Truck Shaking from 60-70. Replaced a ton of parts. Help Please!
Discussion in '1st Gen. Tacomas (1995-2004)' started by CayucosTacoma, Feb 3, 2016.
  1. Feb 3, 2016 at 7:49 PM
    CayucosTacoma
    CayucosTacoma [OP] Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    So have a 1998 3.4 4x4 Manual truck that shakes from 60-70 on the freeway.
    Has been shaking ever since I bought the truck.
    Truck is lifted on DR coil overs and Total Chaos Upper Control arms.
    Alignment was in spec.
    Rear has a custom Cantilever SUA set up.
    1" Body Lift
    Recently went through and tried to cure the shaking by replacing
    -Lower Ball Joints
    -Tie Rods
    -Steering Rack
    -Steering Rack Bushings
    -Carrier Bearing
    -Both U joints on the rear drive shaft(Didn't do the double cardan joint)
    -Upper Control arms have newish uni balls
    -Greased Front Drive shaft, and rear as well
    -Alignment done recently
    -Tires Balanced recently
    The shaking is one that shakes the whole truck, not so much the steering wheel.
    Been chasing this for a while and at a lose.
    Read quite a few threads on TW too..
    If anyone has any suggestions that'd be great!
  2. Feb 3, 2016 at 8:56 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    im thinking u-joints associated with this "cantilever SUA" setup.
    dafuq is a "cantilever SUA"?
  3. Feb 3, 2016 at 9:02 PM
    CayucosTacoma
    2004 Double Cab 4x4
    Rear Long Travel Set up
    SUA=Spring Under Axle
  4. Feb 3, 2016 at 10:25 PM
    CodeSeven
    Serge.
    Coachella Valley
    holys shit what the fuck is that monstrosity?!
  5. Feb 3, 2016 at 10:28 PM
    CodeSeven
    Serge.
    Coachella Valley
    im thinking that is an issue. I cant see where the shocks are actively playing an affect on the "hits" that suspension typically dishes out. maybe air them up to max? or add some temp shocks to see what happens.
  6. Feb 3, 2016 at 10:34 PM
    Yotamac
    Yotamac Well-Known Member Vendor
    Ze
    562- Cerritos, CA
    07 PreRunner
    Stuff, stuff and more stuff
    Nice set up.. Have you had your wheels balanced... you'd be surprised how much a difference it can make..
  7. Feb 3, 2016 at 10:34 PM
    CayucosTacoma
    2004 Double Cab 4x4
    That "monstrosity" is a well engineered piece of equipment lol
    I don't see that being the issue as it was on a truck previous to mine without issue.
    My truck also shook before this was installed.
    The shocks damped by swinging on a pivot as the axle moves up and down.
    Atowns40 likes this.
  8. Feb 3, 2016 at 10:35 PM
    CodeSeven
    Serge.
    Coachella Valley
    yes he did
    yeah but..... but...... why?! do you even see this kind of setup on trophy trucks? I cant imagine a million dollar race truck would bother with something this heavy. I'd get rid of all that junk and put in some standard shocks.
  9. Feb 3, 2016 at 10:36 PM
    CayucosTacoma
    2004 Double Cab 4x4
    Thanks!
    Yea had the tires balanced the other week.
    Going to get them rotated and see if the vibration shifts to a different part of the truck.
    Replacing the front rotors and rear drums as they are warped.
    Going to make a CB drop, and pull the front drive shaft temporarily.
    Try to pin point the cause
  10. Feb 3, 2016 at 10:38 PM
    CayucosTacoma
    2004 Double Cab 4x4
    and for Travel Numbers. Can't pull the same travel numbers with standard bolt in shocks.
    Personally didn't want to cut into the bed and make a cage.
  11. Feb 3, 2016 at 10:45 PM
    CodeSeven
    Serge.
    Coachella Valley
    I mean... I dont know.... All I can think of when I see that setup is......
  12. Feb 3, 2016 at 10:47 PM
    CayucosTacoma
    2004 Double Cab 4x4
    Different Strokes for Different Folks.
    Just trying to chase these vibes :boom:
  13. Feb 3, 2016 at 10:47 PM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    Somebody's never heard of long travel it seems.....
  14. Feb 3, 2016 at 10:48 PM
    CodeSeven
    Serge.
    Coachella Valley
    long travel wut?
  15. Feb 3, 2016 at 10:51 PM
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    When you had the tires balanced were they road force balanced or just a normal balance? Sometimes having a set of tires road force balance can help get rid of lingering vibrations.
    Yotamac likes this.
  16. Feb 3, 2016 at 10:51 PM
    Yotamac
    Ze
    562- Cerritos, CA
    07 PreRunner
    I had the crazy shakes until I got all new tires.. I dont have any shaking problems anymore.
    Maybe have them road force balance if possible
    looks like you have a troll haha good luck hamming out the issue bud!
  17. Feb 3, 2016 at 10:53 PM
    CayucosTacoma
    2004 Double Cab 4x4
    Not sure actually. Didn't know there was a difference honestly ha
    A buddy of mine was thinking tires too. I guess before I shell out money for drive shaft balancing I'll try to find someone local who can lend me a set of tires for a few hours
  18. Feb 4, 2016 at 5:05 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Same thing happened to me. My front end would vibrate between 60 - 75mph. It took 4 times of balancing and rotation. Sometimes they would get the vibration to go away for a half of a day sometimes 10 minutes or just as soon as I left the tire shop before they finally just replaced all 4 tires and now there is no vibration whatsoever. I didn't replace all those parts. They replaced the tires first and if that didn't work then replace parts. I also have Camburg UCA's with Bilstein 5100's on the bottom setting with Eibach 3" coils. Regular 5100's and a 1.5" AAL in the rear. Alignment was fine and so was the whole front end. That's why it was so hard to figure out what was going on. So we started with the most simple thing. Reject Tires! Good luck!
  19. Feb 4, 2016 at 5:38 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Put the truck up in the air and spin the tires. Look for out-of-roundness, bulges, knots and ETC. Even better is get it on a lift, start the engine and get it up to speed of vibrating.
  20. Feb 4, 2016 at 6:37 PM
    CayucosTacoma
    2004 Double Cab 4x4
    Borrowing a friends set of extra tires/rims.. try it out tomorrow
