Truck shudders when turning steering wheel
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Nov 28, 2021.
  1. Nov 28, 2021 at 3:19 AM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Hi guys, I had a power steering flush done. I noticed that when the engine is cold and I turn the steering wheel I get a low whining. Also noticed that if I press the brakes in Drive and turn the steering wheel the truck shudders “vibrates” this happens if the truck is fully stopped and if I’m pressing the brakes and turning the wheel, any ideas?? I’m worried now please help
  2. Nov 28, 2021 at 7:53 AM
    Wurmwood
    Wurmwood Well-Known Member
    Kentucky
    1997 Toyota Tacoma 2.4L 2wd 5spd
    Whining when turning the wheel usually means the power steering fluid is low. Maybe when whoever flushed it they got some air in the line? Also didn't fill it up all the way?
  3. Nov 28, 2021 at 9:59 AM
    Hektor
    Texas
    Should I check with the truck at operating temperature and hot mark??
    Taco critter likes this.
  4. Nov 29, 2021 at 4:29 PM
    Tacoma-MO
    Tacoma-MO New Member
    I’m having the same problem, 99 4x4. When stopped, is at it’s worst near full lock. Either the pump is failing or the rack and pinion. The more of a load on it the more it shudders. Any suggestions on how to diagnose between the pump or rack? Thanks
  5. Nov 29, 2021 at 8:13 PM
    Hektor
    Texas
    Exactly same here it’s worst at full look. The whole engine shakes vibrating
  6. Nov 29, 2021 at 8:59 PM
    Glamisman
    Glamisman Well-Known Member
    it is my understanding that there is a filter at the bottom of the reservoir, low flow could be due to filter blockage.
  7. Nov 30, 2021 at 6:36 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
