Truck Shaking when Breaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shaff33, Nov 17, 2013.
  1. Nov 17, 2013 at 8:22 AM
    shaff33
    shaff33 [OP] Active Member
    Adam
    Harrisburg, PA
    06 Tacoma double cab
    As an avid Penn State fan, I go to every home game. I noticed a few weeks ago that when breaking, especially on downhill mountains, my truck shakes. Specifically the steering wheel shakes and you can also feel it on the break pedal. Passengers do not feel it very much, but as the driver, i certainly do. I have new tires, but they have been on my truck for almost a year now.
    Any thoughts or suggestions?
    Adam
  2. Nov 17, 2013 at 8:23 AM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    You have warped rotors
  3. Nov 17, 2013 at 8:26 AM
    Frogging
    Frogging Well-Known Member
    DEREK
    ORLANDO, FL
    DCLB 4.0 2wd
    ASV vent visors LED tailgate brake light Weathertech floor mats Wish list:Maxtrac Spindles New leaf pack Extended rear shocks Braided Brake lines Konig countersteer Anodized bronze 285/70/18 tires NST Crank lite pulley setup XTP intake manifold spacer Neoprene seat covers Fiberglass fenders Power sliding rear window 1" Spacers for rear wheels
    warped rotors or uneven break pad wear maybe?
    if they are hot and you run through a cold puddle it can damage them. either have the rotors turned and ground down by a pro or replace the rotors all together. not too costly for a important piece of equipment
    for some reason i cant think of anything else
  4. Nov 17, 2013 at 8:35 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    That's a myth. You can't drive these trucks hard enough to make that happen. I bet he has been in stop and go traffic a lot and needs to burn in the pads. Do a couple of 60mph-0 stops. Hard, but not hard enough to get the ABS to engage. I'll bet it goes away.
  5. Nov 17, 2013 at 9:02 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Replace your brake rotors. Mine only had a minor vibration and when I put them on a brake lathe they were too warped to cut. You might want to replace the pads as well. I have noticed complaints about ceramic pads making noise(grinding sound) so I would go with semi-metallic pads. This should solve your problem.
  6. Nov 17, 2013 at 9:05 AM
    169.254.255.201 Well-Known Member
    Interwebs
    I wouldn't worry about it, but do you know the difference between braking and breaking?
  7. Nov 17, 2013 at 9:06 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Break or brake. Or there, their, or they're.
  8. Nov 17, 2013 at 9:11 AM
    CreepyTm
    CreepyTm Well-Known Member
    Long Island, NY
    Bug Out Battle Truck
    Line-X'ed CBI Rock Sliders, Avid Light Bar, Flowmaster 10 series, Painted Grill and bumper, OKLED 20, 5100's with TSB and AAL, Bed mounted M240G
    Rotors are warped....same thing happened to me. Brakes were nice and hot and then i must have hit a deep puddle. The shaking was just as you described, shuddering while braking. The dealership cut the rotors "under warranty" and no more shaking and shuddering.
  9. Nov 17, 2013 at 9:59 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Just burn them in. Try it, it's free and it works. 60-0 two or three times. Do it.
  10. Nov 17, 2013 at 11:36 AM
    Hugh Morron
    Bill
    Brake pad deposits are the dust that is on your front wheels. Whenever I cut rotors it removed metal from the braking surface not just brake dust. That whole speal about brake rotors not warping sounds like it was written by a manufacturer who doesn't want to replace defective rotors. Tacoma rotors aren't very thick to start with(for the size and weight of the vehicle) so I would just replace them. By all means you can try to burn your pads back in but I doubt it will make any difference. Let us know how you make out.
  11. Nov 17, 2013 at 11:42 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Either my dial indicator lies like a politician, or warped rotors are pretty commonplace in my world too.
  12. Nov 17, 2013 at 11:47 AM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    :crazy: It shakes when it brakes or breaks when it shakes? :notsure:
  13. Nov 17, 2013 at 11:49 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Warped rotors...Myth #1 is just that, a Myth....
    I just got new rotors, problem solved, took my old ones in to have them turned so I would have some 'backups', they wouldn't turn them, said too warped, said if they turned them it would cause thinner spots when turned and would almost immediately rewarp because of this...
    just my .02 worth...
  14. Nov 17, 2013 at 12:27 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    If you were to take a rotor that was supposedly warped and measure it for lateral runout with a dial indicator, you would probably see runout in excess of 0.003". I say that because it takes approximately that amount of runout (or more) for the average person to feel in the brake pedal as pulsation. For the most part 0.002" or 0.001" of runout is very difficult to feel in the brake pedal. So what is causing that runout? Well, most people would say that the metal rotor warped, and the solution is to machine (or lathe/cut) the rotors to make them true again. In reality, the runout is almost always caused by uneven pad deposits on the surface of the rotor. In other words, the brake pads aren't depositing material evenly around the rotor. The result is high and low spots on the rotor, which result in excessive runout, and of course pedal pulsation. Machining the rotors will make them true again. So will bedding the pads with a few hard stops. Try it, it's free and I'll bet you a beer it works.
  15. Nov 17, 2013 at 12:44 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    I cannot agree with you there. On multiple occasions I have mearured rotor run-out well in excess of .010", yet parallelism (AKA thickness variation) was still within spec of under .0005" when measured with a mic. I like beer.
  16. Nov 17, 2013 at 12:49 PM
    Snowman11
    Snowman11 Supreme Ruler
    Snow
    Near Philly
    2011 DCLB TuRD Sport
    5100 Billies
    Maybe it works for you... but in my 30 cars that I beat the living shit out of, I have gotten warped rotors on every one. I have done 60-0 brake hits as an ordinary part of having fun since I started driving. You sir are incorrect.
  17. Nov 17, 2013 at 12:53 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Get new front pads and rotors. Problem solved.
    If you suck at driving, you'll warp rotors nice and quick. Learn to let off the brake and use engine braking.
    Rotors get warped from being too hot. Let them cool down. I drive a truck with 35s, armor everywhere, and lots do heavy extras. Gues what? I've never warped the rotors. I've done hard stops, slow stops, I drive down a long steep hill home everyday and I've never warped my rotors. You need to concentrate and use your head while driving. When your rotors are warped, they don't work nearly as well. When you emergency stop, your stopping distance will increase. Braking and steering are the most important parts of your vehicle...keep them in shape.
  18. Nov 17, 2013 at 1:17 PM
    macb15
    macb15 Active Member
    Mac
    Charlotte, NC
    04 SR5 4x4
    I recently had a little shimmy while braking and thought my rotors had warped as well. I got my tires rotated and re-balanced a few days ago and the shake is gone. So don't count out unbalanced tires...
  19. Nov 17, 2013 at 2:41 PM
    169.254.255.201
    Interwebs
    Or breaks when it is braking??
  20. Nov 17, 2013 at 4:03 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Have a brake, have a kit kat! Chocolate coated brake pads FTW!:cool:
