Truck Shaking--Cylinder Problem?
Discussion in '1st Gen. Tacomas (1995-2004)' started by gatrapper, May 3, 2016.
  1. May 3, 2016 at 5:00 AM
    gatrapper
    gatrapper [OP] Well-Known Member
    Senoia, Georgia
    1998 SR5 4x4
    Hey Y'all,
    The other day I was in the drive through at Chik-Fil-A and I started to get a lot of vibration from the front of my truck. After a minute or two it stopped.
    This morning I'm headed to work and my truck started to shake pretty good. I pulled over because I thought I might of had a flat tire and everything was good. When I started the truck back up my engine light came on and the shaking started again.
    I plan on dropping the truck off at the shop after work. I was either thinking that its something with my cylinder or spark plugs.
    What are yalls thoughts?
  2. May 3, 2016 at 5:34 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Bet it's a coil pack or wire. They will tell you.
  3. May 3, 2016 at 5:59 AM
    gatrapper
    Senoia, Georgia
    1998 SR5 4x4
    Is that a simple fix?
  4. May 3, 2016 at 6:01 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    You sure it's not just a tire out of balance? Was the vibration proportional to your speed?
  5. May 3, 2016 at 6:26 AM
    GA-3RZFE
    GA-3RZFE Well-Known Member
    2000 Taco 2.7L 3RZFE SR5 manual
    Complete rebuild at 197k miles
    If it was a coil pack, bad spark or misfire the CEL should have been flashing. Generally speaking, a flashing CEL on almost any vehicle indicates a misfire that can be caused by a number of problems. At idle, it could be the IAC or a vacuum problem causing the "rough idle". If you turn off the AC does it appear to idle better? If it didn't have a CEL that was flashing, it could be a simple as the MAF needs to be cleaned or the truck is running lean. You need to get the code scanned and let us know what code it is throwing.
    Brie and eon_blue like this.
  6. May 3, 2016 at 6:28 AM
    gatrapper
    Senoia, Georgia
    1998 SR5 4x4
    It's not a tire issue because I still have the shaking even when I am not moving.
  7. May 3, 2016 at 6:29 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    When my old '98 had misfires, the check engine never flashed, but it was steadily lit. Changed the plugs and it was fine. I've never seen the check engine light flash on and off on these trucks. With first gens at least.
    bicklebok and GA-3RZFE[QUOTED] like this.
  8. May 3, 2016 at 6:31 AM
    GA-3RZFE
    That is odd. My 2000 flashed when I had a similar problem. If that is the case, then it may very well be a coil pack. I had an 02 F150 that had a bad coil (intermittently) and caused all kinds of problems.
    Brie likes this.
  9. May 3, 2016 at 6:32 AM
    gatrapper
    Senoia, Georgia
    1998 SR5 4x4
    My check engine light is staying lit.
  10. May 3, 2016 at 6:49 AM
    GA-3RZFE
    It may be a misfire. I have no experience with any imports prior to my 2000 taco. Everything else I have had (mustangs) would flash the CEL if it found a misfire. With that said, take it to Autozone/etc, they will pull the codes for free. let us know what you find and someone on TW can probably help you with what to check.
    DustStorm4x4 likes this.
  11. May 3, 2016 at 7:23 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    x2 find out what the code is.
    Brie likes this.
  12. May 3, 2016 at 9:07 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    The code Luke..........Go get the code. The Force and the code are one in the same fellow Jedi.
    Brie likes this.
  13. May 3, 2016 at 9:14 AM
    eon_blue
    Azusa, CA
    Yeah that's what I'm dealing with right now (and it's a nightmare)...a lean fuel system. Truck runs fine, maybe idles a bit rough, but with a lean fuel system you could seriously end up damaging a piston if you don't get it taken care of. Could be anything from a bad/dirty MAF or o2 sensor, clogged injectors, leak in a vacuum line, cracked exhaust....
    Brie likes this.
  14. May 3, 2016 at 4:49 PM
    gatrapper
    Senoia, Georgia
    1998 SR5 4x4
    Dropped the car off at the shop. The computer said misfire on cylinder 1. He said he was going to take a look at the spark plug and wires. Could it be the fuel pump?
  15. May 3, 2016 at 6:31 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    It's most likely the coils and wires.
    Brie likes this.
  16. May 4, 2016 at 7:58 AM
    gatrapper
    Senoia, Georgia
    1998 SR5 4x4
    I'm hoping it's something simple like that.
  17. May 10, 2016 at 12:07 AM
    Brie
    Brie Well-Known Member
    Brieanna
    CA
    2001 Tacoma TRD, Prerunner & 2016 Taco Sport
    Well, was it?
  18. May 10, 2016 at 11:05 AM
    Goldtaco99
    Goldtaco99 Member
    99 Gold TRD Tacoma
    3 inch toytec spacers 33 12.50s on steel wheels
    My buddy had a 96 Tacoma that started missing due to plugs and wires but the engine light only flashed once time after about an hour of driving although it was missing constantly.
    Brie likes this.
  19. May 10, 2016 at 1:40 PM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    I just had this on a 98 2.7 (with coil packs)it was plug wire boot jumping down in the hole by the spark plug
    Brie likes this.
  20. May 14, 2016 at 2:17 PM
    Swamp Cop
    Swamp Cop New Member
    My '06 is having a similar problem. At around 40 mph, under light acceleration, the engine occasionally misses. CEL came on and the code was for a misfire on cylinder 4. I replaced all plugs and coil pax and still have the same problem. Took it to the dealer, and they said it was a bad coil pack, but I'm not buying it (Just replaced them). The CEL doesn't come on any more, but the problem persists. I'm thinking a bad fuel injector? Any thoughts?
    Brie likes this.
