Truck shell...
Discussion in 'Tonneau Covers, Caps and Shells' started by Ahitaco, Nov 7, 2010.
  1. Nov 7, 2010 at 8:41 AM
    Ahitaco
    Ahitaco [OP] Member
    Dave
    Utah
    05' 4x4
    I have an 05' double cab longbed, and I want to put a shell on it. Any advice on Brand or Style that looks like the shell belongs?
    Thanks
  2. Nov 7, 2010 at 8:46 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Welcome
    SnugTop's & Leer look good just make sure it's body color matched and it will look good
  3. Nov 7, 2010 at 2:11 PM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    ARE "Z" series is what I went with and I like it. Paint matched perfectly.
    I liked the rear door hidden hinge system and the door handle and locking system seem beefy and engineered well. So I went with the "Z" series. What ever you buy, inspect it carefully before the dealer installs it on your truck. For the money you want it to be perfect.
  4. Nov 7, 2010 at 2:23 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    In my opinion the SnugTop SuperSport matches these trucks perfectly...
  5. Nov 7, 2010 at 2:39 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I've got the A.R.E. MX something. It doesnt look the coolest but it does fit the truck great, colormatched, and most importanly it's functionl for me.
    This topper has the opening side windows, super handy. I recommend you get those on whatever topper you choose.
  6. Nov 7, 2010 at 3:50 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    I've got a "Jason" brand shell, and although it's not as cool as ^^^ with the opening side windows, I can say that it's tough as S**T! It actually flipped off the back of my truck a few weeks ago while wheelin'... Flew about 6 feet through the air, landing on it's lid, on a bunch of rocks. The thing was scratched up pretty good, but did NOT break! I was amazed. Fixed it up at the shop, and she's good to go again.
  7. Nov 7, 2010 at 4:00 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    No matter what brand you select get the windows to fold down especially the one that butts up to the cab. I didn't think much of it when I got my ARE, which I love except when it comes time to clean the window against the cab.
  8. Nov 7, 2010 at 4:17 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    I got the V series with the Yakima racks, 100_1132_fbf11013b0f73e89d4b53ba124d3534a8b40edc0.jpgsliding rear window and LED dome light. Paint is perfect, and i really like how it looks on my truck. I was gonna get the tilt-up side windows but I've red where guys had problems with leaks.
  9. Nov 7, 2010 at 5:46 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    i have an ARE Z cap as well..lots of $$$ but in the end im sure it will be worth it..ARE customer service is also top notch..
  10. Nov 7, 2010 at 6:49 PM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    I like my taller shell. Didn't at first, but now I wouldn't have anything else.
    RZ Rob
  11. Nov 7, 2010 at 9:25 PM
    Mtnfreak
    Mtnfreak Active Member
    In a place you've only dreamed of....
    '05 Taco, Access Cab, 4x4
    Yes.
    I have to vote against ARE. I got the MX and sent the first one back. All of the metal trim looked like it had been cut by a 10 year old with hedge shears and then installed by the same kid who was a virgin with the pneumatic driver. There was fiberglass everywhere in the headliner - like they'd cut the windows after installing the carpet. The headliner wasn't even attached to the shell in several large patches. The rear door leaked, the front bed seal leaked, the 3rd brake light filled with water. This was a truly amateur effort. When I arrived at the dealer to have the 2nd attempt installed I had to tell them to send it back and refund my money. I gave that shell a C+ but they cut me a deal that I couldn't refuse. If I had to do it all over again I'd go with Jason - seemed like a quality at a reasonable price.
    Definately get the folding front window. If you can justify the extra bucks, the openable side windows are really nice. They may not be a standard option, but the good dealers can make it happen. Skip the factory lights - most of them are worthless. Get some LEDs from Oznium.com and install them yourself - it's not hard.
  12. Nov 7, 2010 at 9:39 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    ^ Nice first post.
  13. Nov 7, 2010 at 9:53 PM
    Maksimus54
    Maksimus54 Well-Known Member
    Seattle
    07 SR5 TRD OR
    I'm most familiar with Leer and Snugtop by name and reputation. I don't think you can miss with either. I'd find a canopy company and go inspect the different brands and styles yourself and see what you like.
    I bought my truck used with a snugtop already. My only regret is that it is key operated only, I'd really prefer a lockable pushbutton type opener. Make sure to pick one with a latching style that will work best for your use.
  14. Nov 7, 2010 at 10:27 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I've got a used ARE CX series with the Yakima rack. When I was looking, the guy at the local topper dealer said sometimes the lesser known brands, like Jason and Century, are a better deal for the buyer in terms of warranty and features. I'd also heard a few reports of problems with Leers, but was still open to considering them. I like the Snugtops, but couldn't find any in my area. If you're going for a new one be ready to drop some coin if you get the side windoors and drop down/sliding front glass. I wish mine had those, but probably couldn't have afforded them on a new one anyways.
  15. Nov 8, 2010 at 3:08 AM
    Ahitaco
    Ahitaco [OP] Member
    Dave
    Utah
    05' 4x4
    Thanks for all the input, I have more to think about now.
  16. Nov 8, 2010 at 10:29 AM
    ASH
    ASH Well-Known Member
    SF Bay Area, CA
    2010 DC PreRunner TRD Off Road
    SnugTop Rebel Shell, Bilstein 5100's @ 1.75, Rear TSB, BFG A/T KO 265/75/16, Tranny TSB, WeatherTech Digital Fit Floor Mats, Debadged (Sides), Black Badges (Tailgate), Avid Off Road Sliders, TRD Shoulder Pads, Factory Color-Matched Grille w/Blacked-Out Emblem
    Another vote for SnugTop. After comparing the SnugTop and Leer at the dealer, the SnugTop's quality won me over. Here's my Rebel:
  17. Nov 8, 2010 at 10:32 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Have i ever told you that i love your truck?
  18. Nov 8, 2010 at 10:35 AM
    myth01
    myth01 Well-Known Member
    south sf, ca.
    08 taco Trd sport
    eclipse nav.-w/ Bluetooth & iPod 3'' revtech add a leaf lift kit snug top ss truck cap dive tank racks in back Aux fuse box Aux back up lights, w/ interior fj cruiser stock switch Back up cam Turn signal cams Interior inverter -switched Aux audio/video inputs -RCA (including iPhone cable)w/ 4 input switch Mag light mount Tyredog stand alone tpms Spare tire extension hose Avid off road light bar(powder coated)
    i have the snug top super sport looks awesome and 2 word KEYLESS ENTRY tied in with passenger side door
  19. Nov 8, 2010 at 4:20 PM
    satchsd
    satchsd Old Guy Member
    keller texas
    leer 100 XQ
  20. Nov 8, 2010 at 4:26 PM
    ASH
    SF Bay Area, CA
    Thanks, man. :cheers:
