truck shop told me blist. 5100 1.75" is bad
Discussion in 'New Members' started by reggie1234, Oct 23, 2013.
  1. Oct 23, 2013 at 12:30 PM
    reggie1234
    reggie1234 [OP] Member
    just got first tacoma a 2013 off road series. added a bakflip tonneau cover. westin black 4" step bars. and guy at truck shop said adding front suspension blistein 5100 adjusted to 1.75 inch would be harmful to the truck. also said anything less then 4 inches in front and 2.5 in back would be harmful. anyone ever ear of this
  2. Oct 23, 2013 at 12:32 PM
    Large
    Large Red
    Sounds like he wants you to drop some money in to a 6" DB lift, tell him to go f$%@ himself and go somewhere else, IMO.
  3. Oct 23, 2013 at 12:33 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Sounds like a bunch of BS to me
  4. Oct 23, 2013 at 12:34 PM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    this
  5. Oct 23, 2013 at 12:43 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Assuming you mean "more than 4 inches in front and 2.5 in back."
    First question: 1.75" should not be harmful, although it does put a lot of preload on the springs. It will ride rough, especially if you have the Off Road progressive springs. Personally, I would not use more than 0.85" on non-progressive stock springs, and no preload on progressive springs. That is personal preference, though, and it should not be harmful to the truck.
    Second question regarding lift heights: What they most likely mean is alignment issues and CV axle angles on the front lift. Unless you also change out UCA's, anything over 3" in front will be near impossible to align properly. CV axle angles will not be ideal and they may wear slightly faster, but again, not what I would consider harmful.
    For the rear, the driveshaft angles will change and may cause vibrations. Carrier bearing drop and/or angled axle shims can be used to reduce vibration issues. Again, maybe not ideal, but not really harmful.
    In the end, if you are happy with the results, none of these things would really be harmful. Just be aware of what you might run into and have realistic expectations.
  6. Oct 23, 2013 at 12:50 PM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    This^^
    guy doesnt know jack!
    above 3 inches will need a UCA to allign, your cv angles will be worse, but just dont go over 3 and you will be fine
  7. Oct 23, 2013 at 6:24 PM
    vstrom
    vstrom Well-Known Member
    I've got Billy's on all four corners. The front are set at 1.75 on stock springs. I also have airbags on the rear.
    The ride is excellent! It soaks up every bump on the road without a bounce .. definitely not rough or stiff. Would recommend this setup for anybody.
