Truck shut down
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoma92, Sep 2, 2010.
  1. Sep 2, 2010 at 12:06 PM
    tacoma92
    tacoma92 [OP] Black Hole Sun
    Forrest
    Gulf Shores, Alabama
    09 SR5 Toyota Tacoma
    I was driving on the interstate and there was backed up traffic. The traffic was moving about 10 mph. When I got off of the exit where I was staying, my truck started squeaking under the hood and after that my acceleration wasn't working and my steering wheel and brakes stiffed up. Anybody kno wat this could be?
  2. Sep 2, 2010 at 12:11 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    did it start back up again? will the engine even turn over or does the starter just make a clicking sound?
  3. Sep 2, 2010 at 12:12 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    So it stalled out?
  4. Sep 2, 2010 at 1:03 PM
    tacoma92
    Forrest
    It turns over but doesn't start
  5. Sep 2, 2010 at 1:05 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Are all the belts still on their pulleys? Im trying to figure out what the squeak was.
  6. Sep 2, 2010 at 1:11 PM
    tacoma92
    Forrest
    Yea they r all still on the pulleys
  7. Sep 2, 2010 at 1:15 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Timing belt?
  8. Sep 2, 2010 at 1:18 PM
    tacoma92
    Forrest
    Thts one thing I thought it would be. Wat would cause tht though?
  9. Sep 2, 2010 at 1:18 PM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    Yeah, sounds like timing.
  10. Sep 2, 2010 at 1:21 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    When's the last time it was changed?
  11. Sep 2, 2010 at 1:24 PM
    tacoma92
    Forrest
    I have no idea. I bought the truck a year ago and since then have put 25000 miles on it. How much would it cost to change it?
  12. Sep 2, 2010 at 1:25 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Good thing you got a non-interference engine ;)
  13. Sep 2, 2010 at 1:28 PM
    tacoma92
    Forrest
    Y is tht?
  14. Sep 2, 2010 at 1:28 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Parts to do my Timing Belt...Water pump...T-stat...and Serpentine belts was around $500 + Labour + Taxes
  15. Sep 2, 2010 at 1:30 PM
    84Hilux
    Gary
    Vancouver, Canada
    I was going to ask this- So, if your timing belt breaks it does not screw up your valves ? Good to know!
  16. Sep 2, 2010 at 1:30 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The timing belt can run any where from 500 to 1000 depending where you go. You could do it your self if you have the know how for about 200 bucks in parts give or take a few dollars.
  17. Sep 2, 2010 at 1:31 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    A 'non-interference engine' is designed so that if the timing belt or chain breaks while running, the valves will not strike the piston tops. The engine will only stop running without damage. 'Interference' engines will suffer major mechanical damage if the chain or belt fails during operation, thus the need to replace the belt or chain when recommended.
  18. Sep 2, 2010 at 1:32 PM
    tacoma92
    Forrest
    Yea tht is. Thank god it won't mess up the valves
  19. Sep 2, 2010 at 1:57 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    cost me just shy of 300 to do it myself with NAPA parts. First pull that plastic cover off the front of the motor just to make sure it is the t belt. I don't see what else it could be but still, just make sure.
  20. Sep 2, 2010 at 1:58 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Just so you are aware in the future, the recommended service of the timing belt is 6 years or 90,000 miles.
    There are also many other things that should maintained as well, including transmisison fluid, front and rear diff oil, transfer case oil, spark plugs, and inspection of pretty much everything that is made of rubber or has rubber on it (hoses, belts, cv boots, ball joints, brake lines, etc).
    Back in the day, people would ask how important it is to worry about anything besides just a regular oil change. My response is the same today... It just depends how long you want your vehicle to last.
    Attached is the service intervals for your truck. Please use it. It was gotten from http://smg.toyotapartsandservice.com/guides.php
