truck shaking when applying brakes down steep grade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brianwilk, May 22, 2012.
  1. May 22, 2012 at 2:40 PM
    brianwilk
    brianwilk [OP] Member
    san luis obispo
    2007 black toyota tacoma standard cab manual
    I've noticed that when I'm going down a steep grade and I apply the brakes my truck starts shaking. It feels like the brakes are not being "grabbed" properly for some reason. my speed is about 60 Mph which is the speed limit and certainly not speeding for the highway. Anyone have any suggestions because the truck definately doesn't feel safe when it's doing that.
    Thanks...
  2. May 22, 2012 at 2:46 PM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    I'm thinking warped rotors.
  3. May 22, 2012 at 2:58 PM
    brianwilk
    san luis obispo
    why would it do it only going downhill though?
  4. May 22, 2012 at 3:04 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    More weight to stop the vehicle with gravity pulling you downhill. My VW did it all the time...definitely warped rotors.
  5. May 22, 2012 at 3:07 PM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    x2 warped rotors.
  6. May 22, 2012 at 3:09 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    warped rotors.
  7. May 22, 2012 at 3:13 PM
    Brandon9402
    Brandon9402 uncoordinated dirtbox
    Brandon
    Mississippi
    02 prerunner sr5
    Kenwood headunit, 4 kicker 5x7 coaxials,2 memphis 1.5" tweeters, 2 12" memphis subwoofers, memphis 500w amp, chrome grille guard, kc fog lamps, chrome side steps, chrome tool box, and window visors
    yup warped rotors. my taco did it for a while and i got new rotors and pads. doesnt do it anymore
  8. May 22, 2012 at 3:36 PM
    gm1ll
    gm1ll Member
    12 SR5 Debadged MGM 4X4
    Before going with new rotors, loosen up the lug nuts and using a torque wrench tighten to 70-80 ftlb. Overtightened or uneven tightened lug nuts will 'warp' the rotors and cause this.
  9. May 22, 2012 at 3:49 PM
    brianwilk
    san luis obispo
    dang, wish i'd known that before I bought it! Is it something that should be done soon or is ok to let it go for a little while? Gotta get the finances together...
  10. May 22, 2012 at 3:51 PM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    Agreed. Whenever you get some tire place to rotate your tires, etc, and you told them the torque spec, when you get home, break em loose and torque em right. Nothing beats getting that shit right because they won't. If they actually break out a torque wrench, don't ever go anyplace else - period - you've found the only place that does it right.
  11. May 22, 2012 at 4:07 PM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    Bingo!
    Ive been through the whole resurface and then new with new pads to no solid results
    i am going to give this a try. the guys who did my shocks did the hang of the end of the breaker bar thing.
  12. May 22, 2012 at 4:16 PM
    Blackcat10
    Blackcat10 Well-Known Member
    Ok to drive. Along as there is no grinding. If you have grinding pull the wheels and check the brake pads. Its just anoying putting up with vibration. If it gets real excessive you could break a tie rod end
  13. May 22, 2012 at 10:31 PM
    brianwilk
    san luis obispo
    Great! Thanks everyone for the replies! I'm pretty much a vehicle novest so this really helps me out! :)
  14. May 23, 2012 at 9:53 PM
    Schwinn
    Schwinn Well-Known Member
    Jamie
    Georgina, ON
    2012 TRD Sport with Trail Teams package
    You'll probably find it would do it any time you went heavy on the brakes, too. Depends how warped the are. My wife was complaining her old car was doing it, but when I drove it I never felt it. Then one day I wasn't paying attention and came close to locking up at a light. Shook like crazy.
