Truck Shaking on highway
Discussion in 'Suspension' started by chaos316, Apr 26, 2012.
  1. Apr 26, 2012 at 12:42 AM
    chaos316
    chaos316 [OP] Well-Known Member
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    285/75/16 BFG KO2 Ditch Lights
    I have a DCLB sport 4x4 with a spacer lift, it shakes a lot! sometimes around 40mph, and a ton around 75 mph. Can anyone point me in the right direction? the only time i take my truck off road is when I go fishing, about once a twice a week, and its only about 20 mins total off road.
  2. Apr 26, 2012 at 12:47 AM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    How much lift is the spacer lift? I'm assuming you'll need after market UCAs either that or an alignment(if you recently installed the lift). When I bought my truck used it had spacers up front and I had the same problem. It wasn't the truck shaking but more of the steering wheel.
    EDIT Just saw your profile description..3" spacer lift. Still saying you need after market UCAs.
  3. Apr 26, 2012 at 12:55 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Most likely shaking comes from unbalanced tires....that was my case anyways! I'd make sure everything was torqued to spec, tires balanced/rotated and alignment......in that order. I had a spacer lift and alignment was good with stock uca's! The spacer was just stiff and shook the truck evertime it went over uneven road surface?
  4. Apr 27, 2012 at 9:49 AM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    I bought my truck used with everything on it already a few months ago. Mines kind of a mixture of both, the steering wheel shakes sometimes, and sometimes on the highway, the entire truck shakes. Its almost to the point where its scary to drive it
  5. Apr 27, 2012 at 9:59 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    You might want to have a mechanic look at it......where did you buy from? There could be something else going on that needs major attention!
  6. Apr 27, 2012 at 10:18 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2. If a simple alignment and/or rebalancing of the tires didn't do the trick, you should have a professional take a look.
    Did it shake when you bought it? Assuming you did a test drive correct? If you didn't get it up to those speeds at the test drive, it's anyone's guess what's causing the shake. If you put the spacer lift on yourself and then it started, it'd at least narrow your search.
  7. Apr 28, 2012 at 1:54 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    Once i bought it, it drove fine. But i decided to go mudding a few times and slammed on the brakes because we were about to slide into a massive ditch. if i bought ucas, would i have to buy coil overs as well?
  8. Apr 28, 2012 at 4:58 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    I'd get everything looked over first. Usually uca are needed when you lift in the 3"+ and can't get alignment where you want it! Something could be loose or bent from that situation?
  9. Apr 29, 2012 at 10:36 AM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    So take it to the toyota dealership? or go to an off road suspension place?
  10. Apr 29, 2012 at 10:37 AM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    and i noticed whenever i brake hard enough, theres a squeak/ grind type noise
  11. May 2, 2012 at 9:32 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
  12. May 2, 2012 at 9:40 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    If you are with warranty take it to Toyota but if not I would suggest going to someone you know who does good quality work. The toyota dealer that I took my truck to had my truck rear ended :mad: lucky they fixed it no questions asked.
    But you need to get your breaks looked at if they grind.
  13. May 2, 2012 at 9:42 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Get your tires balanced. If your front tires are off, they'll shack the steering wheel. Get your front end checked out. An alignment shop, if they're worth a damn, will check over everything before they align it. Loose TREs, BJs, etc...
    Wash your truck, if you got shit packed in the wheels it will throw off the balance, especially a lot of mud.
    BJs, wheel bearings, and TREs are easy to check if you know how but theres youtube tutorials for that.
    Yes, check the pads for wear on your brakes, the shoes, drums, and rotors as well.
  14. May 3, 2012 at 5:30 AM
    Pugga
    Massachusetts
    Yeah, what he said... :thumbsup:
