaidenJapan So old I fart dust
    Lizardville
    23 TRDOR
    Could be several things… Warped rotors, wheel bearings… You gotta start kicking and wiggling things and you’ll find it…
    Kmedei[QUOTED][OP] likes this.
  4. Jan 13, 2024 at 7:17 AM
    BradyT88
    BradyT88 Well-Known Member
    Does it get dramatically worse if you push the brakes pretty hard? Not quite stomping on them but slowing down in a hurry. If so then that sounds like warped rotors to me. If not then I'd look closer at the wheel bearing as IronMaidenJapan suggested above.
  5. Jan 13, 2024 at 7:24 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Carrier bearing?
  6. Jan 13, 2024 at 7:27 AM
    Kmedei
    No history of accidents
  7. Jan 13, 2024 at 7:28 AM
    Kmedei
    Already replaced and the problem persists :/
  8. Jan 13, 2024 at 7:32 AM
    Kmedei
    Not dramatically, no. I had kept an eye out for this previously and noticed a subtle increase when braking/slowing.. but it's very subtle.
    Thanks for your thoughts!
  9. Jan 13, 2024 at 9:26 AM
    Micah831
    Micah831 I drive a Taco but work on VW's
    Micah
    San Jose
    13 Tacoma PreRunner
    Pavement Princess
    I always start with the easy stuff. No shaking until highway speeds i would check tire balance first if its not under braking. If its under braking most likely warped rotors
  10. Jan 13, 2024 at 9:52 AM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    You mentioned you have summer and winter tires. Are they mounted on OEM rims or aftermarket? OEM rims are hub centric. Many aftermarket are not. Tacomas get finicky about balance if the rims are not hub centric.
    Kmedei[OP] and Jimmyh like this.
  11. Jan 13, 2024 at 9:55 AM
    Woodythebluetaco
    Woodythebluetaco Well-Known Member
    2016 Tacoma SR5 Blazing Blue
    Stacked plate transmission cooler Front: Custom Fabtech 2.25 Resi Coilovers, King springs, Eibach Tenders Rear: Fox 2.0 Resi, Custom OME Dakar Leafs, Caltracs Rebuilt 3.5
    Check driveshaft is properly lubed? Same with the spicer joints? When I get vibration at highway speed that’s not wheels, rotors or suspension bushings it’s usually driveshaft lube related.
  12. Jan 13, 2024 at 12:08 PM
    krue92
    krue92 Well-Known Member
    Nebraska
    I had a similar issue that was around 50-60mph and I replaced my u-joints to fix the issue. Carrier bearing was already done prior to them as well.
