Truck shifted itself into 4hi?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joes06tacoma, Sep 2, 2010.
  1. Sep 2, 2010 at 7:13 AM
    joes06tacoma
    joes06tacoma [OP] Well-Known Member
    Joe
    Central Coast, CA
    So last night I get into my truck and start backing it out of a parking spot. It feels like it's going to stall out as I am turning sharp and moving backwards. Felt like I was rubbing a tire on the curb or something. So I pull back into the parking spot and I notice the green 4x4 light is on. The switch is still in 2hi. So I turn the switch to 4hi, wait a few seconds, then turn it to 2hi. Light starts flashing, then goes out. No more issues since, even put it back into 4hi a couple times just to test. Any ideas?
    I think the switch might have been just slightly out of 2Hi, but not sure and I can't duplicate the problem by slightly moving the switch.
    :confused::confused:
  2. Sep 2, 2010 at 7:15 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    If it doesn't do it again, your problem is solved!
  3. Sep 2, 2010 at 7:16 AM
    joes06tacoma
    Joe
    Central Coast, CA
    That's what I figure.
  4. Sep 2, 2010 at 7:16 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Was there alcohol or any other chemical substances involved?
  5. Sep 2, 2010 at 7:41 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Do you have a leprechaun problem in your area?
  6. Sep 2, 2010 at 7:46 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Well, I was in the Taco Bell parking lot. I suppose there could have been something extra in my mountain dew!
    We do have a leprechaun problem, but they seem to be scared of the dark, so I don't think that's it.
  7. Sep 2, 2010 at 7:48 AM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    the taco wanted to crawl into taco bell and get a bite to eat
  8. Sep 2, 2010 at 11:23 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Did you do recall with ECU re flash ?
  9. Sep 2, 2010 at 4:55 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Nope, no recall yet.
  10. Sep 2, 2010 at 4:56 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    it's happened to me before, do u drive stick? cuz the e-brake handle is real close and u could have bumped it
  11. Sep 2, 2010 at 4:56 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Spontaneous acceleration AND spontaneous 4WD activation! THAT would be a true problem!
  12. Sep 2, 2010 at 4:58 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Yeah, it's a six speed. And I was pretty tired, so I could have bumped the 4wd knob. But I am positive that the knob was not all the way to the 4hi position. If anything it was just slightly out of 2hi.
  13. Sep 2, 2010 at 5:03 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I have a buddy with a dodge dakota 4wd, his mom this super asian lady used to drive it sometimes, and she was insistant in not ever taking her eyes off the road she tried to adjust the heater without looking and she always put it in 4lo without knowing. One day we went to drive it and it scared the shit of us.
  14. Sep 2, 2010 at 5:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    This is my main worry. If there really is something wrong, and it's not just me, then next time maybe it'll shift into 4Lo. Then I could be one of those stories on the news and everyone will think I'm just another nut job trying to squeeze money out of Toyota.
  15. Sep 2, 2010 at 5:24 PM
    ktmrider
    Junk
    Well if it does shift into 4lo i really dont think you will have any problem with accelerating to uncontrollable speeds cause it really doesn't go over like 30 lol
  16. Sep 2, 2010 at 5:45 PM
    David K
    Being that you have to stop, put it in neutral, depress the clutch if a manual tranny... I don't see it happeneing. Try and go into L4 while moving and all you get is the flashing light to alert you that you are doing it wrong!
  17. Sep 2, 2010 at 8:03 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I've had a similar problem before. Get in the truck only to find it mysteriously switched itself into 4HI!:eek:
    Problem seems to have resolved itself as my daughter has gotten older and wiser...:p
  18. Sep 2, 2010 at 9:29 PM
    a89aries
    a89aries Well-Known Member
    Alex
    London Ontario
    09 Tacoma TRD offroad
    Sometimes my friends and I will mess with each other by dropping each others truck into 4L when they aren't looking. Nothing like lurching forward in 1st gear when you go to take off normally!:D
  19. Sep 2, 2010 at 10:05 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    ^ that's really bad for the truck, especially on paved roads
  20. Sep 2, 2010 at 10:33 PM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    Just a thought, but I unplugged my switch when I was putting the lighted-switch kit and noticed later my 6 speed switched into 4 high. I had to drive it 40 miles that way until I got back and could plug the switch back in.
    RZ Rob
